Question about Salter 1250BK Electronic Diet Scale
How do I keep my salter electronic diet scales 1250Bk from bouncing in the digital display?
I have calibrated them a few times. Changed the batteries. Cleaned them. Made sure they were sitting on hard level surface.
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
Posted on Oct 20, 2009
SOURCE: E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Posted on Dec 29, 2009
  • 10865 Answers
SOURCE: I own the Salter Stainless steel electronic
yes. here is the link to the company http://salter-scales.com/ just click on the link and then enter your country. then you will see a place for parts or to contact them.
Posted on Mar 25, 2010
Testimonial: "Thank you! Wow, didn't expect a reply so quickly. Appreciate your help."
SOURCE: E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Posted on Jul 28, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
What would cause a water pump to crack or break on a 2000 chevy blazer i have changed it 2 times for it and now again
If the mounting surface is not cleaned of all old gaskets or o rings and debris it will crack when tightened. Also when you mount it make sure it is sitting flat and not in a bind while you are snugging bolts up before you tighten in a cross pattern.
Sep 27, 2014 | 2000 Chevrolet Blazer
How to reset as scales are not weighing properly and new batteries have been inserted
These scales cannot be calibrated so i'm afraid that it's time for a new set. I think they were first manufactured in 2002 and they have a 10 year guarantee which meas you are out of luck. If you are in the UK, this site is a good place to start looking for another set of All Kitchen Scales
Jan 23, 2014 | Taylor Salter 1010 Stainless Steel...
My Fan runs all the time on my HP Pavillion a6720f
GIF's and certain media and even Flash will make your Fan run continuously. Observe what you are doing when you hear the fan run. Also you said you cleaned the fan, did you open the bottom plate and then clean it? Also, is there a hard surface you are keeping the laptop on or are you sitting in bed using the laptop?
Aug 23, 2012 | HP Pavilion a6720f PC Desktop
Hard Starting Issue
Just went through similar deal 06 mega cab 5.7 hemi everybody was tellin me it was the TIPM Total intigrated power module. I changed my fuel pump and been running good since make sure all connections are good going into the tipm
Aug 20, 2012 | Cars & Trucks
My D-7 will not power up...when turn it on the power light weakly flickers (as well as the power sound) for only sec then nothing. Have cleaned battery connections, used charged batteries and even to
Sounds like electrolytic capacitor dried up needs curing, which is power on capacitor and left it absorb some moisture in humidity on power. Some time a few minutes, hard cases may take a few days.
Feb 08, 2012 | Konica Minolta Cameras
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
I replaced my battery and now I have a engiine light vsc light and 4wd light warning no throttle response and problem code p2118. checked all fuses all good. any ideas please help.
Tests/Procedures: 1. Perform zero point calibration of the yaw rate sensor/deceleration sensor. Potential Causes: Deceleration Sensor Zero Point Calibration
Tech Tips: Code C1336 is for Deceleration sensor zero point calibration undone. To perform zero point calibration, have the steering wheel in the straight ahead position and have the vehicle on a level surface within an inclination of 1%. Turn the ignition switch OFF. Use a jumper wire and connect terminals TS and CG of Data Link Connector (DLC) 3. Turn the ignition switch ON. Keep the vehicle stationary on a level surface for 2 seconds or more and verify that the VSC warning light blinks. Diagnostic Codes: C1336
Jan 24, 2011 | 2006 Toyota RAV4
Salter 1250BK Electronic Diet Scale Logo
404 people viewed this question
Top Salter Home Experts
Donni Steen
Tom Chichester
Are you a Salter Home Expert? Answer questions, earn points and help others
