I have a WF448AAP/XAA washer and is leaking from the bottom, what it be?
    Master:
  • 514 Answers
On these machines the draine hose broke and needs to be replaced not to hard the problem is to flip machine so you can see the bottom of the washer
Posted on Nov 27, 2014
    Sergeant:
  • 272 Answers
Could be the bottom seal of the drum, a leaky hose or the pump that discharges the water out of the drum during rinse cycle. If it seems to leak while filling and/ or operating my bet would be the drum seal.
2 Suggested Answers
SOURCE: I have the Samsung WF448AAP/XAA
I have the same problem. Did you manage to get the spring back on???
Posted on Nov 21, 2011
Samsung Washer model WF448AAP/XAA fills up with water but will not start cycle
That could be the lid switch is open or not engaging.
Check the continuity of the lid switch
Mar 07, 2016 | Samsung Washing Machines
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Leaking washer
What leaks exactly?
What should we be guessing at ?
You changed one of the two hoses that feed
water to the washer?
Then turned off the water at the watts valve or
the hot or cold water--why?
No you have no leak until you turn the water back on?
Nov 27, 2014 | Samsung WF448AAP Front Load Washer
I HAVE A LEAK FROM RIGHT BOTTOM OF A SAMSUNG WF448AAP/XXA-000 FROMT LOAD WASHER ONLY HAPPENS DURING RINSE CYLCE
Hello Harlan;
My name is Peter. I am a retired field service appliance technician.
Your drain hose is in the back on the right hand side. This is a rubber hose. After a time the rubber may be dry rotted and leak or become partly clogged with soap residue.
Once completing the wash cycle the soapy water may have not completely drained due to a partly clogged drain hose by the time the rinse cycle is complete flooding the washer drain pan.
You do not have water in the bottom of the washer because your pump removed it all, but at a slower rate
Ok, Lets fix this ourselves:
1.) On the bottom right front of your washed is a leveling leg.
turn the leveling leg one full turn clockwise. The right front may be pitched down, causing the drain pan level on this corner to be high. Your washer through vibration may have moved slightly. This is not going to solve the problem.
2.) Pull your washing machine out so you can see the drain hose. Run some laundry on heavy load. Observe to see if your drain hose is leaking. Your hose clamps may be loose and require tightening. If it is leaking it needs to be replaced.
3.) Even if your drain hose is not leaking it must be obstructed, flooding the bottom of your unit. This is easily replaced.
The part number for your drain hose is DC97-12534D. It cast about $24.00.
Nov 24, 2014 | Samsung Washing Machines
Drain pump continuously running on Samsung Model WF448AAP/XAA
do pull the plug out first
not funny dancing with the machine
have you checked the pressure pipe for any cuts
look near the pressure switch area first
Feb 05, 2014 | Samsung Washing Machines
I have the Samsung WF448AAP/XAA clothes washer. The large retainer ring for the front door seal came off somehow. Its a heavy gauge steel wire loop with a spring assembly integrated into the loop. How...
You need to reinsert the door seal back onto the door frame and replace the spring clamp back on. The spring is fairly heavy duty and it will require some muscle to get it back on. Good luck
Jun 17, 2011 | Samsung WF448AAP Front Load Washer
I have a Samsung WF448AAP/XAA washer. I have had it for a year + and have never cleaned the filter on the bottom of the machine. Tech support told me to clean the filter. Dumb, I know, I just didn't...
There is most likely something stuck in the rubber hose between the drum and the pump, Unfortunately this is not easy to get to as it requires tilting the machine back and climbing underneath to remove the hose and check it. Make sure you disconnect the power before doing this.
May 08, 2017 | Samsung WF448AAP Front Load Washer
Samsung WF448AAP maybe clogged with feathers.
dont put expensive pillows into a washing machine.
Dec 12, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
