Question about Samsung WF448AAP Front Load Washer
Leaking washer I've changed the water valve hose and turned the cold water off and it still leaked.
What leaks exactly?
What should we be guessing at ?
You changed one of the two hoses that feed
water to the washer?
Then turned off the water at the watts valve or
the hot or cold water--why?
No you have no leak until you turn the water back on?
Posted on Nov 27, 2014
Testimonial: "Im waiting on a new cold water valve for my washer that is why I only have the hot water running and I did replace both new hoses they were warn."
Leaking washer, increases when using cold, less when using hot. May be at drain?
Stop the washer and clean up the water. Confirm that the water is not leaking when the washer is off. The leak can occur before the electric valves either where the hose connects or from the electric solenoid valves just inside the washer. The situation is more likely true if the hoses are stressed by being bent to one side.
If dry then confirm if it is the hot or cold by running the machine with the cold service valve open and hot closed.
Jan 06, 2016 | Washing Machines
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Washer is leaking
sounds like you have a hose problem. are the hot and cold water hose connections tight? they may need new washers. if that is the problem turn off water valves,disconnect hoses and replace them with garden hose washers from any hardware store. re-tighten them snugly. just tight enough so they don't leak. if it only leaks while draining, replace the short hoses connected to the pump,located inside bottom of inside of washer.
Sep 16, 2010 | Kenmore 9781 Electric Laundry Center with...
I dont know what the piece is called but it goes on the back of my front load washer and it seperates the hot water from the cold water and its cracked
Are you referring to the water valve assembly? If so, you can purchase a new assembly. Check with a parts distributor. You will need the brand and model number.
Unplug the washer. Turn off the water supply (hot and cold) to the washer and disconnect the hoses at the washer (there is no need to disconnect the hoses at the wall). Make certain that you replace the hoses correctly on the new water valve with corresponding hot and cold hoses coming from the wall. Disconnect the wire harnesses to each temperature (hot and cold) on the water valve. The harnesses should be color-coded. Replace them correctly on the new valve. Turn the water supply back on and plug in the washer. Run a small water level while testing different temperatures (hot, cold and warm). Check for water leaks and proper temperature.
Feb 20, 2010 | Kenmore Washing Machines
No cold water is coming into the tub.
The most common reason would be a blocked inlet screen. Turn off water shut offs behind washer and unhook the cold inlet hose from the back of the washer. Remove the screen from inside where the hose came off of, then replace the screen. Re-attach hose and turn valves back on. Check for leaks. Test washer. If that does not solve the problem, the next most likely cause would be the cold water inlet valve. (The part the inlet hose screws onto)
Sep 17, 2009 | Magic Chef CAV4000AWW Top Load Washer
Water leaking into tub of Maytag la9806
Check the solenoids at the valve. Use a multimeter or ohmmeter to check for continuity. A lack of continuity means a bad solenoid. I'll attach a photo for reference. Hope this helped and best wishes.
Sep 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Water leaking into tub when washer is not in use
Hello, Yes it is the valve leaking, remove 2 screws at the back top of the washer, slide top panel backward and lift, once you have removed the top panel you should see the valve, they are fairly easy to replace. Good luck!! Mike
Aug 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water flows in cold side of water valve and out hot side valve
It seems unlikely that something went wrong just from moving it unless it got banged up!
It sounds like you may have stripped the hot side.
I'm assuming the water is going in the cold side and out the hot side and out the back.
If this is so and you are happy with just cold water try this:
Go to a Plumbing Store and buy a cap for the leaking intake...if it still leaks you can try soldering the two together!
I hope this was helpful.
Good Luck!
Jan 20, 2009 | Maytag PAV2300 Top Load Washer
Hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
May 04, 2007 | Hoover HTC243 Top Load Washer
Samsung WF448AAP Front Load Washer Logo
87 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
