Tonite I used the self cleaning mode, it is 15 years old it cleaned and now keeps beeping? I have used it before numerous times why won't it stop beeping as it is done? Thank you very much.
I have never encountered this before.
    Problem Solver:
  • 7 Answers
Call a service guy. He should be able to tell you what to do for free over the phone. Also, almost Everything resets if you turn it off & unplug it!!!
Posted on Nov 27, 2014
  • 27 Answers
Turn off & Unplug the unit it will do a reset
1982 Yamaha Seca Turbo (XJ650LJ) Had the carbs
Mine was stored for 20 years, I ended up replacing the seat and needles, cleaning them thoroughly and when I tried starting it, nothing!! No gas was going to the carbs, it turned out to be my gas pump, it was seized by the old gas remains 'varnish' so I had to clean it numerous times, soaked it in gas cleaner (short period at a time 15 minutes or so, being a very powerful cleaner, you cannot leave it for long without causing greater problems, thus I was able to get the pump going by boosting it with my car batterie, having more cranking amps directly to the pump, the pump was able to release itself from the old crusty varnish.
Aug 29, 2011 | 1982 Yamaha XJ 650
I have a Kenmore Electric - while trying to use the self cleaning instuct.,I can't get the oven to auto lock -it goes to bake and keeps beeping, please help
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Mar 05, 2011 | Ovens
Trying to use self clean feature. get F-9 message and lots of beeping - doesn't stop unless unit is unplugged
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 09, 2010 | Kitchen Ranges
Why is my self cleaning oven not working. I put it on self clean three times and it did not work. It has worked in the past. The oven is about 5 years old.
heatman101
Sep 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
Kitchenaid Range KGRA806PSS Control Panel Not Functioning
You're right about not using the self clean option. Your oven gets up to over 800 degrees when you use that feature. You can choose to simply keep your oven wiped out, rather than self clean it. The timer is most likely going out if the "stop" button doesn't work after cleaning. Please call or email us and we will be sure toget the right part for you. I hope this solves your problem. Ella
Sep 09, 2009 | KitchenAid KGSI901PBS Gas Kitchen Range
Self clean results in f9 and beeping
heatman101
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Frigidaire electric stove keeps beeping
IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
Feb 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Computers & Internet Logo
David Payne
David Payne
