Question about Amana PTH123E35AXXX Air Conditioner Heat Pump
Have Amana model PTH123E35 heat doesn't shut after reaching temp. Suggestions?
Nothing yet just suspect thermister or heat limiter.
    New Friend:
  • 4 Answers
Replace thermister or fuser
Posted on Nov 27, 2014
5 Suggested Answers
  • 182 Answers
SOURCE: Amana GUIC070A30 furnace won't run.
jump a wire between r and w on the board.if it fires its in your tstat\wire
Posted on Oct 04, 2008
heatman101
  • 43501 Answers
SOURCE: Amana Model PTH153A50AC wont cool or heat
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Jul 12, 2010
hvac1960
  • 2133 Answers
SOURCE: Amana cool/heat unit PTH093B35AM gives error code
Fixed in the middle of evaporator coil.
Posted on Jan 04, 2011
  • 4736 Answers
SOURCE: Amana PTH153B50AM AC & Heat
Jane, what you really need is the Owners Manual for you discontinued model AC/Heat Pump.
Call Amana Customer Support 1-800-843-0304 and they can furnish you one. Either by email attachment or by snail mail.
Hope this helps you. Please let me know.
Posted on Jun 20, 2011
Have amana furnace model GACA070AX30. FURNACE HAS A 5 FLASHES ON ERROR CODE. FURNACE STARTS UP REACHES THERMOSTAT SETTING, BURNERS SHUT OFF BUT FAN MOTOR WILL NOT SHUT OFF. IT ALSO TRIPS ROLLOUT LIMIT
This is a dangerous situation. If your rollout is being tripped open, the heat is going where it should not be going. The fan stays on because it is designed to dissipate the heat.
Nov 03, 2017 | Amana Heating & Cooling
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
DLE330RAW amana dryer running too hot
The control thermostat on the blower housing is the one you need to change if it is getting too hot. It is taking too long to shut off the element. The only other thing it could be is a blocked vent making it overheat. The fuse is set for 350f the limit on the element is a 250 f one. I suspect the 250 f limit on the element is doing the drying not the control stat. Hence you getting overheat but not hot enough to blow the fuse.
Apr 13, 2013 | Amana DLE330RAW Electric Dryer
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
Kenmore side by side Model #106.55532400 Orignally the frig. side would not cooled down below 40F even when the digital control was lower to 33F. The unit was unloaded and turned off for 24 hours, doors...
Yes the thermister is the electronic thermostat...on models such as yours that has a computer control a thermister is used..on models that the knob is turned to set the temp. and has no digital dispay a thermostat is used
The part number for the thermister is 2188819
It fits by air damper in the fresh food compartment in the upper left corner of the fresh food compartment
GENE
Sep 09, 2011 | Kenmore Side by Side Refrigerator
Amana PTH153B50AM AC & Heat pump. fan works AC & heat don't. I was told by the guys who installed it to unplug it to reset the termostat but that don't work either. I turn it on cool &...
Jun 20, 2011 | Amana PTH153B50AM Air Conditioner
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
Amana PTH123E35AXXX Air Conditioner Heat Pump Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
