We have a Sylvania an trying to hook up the
We have a Sylvania an trying to hook up the playstation3.the tv says format not supported
May not be-- if the TV is several years old
What if anything does the owners manual say?
Post the question under TV category & hope for
someone to tell you why
Posted on Nov 27, 2014
2 Suggested Answers
  • 225 Answers
SOURCE: sylvania tv says format not supported when ps3 is
If it's one of the original PS3's (might be the same for the new) you can hold the power button down when you're powering it up until it beeps and then let go of the power button. This will make the PS3 search for what video devices are plugged in. If you're using the HDMI it will say "An available HDMI device was detected. Do you want to output video and audio using HDMI?", and you wan to say YES. Then it will automatically set the resolution (should set to 1080i) and give you 30 seconds to confirm the video works by saying YES again. This TV will not support a 1080p output so if you try to change the PS3 to 1080p resolution it will not work.
I have also received this message when I had a bad HDMI cable.
Posted on May 21, 2011
How to hook up a ps3 to any TV?
"Any TV" is too big a topic to cover in a few lines.
Try the Sony PS3 FAQ
PlayStation3 Support FAQs Official PlayStation website
Sep 06, 2014 | Televison & Video
Hdmi input not working
Try right-clicking on your desktop while tv is plugged in and select screen resolution, that should open the properties window that will allow you to activate or change resolutions for the tv or detect it. Make sure that the tv is enabled and if necessary choose to extend your desktop to it.
Jan 16, 2014 | Sylvania LC320SS9 32 in. LCD TV
Says format not supported when i hook my pc up to my sylvania lc225ssx tv .how do i format it or get pc to reconize the tv
The PC video card resolution is too high for the TV to display, you need to set the PC to the TV PC mode native resolution, see owner manual.
Please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 22, 2011 | Televison & Video
I am trying to hook up my computer to my lc321ss9 b tv. I hooked it up to the VGA port and it says format not supported?
your screen resolution probably exceeds that of the tv.
try playing with your screen resolution.
May 02, 2011 | Sylvania LC-321SS9 32 in. LCD TV
Yesterday and everytime i plug the monitor cable to the back of my sylvania tv it works but today it says format not supported
you have the refresh rate or the screen resolution set to a size not supported by the tv, change it to 800 x 600 and try it. If it works increase it till you reach the maximum that the tv can show
Apr 12, 2011 | Sylvania LC320SS8 32 in. LCD Television
Not supported format
i had my tv hooked up to my desk top pc then i had to unhook it and use a older monitor then i rehooked the tv back up and it said not support format
Dec 18, 2010 | Sylvania LC320SS8 32 in. LCD Television
Hdmi
You need to lower your video source resolution, it is too high for the TV to display. PS3?
http://s807.photobucket.com/home/budm/allalbums
Jun 18, 2010 | Sylvania LC320SS8 32 in. LCD Television
Trying to hook up HDMI to PS3 and the TV keeps saying not a supported format
Try using another AV cable (like a normal composite cable) and try going through your PS3 setup. It may be that it is trying to go to 1080p or something because it is the HDMI, which wouldn't work on yours I bet. See if you can disable the higher resolutions and try the HDMI again to see if you can get the 720p to work. Hope this helps!
Oct 21, 2009 | Sylvania LC195SL9 19 in. LCD TV
LC32OEM9 says Not Supported Format on HDMI Input. It worked when we first hooked up the TV. Then it started working sporadically now it very very rarely works and when it does it only works for maybe 15...
I'm thinking the Comcast DVR box maybe putting out weird HDMI signals and the TV can't translate it. I would call the Comcast people on this one.
In the meantime, I would try finding another source the uses a HDMI cable to rule out the TV as the problem. Basically, testing the TV to see if the problem still happens when you use something else than the Comcast box. Try a Blueray player, Playstation 3, or Xbox. Just something that uses a HDMI cable.
Apr 30, 2009 | Emerson LC320EM9 32 in. LCD HDTV
Sylvania 42" LC370SS8
Your TV monitor cannot support the format (scan rate) that your computer's display card is putting out. Go in to the computer's set-up for the resolution under the display properties and adjust the settings to support the TV monitor. Refer to the TV's instruction manual to see the supported formats.
When going back to the computer's display, the display format will have to be changed back to have the proper resolution.
TV sets are generaly not as good as dedicated computer monitors for use on computers.
Jerry G.
Apr 18, 2008 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
