Question about Oreck Vacuums
I have an Oreck XL2800H2 upright vacuum and had to take the motor out to clean it. Now I need to rewire it but need a wiring diagram to do so. Can anyone help? Thanks!
I need a wiring diagram for the Oreck XL2800H2
chrispurs1
  • 372 Answers
SOURCE: Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Posted on Sep 09, 2007
reddevil6
  • 1673 Answers
That the bottom plate off, check for a clog in the inlet. If clear, then you probably have a clog in the handle tube. You will have to take the handle loose to clean it out. It may also need a new belt if you haven't changed it for a while, they stretch.
Posted on Feb 05, 2008
Agent Don
  • 310 Answers
SOURCE: Oreck XL
I would advise you to ALWAYS to FIRST UNPLUG THEIR VACUUM before beginning any service procedure. The motor has 5 wires to the motor as stated in the Oreck owners manual, tow are for the headlights, one is a ground wire, and the other two are for the motor. There are two screws that hold in the Oreck motor and a good suggestion is to use tape the wires leads and mark the wires so that you will not make a mistake as you take it apart and reassemble the motor. That way you will not make any mistakes, whether or not you have wires for a headlight or not, the rules are the same. Also refer to the owner’s manual schematic and the exploded view. Questions? 1-800-989-3535
www.Oreck.com
Posted on Apr 09, 2008
Agent Don
  • 310 Answers
SOURCE: wiring diagram Oreck XL2
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=650346
Wiring diagram Oreck XL2
Posted by geohil on Jun 06, 2008
Can I get a wiring diagram of the handle on an Oreck XL 2.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL Ultra Bagged Upright Vacuum. The best place to get an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 09, 2008
  • 5 Answers
SOURCE: My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Posted on Oct 15, 2008
MY ORECK KEEPS CUTTINH OUT IF I WIGGLE THE WIRE IT STARTS AGAIN IT IS AN ORECK XL UPRIGHT
Cable has broken internally, wiggling is temporarily making contact which is why it then works. Get it rewired by a cometent person !!!
Oct 18, 2014 | Vacuums
I have to replace a motor on an xl classic. The bad motor is out and i do not know exactly where the wires connect on the new one. I need a wiring diagram.
Hi, it's Jeremy from Crucial Vacuum.
Below you will find a link for many different models of the Oreck XL Classic Bagged Upright Vacuum. I hope you find the link useful.
http://www.oreck.com/PUG/76054-01-REV-A-U2251-CLASSIC.pdf
If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
http://www.crucialvacuum.com
May 22, 2014 | Oreck XL® Classic Bagged Upright Vacuum
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Go Ahead. Use Us.
Jun 06, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Wiring
Here are the 4 different wiring for new Oreck motors.
Apr 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL
www.Oreck.com
Mar 31, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
172 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
