Lay a tarp out and run the unit over a measured area of the tarp then measure the amount of fertilizer.
Do this a couple of times until you get the desired amount.
Add rose water in Renew Collagen Serum sandalwood to establish a paste. Apply this paste evenly in the neck and face and then leave overnight. Now wash facial area with cold water every single day.Looking For Top Level Skin Maintenance Systems?
of course u can it works on all types of hair just make sure your hair dosent get to gressy or it will way it down use a morocan oil that may help if your looking for shine
Below is a list of spreader settings. You may want to call Scotts at 800-543-8873 and verify the product you are using is able to be used in a hand held spreader.
For fine grass seed (blue, rye, fescue) use setting 1
For coarser seed (tall fescue) use setting 2
For light fertilizer (Scotts fertilizers at a regular rate) use setting 3
For heavy fertilizer (Scotts fertilizers at a heavy setting) use setting 4
For pelletized fertilizer and ice melt products use setting 5
According to Michael Reed, MD, professor of dermatology at the NYU School of Medicine, women can use minoxidil but says "the 2 percent solution is way too weak for female pattern hair loss; you really need to use the 5 percent solution to get results." Minoxidil can extend the growth phase and help women keep the hair they have on their heads longer.
I found that one of four feet of scales had the sensor short-circuiting. After padding it with two pencils so that it never gets pressed i get steady readings of right weight from three remaining (and no battery warning and rolling counter)
