Question about Electronics - Others
Can I change a 230V 3ph to 460V on a zd18h220-eo drive?
3 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: range
Yes your oven will work with 3 ph wiring. You need to wire it looking at the back where the wires attach Black, White, Red. Now the red and black can be reversed they both are the hot input that is what makes 240V. also here is an manual if you want to download.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0803193.pdf
Good Luck and Please Rate FixYa!
Posted on Dec 28, 2008
  • 225 Answers
SOURCE: Do I need to change anything to switch my Miller
take side panel off of unit (usually the side that your power leads go into) there is buss bars there along with directions.
Posted on Feb 09, 2010
I have old carrier 50zp060511s Air Conditioners that having voltage details like 3ph 220V 60hz UL Standard But now i have voltage of 400V 3ph & 230V 1ph.. is there any solution for this issue..
If you are reading 400 volts coming into the unit, call electric company. You should only have 220-240 from your power lines. Anything over that will burn out unit. P.S. In my opinion Carrier Units are the best and longest lasting when properly maintained.
May 08, 2016 | Carrier Heating & Cooling
How To Interpret Or Read Nameplate On 3 Phase Motor?
The higher the voltage the lower the amperage, so advantage is its more cost effective to run it at highe voltages since power consumption is I squared x Resistance. The resistance will be the same but the lower the current the less it cost to run it.
Jul 27, 2014 | Baldor 1/2 Hp Motor M3538 1725 Rpm 5/8"...
Change cebora prof 55 plasma cutter from 3ph 4oov to 1ph 230v
Sorry but you can't change a prof 55 3ph to monophase. The 3ph transformer is simetric, but the 1ph prof 55 transformer isn't.
You should change transformer and add a bank of capacitors to compensate the lack of power.
Dec 14, 2013 | Welding Tools
SWITCH NOT TURNING OFF
there is more than likely dust/dirt in the switch and won't allow it to break contact when turned off. I would recommend replacing the switch. BEFORE removing anything make a note of all wiring. Most local repair shops should be able to match the switch up for you. UNPLUG TOOL before attempting any repairs.
Feb 07, 2012 | Jet -JTAS-12XL-3 Tablesaw 5HP/3PH/230V LFR
Need power input wiring diagram for 230V use
you can get the manual here:
http://www.millerwelds.com/service/locate_om.php
Jul 23, 2010 | Miller Electric Manufacturing Electric...
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
Do I need to change anything to switch my Miller Goldstar 452 from 230v to 460v?
Dec 07, 2009 | Welding Tools
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
Voltage problem
Most direct-drive electric compressors can run on a standard 110-volt circuit. When you get into the electric wheelbarrow compressors, you may have a choice for a dual-voltage option, which allows you to switch between 110-volt and 220-volt, depending on power supply that is available for the job. However, for jobs that require substantially more air, usually a 220-volt motor will be your only choice if a gas-powered compressor is not allowed as an option. When looking for a stationary shop compressor, you need to know what power supply you have at your disposal (208v, 230v, or 460v), and whether it is a single-phase or three-phase power. These units are usually hard-wired into the power supply and require a magnetic starter for thermal overload protection
Aug 27, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Electronics - Others Logo
53 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
