Question about Oregon 511ax 115-volt Bench-mount Chain Grinder
Adjustsettings on Oregon 511AX bench grinder
Tried to reposition the vise assembly to compensate for the wearing down of the grinding wheel's diameter; instructions provided are incomprehensible to me
  • RON Benoit
    RON Benoit Dec 12, 2014
    oth answers,while meant well, were incorrect; I made that determination by locating two nuts beneath the vise. Thank you both for trying to help; I'm appreciative of your concern.
  • 30 Answers
There is a nut and bolt that holds the little shelf below the grinding wheel. Loosen it and adjust the shelf or rest to within approximate ly1/8 inch of wheel for safety.
Posted on Nov 27, 2014
How complicated can that be?
Does it not have a nut on the side you loosen
& move the steady rest in toward the grinding
wheel or wire brush?
You do not need instructions to use a bench grinder
Not in my 55 years of doing so
Testimonial: "Agreed; instructions for this grinder confuse more than help... thank you."
How do I lock the grinding wheels on bench grinder
Push the lock button down while turning the wheel till it clicks in and locks , release the button and it unlocks.
Oct 18, 2014 | Grinders
How do I tighten the nuts on my bench grinder?
A bench grinder has left handed threads on one shaft and right handed on the other,so that the grinding stones don't unscrew the nut as you grind something.I haven't ever gotten around to getting a bench grinder,but on my father's, I used to just hand tighten the nut,then grab the grinding wheel with my hand while tightening the nut with a wrench.(You don't have to make it real tight,as the wheel pushing against the nut will keep it tight)
May 04, 2012 | Heating & Cooling
Both wheels have a noticeable wobble. Can this be corrected?
Yes, the wobble can be fixed. First, remove both wheels and check the shaft bearings/bushings for wear. Make certain the grinder is unplugged and mounted securely. Try moving the shafts up, down side to side; there should be little or no noticeable movement. If there is movement it is a major(time and money) problem. I'm not familiar with what the shafts ride on. It could be, ball bearings(the best-long lasting, least friction, most accurate, but expensive), sealed bearings(almost as good as ball bearings, with many of the same attributes) and bushings(least expensive to produce and fit and cause the most friction. If excessive up,down side to side movement is present a decision must be made as to how much money/time you want to invest. If the shaft exhibit little movement; check if the shaft is running true/straight. Turn the grinder by hand while observing the shaft for bends. If none are seen by eye use a magnetic base micrometer to check run out(deviation from straight). If a micrometer isn't available; bend a short length of wire(coat hanger works nicely) with a small hook on one end and then put a pointer end on the other. Put a screw thought the end with the hook to mount it to the base of the grinder. Then bend the pointed end so it just touches the shaft. Rotate the shaft and notice if the distance changes between the point of the wire and the grinder shaft. Repeat for the other side. A couple of thousands won't hurt. However, any more and the cost effectiveness of tearing the grinder apart straightening the shaft must be considered. The most common cause of grinding wheel wobble is the wheels becoming out of true and/or unbalanced. This is easily cured with a wheel dressiing tool. The tool grinds the wheels in place. By gringing the wheels on the grinder they balance the wheel, true the wheel to the shaft and clean it of imbeded soft materials, aluminum, wood and so forth.
Feb 23, 2011 | Dewalt DW758 Heavy Duty 8" bench grinder
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
Grinding wheel for Delta bench Grinder where to get one.
It should take a standard grinding wheel, available at almost any hardware store.
Oct 13, 2009 | Delta Grinders
What wheel do I use for grinding chrome
Grinding chrome is not recomended on a bench grinder
Aug 30, 2009 | Baldor Grinders
Delta 23-880 bench grinder
You should be able to hold the grinding wheel with a pair of leather gloves on your hands and lossen the bolt. Look very carefully at the threads to make sure you are trying to lossen and not tighten. Some are left handed threads on bench grinders.
Aug 29, 2008 | Delta ShopMaster 8in Grinder with Light...
Bench Grinders Safety issues
Goggles or safety glasses need to be worn to protect the operator's eyes from the sparks and metal filings that result. Depending on the workpiece and time of exposure, hearing protection may also be required, the dust produced is also potentially hazardous. The toolrest (or workrest) should be mounted slightly below the center of the grinding wheel with less than 3 mm clearance from the wheel. This prevents the work from jamming between the toolrest and the wheel. Grinding wheels designed for steel should not be used for grinding softer metals, like aluminium. The soft metal gets lodged in the pores of the wheel and expand with the heat of grinding. This can dislodge pieces of the grinding wheel. Wire brushes require particular attention for the safety of the operator and bystanders as the metal wires may become dangerous projectiles as they could bind with the object being brushed and so throw it away with great energy. The machine needs to be securely mounted to a pillar or a bench to be used safely and effectively, often with an emergency stop switch or pedal fitted close by the machine, for use in emergencies.
Aug 27, 2008 | Clarke Power Products Cast Iron Bench...
Bench Grinders Usage
Grinding is the fastest way to deburr a sharp corner or dress the end of threaded rod or bar stock that's been cut to length. Fit a grinder with a wire wheel, and you have a handy tool for removing rust. Then switch to a buffing wheel and you're ready to polish metal to a mirrorlike sheen. But for most of us, grinders are essential for shaping and sharpening hardened tool steel and high-speed steel.
Aug 27, 2008 | Black & Decker 3/4 Hp, 8" 205MM, Heavy...
Precision work question
Bench grinders aren't designed for precision work. In fact, they're really freehand tools that rely on a good eye and careful touch. And while you can take some tools, like drill bits or turning tools, right from the grinding wheel to the work, it's common for grinding to be a relatively coarse, preliminary shaping procedure, followed by careful honing on a whetstone.
Aug 27, 2008 | Black & Decker 5/8 Hp, 6" 150MM, Heavy...
Oregon 511ax 115-volt Bench-mount Chain Grinder Logo
158 people viewed this question
Top Oregon Saws Experts
Tom Chichester
ray gallant
Are you an Oregon Saw Expert? Answer questions, earn points and help others
