Question about Grilling
<!-- from fixya rte -->How do i light with match - Grilling
How do you put together words,
to make up a question
That is the issue here
Posted on Nov 27, 2014
How do i re start the pilot lght
You will need:
a wire hanger or something like that about 14 in long
a small clip and matches to clip to wire.
Turn red knob to off
remove small door covers (Both).
look inside you will see a tube pointing up this is where you put the match to light it.
turn red knob to pilot and push down and hold
light match and put it at end of the tube inside it will light a blue flame
remove match.
all this time holding knob pushed down
continue to hold down for 60 sec
then let it up slowly and turn knob to on
should flame up and start whole burner
replace door your done.
OR call your gas company most will light it for free
Jan 17, 2016 | Water Heaters
What is the pictured part used for?
That is a probe that one attaches a lit paper match too(see circle) so you can light the piolet light w/o getting burned.
Jun 07, 2015 | Thermos Grilling
Some wire colors don't match! They can't match! So which mismatch is correct?
is the light engine the exact type?. ensure it is what are the old engine wire colours and what are the new ? red matches brown green for yellow white for black or grey but still u need the exact light engine match
Jul 17, 2013 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kenmore quantum series gas grill: where do I put the match to light it?
Using the wire match holder that came with the grill. Place the match in the holder, light the match and place it next to one of the burners. Turn the burner ON just enough for the gas to rise and the match will light the burner. Quickly remove the match and continue lighting the remaining burners you want to use.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Kenmore Grilling
Electronic ignition doesn't work anymore. How do I manually light this?
Before you go to match lighting, have you changed the battery in the ignitor button? If you haven't, I'd start there first. Unscrew the ignitor cap and the battery's Positive Tip (+) will be facing you. Be sure to install the new battery in the same direction.While the battery is out, check for any corrosion that may be present in the battery holder. A Q-Tip & WD40 work well to clean out any corrosion.
To match light the burners ... use a long stick match (also called a hearth match) and carefully guide the match between the grates and under the flame tamers, as close to each burner as possible. Of course, the match should be lit prior to doing this. Turn each burner on individually, as you place the lighted match next to it. Once the burner lights, turn it down to low and move to the next burner and so on, until all the burners you want to use are lit. Then set the flame heights where you want them.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 01, 2011 | Char-Broil Advantage 463453306
My E320 Grill fell over and all is ok, but Igniter wont work, changed the battery, connections look ok, but I didnt assemble it. It does light with Match.
Yes, you can match light each burner with a long stick match or a butane match. You'll have to turn each burner on one at a time to do this. But, I'll caution you, do not to hesitate in lighting a burner, as gas will build up quickly and you'll get a big WHOMP when the burner lights.
Apr 15, 2011 | Weber Genesis E-320 Propane Grill
The automatic ignition on my gas grill is not functioning. What's the alternative lighting method. A match?
YES, YOU CAN DO A MATCH.
BEFORE YOU LIGHT IT WITH A MATCH, REMOVE THE TOP GRILL TO
EXPOSE THE BURNER BELOW IT.
THIS WAY THE MATCH WHEN LIT AND THROWN IN WILL NOT GET STUCK IN THE
GRILL AREA WHILE THE GAS IS ON. THEN MORE GAS WILL BE IN THERE
BEFORE YOU GET ANOTHER MATCH LIT TO THROW IN. NEXT THING
YOU KNOW, THE MATCH DROPS DOWN IN BETWEEN THE GRILL AND
FINALLY MAKES THE BURNER AREA AND GOES 'BOOM'!
REMOVING THE TOP GRILL MAKES IT EASY TO TOSS THE MATCH
DOWN BY THE BURNER AFTER A FEW SECONDS WITHOUT A 'BOOM'.
TO FIX YOUR ELECTRONIC START BUTTON ON MOST UNITS, RE-POSITION
THE ARC UNIT IN THE BURNER AREA, TO BE CLOSER TO THE METAL IT ARCS TO.
IT IS MOST LIKELY VIBRATED AWAY FROM IT TO FAR AND THE ARC WILL NOT REACH
METAL OR GROUND TO MAKE AN ARC TO LIGHT THE GAS.
Feb 20, 2011 | Char-Broil Grilling
I have a small propane reddy heater with an electric ignitor if power is out can i manually light it
Yes, you can. Use either a butane grill lighter or a long stick match. Make sure the control knob is in the "light" position and the wick is in the right position. Light the long stick match or butane grill lighter, press the control knob in and while holding it in, touch the flame of the match or butane grill lighter to the wick and the wick should ignite. Once it ignites, quickly remove the match without knocking the tip off into the heater.
Jan 31, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Pilot went out and don't know how to lite it
YES YOU DO NEED MATCHES TO LIGHT THE PILOT IT IT DONT HAVE A AUTO PILOT AND IF IT DOES THEN YOU'LD HEAR IT CLICKING OR TRYING TO LIGHT IF NO CLICK THEN YES MATCHES WILL WORK TO LIGHT THE PILOT
Apr 11, 2009 | Williams 1403622 Gas Compact Heater
When we have a power failure, should the "sparker" still work
I don't believe so. It is usually electric powered. You should be able to light very carefully with a match by lighting the match first and then turning the gas on slowly with the match up close to the burner.
Dec 30, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Grilling Logo
35 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
