Question about Garden
No hydraulics working yet everything was fine the night before
Checked fuses, checked for broken or loose wires , hydraulic oil levels,, it was running fine last nite , but nothing functioning at all this morning......nothing moves ...it must be something simple just cant seem to think of anything else..
    Problem Solver:
  • 11 Answers
My thought also. Does the engine run but hydraulics not work? If engine has a starter, check the battery and battery connections.
Need more information in detail.
Posted on Nov 27, 2014
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
  • 370 Answers
SOURCE: All hidraulics funtions are dead, no hydraulic power in machine.
first thing I would do is test the pump itself even if no wear is found you could have a GPM loss.
So you need to do a flow test on it to find otu how much the loss is and check it to the specs of that hydrolic pump first.
Posted on May 14, 2010
  • 251 Answers
SOURCE: ALLIS CHALMERS 190 GAS -HYDRAULICS ON TRACTOR ARE
hi , replace your hydraulic oil filter and pump and renew the oil .
hope this helps
Posted on Jun 21, 2010
heatman101
  • 43501 Answers
SOURCE: 4020 john deere compact diesel. Lost hydraulics
I doubt that it is the fluid level...it's been a few years... but I seem to remember there being a couple at the front of the motor that ran the hydralic pump...I am wondering if your problem is not there...tthe hydralic pump sits under the fuel tank at the front of the tractor... check there to see if everything is working right there...of course it could be the pump its self that has gone bad...
heatman101
Posted on Aug 24, 2010
Hydraulic light on the dash 6420 john deere is on why?
accord to my books on this this tractor is a big 4wd tractor , it has hydraulic everything , drive-steering-lifting so if you loose hydraulic pressure then yes it's gonna shut off for safety reasons , need to resolve hyd problem , could be out of oil or hose broken or pump bad it's gonna be one or more of them reasons
Mar 05, 2015 | John Deere Garden
Troubleshooting nissan
if it is hydraulically operated then check the oil level as there is air in the system. if it is motor driven then check for dry joints and slides and loose connections in the wiring
Jul 14, 2014 | 2006 Nissan Micra 1.4
What are some things to check when the hydraulic jacks will not come down on 2014 Thor Challenger?
You did not specify if your hydraulic motor would run or not..
did they work last week?
what kind of jack system?
you need power to control panel to send power to relays on hydraulic pump.
If pump is running when button switched. Then perhaps loose wire or defective valve.
if pump is running and oil sprays all over then you have a bad hose.
need more info
Jul 05, 2014 | RVs
Hydraulic failure
Check out your Ferguson Tractors Information Headquarters, sponsored by Ferguson Enthusiasts of North America (FENA) at www.fergusontractors.org
Feb 15, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
PtO will not engage on cub cadet 1000
It would be helpful if I knew whether it was working and quit or has never worked. At any rate it has of course a live PTO on it (not dependent on the clutch to engage-disengage it). Check your linkage, make sure nothing has come loose and not moving the travel rod. Secondly some models have a hydraulic fluid compartment that is used for the PTO alone, check to see if this is the case and if so check fluid levels. Back to linkage, the engage mechanism is usually a lever of some type that moves a valve body and lets hydraulic flow under extreme and engage s set of input and output clutches together. If your engage mechanism is a magnetic clutch, check for bad wiring and burnt fuses. If it is a fuse replace with the same value as already in the harness. If the new fuse flows don't do like me and put a larger fuse in it, though that will show what wires are involved with the clutch engagement it also shows the wires to be replaced. Check wiring for ***** wires or wires worn and touching metal parts and grounding out.Back to Hydraulics again, unless you've loaded the PTO hard enough to burn the clutches out (which I doubt very much) it can only be that fluid is not getting to the clutches. Chances that there is a problem inside the tractor with the valve body are slim but possible. Most PTO that just quit are caused by linkage problems or low Hydraulic fluid. Check all the above, I believe you will find your problem lies somewhere in what I have explained. I farmed for 30 years and we ran from 140 -250 HP tractors and if a PTO went out it was usually linkage or low Hydraulic Fluid. Hope this helps, don't want to miss a crop over a PTO!Col. Dana Gillespie TSM
Apr 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Won't pull itself up hill
You didn't indicate what model of tractor you have but most likely it is a hydrostatic drive problem . The power is transfered from the engine to the wheels by hydraulic pressure. If the fluid level (hydraulic oil) is low then it won't drive correctly. Follow the owners manual to check the fluid level. The other possibility is if this is an older unit it could actually have water in the oil.The water will not operate correctly. Where did the water come from? The transmission housing, is vented to atmosphere. On a hot humid day, while you're driving, the fluid and housing is heated. When the tractor cools, the ambient humid air enters the housing. When night rolls aroound the water condensing inside the housing. If you're lucky this transaxle may have a drain plug in the bottom. You can remove this and see if the oil looks milky. If it does, I'd drain it all and refill with fresh oil.
Jul 18, 2010 | Husqvarna 24HP 54" Yard Tractor ()
When loading or unloading with the Toyota Forklift it tilts without me touching the controls - it is a Toyota model 027FD25 , any suggestions why this is happening?
my past experiences with hydraulic equipment leads me to believe the valve that operates the tilt feature needs to be either rebuilt or replaced. It probably has a bad seal or O-ring in it that is allowing the hydraulic oil to pass causing the tilt to tilt. Follow the bar, or cable, from the tilt lever to the valve and that is the one to work on.
Oct 31, 2009 | Water Heaters
Audi A4 1.9 TDI power steering oil type and capacity
Power steering fluid level checking:
- vehicle stationary
- front wheels in straight ahead position
- engine at normal operating temperature
- remove cap with dipstick from expansion tank and wipe off
- reinstall cap with dipstick and remove again
- fluid level between "min" and "max" markings
- top off with G 002 000 hydraulic oil if necessary
Power steering system capacity is around 1 liter, but it is not necessary to periodic change the hydraulic oil!
If oil level has dropped to the "min" marking, check power steering system, including hoses and lines.
It is not enough simply to top off the hydraulic oil !!!
Oct 02, 2009 | 2003 Audi A4 Cabriolet
19886 saab 900 convertible roof not working.
Hi David:
First, check the fuses for the hydraulic motor; if they're blown, replace and monitor (why did they blow? Perhaps an overload, or ...) These fuses are located in the engine bay on top of the fender by the front right wheel housing.
Next check the voltage supply to the top switch, possibly a loose connection or broken wire.
Also check relays C (raising top) and D (lowering top) under the rear seat.
Lastly check for voltage at the pump, also under the rear seat, when the switch is actuated, and that the voltage polarity reverses when the switch is actuated the other way (up or down).
After that, it's a hydraulic/mechanical problem. Check the fluid level in the pump reservoir (use SAAB fluid to top up if low) Fluid level should be at the upper marker with top down, and at the lower marker with top up.
Check behind the rear seat side panels that the piston shaft is still properly attached to the roof mechanism bracket at one end, and the piston itself is still firmly attached to the body. Look for any leakage from the system.
If all tests out OK and looks good under the rear seat and behind the side panels, then there is the possibility that the piston seals have failed and the fluid is just circulating around without activating the piston. Pistons are available (http://www.convertibletopguys.com/cgi-local/displaycat.cgi?cat=584 - scroll down) but the entire system should be removed to avoid getting hydraulic fluid on the interior.
However, that fact that you can operate the hood using the bypass valve (manually) would indicate that the hydraulics are likely OK, and that it's probably an electrical or mechanical problem.
Saabreur
Jun 09, 2009 | 1998 Saab 900
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
