Question about Sewing Machines
My Quattro 3 innov-is 6750D needle bar keeps freezing up
Well not sew ,needle bar well not move.
    Problem Solver:
  • 8 Answers
Make sure the machine is lubricated properly with oil, you will need to take some covers off to access inside components. Also, make sure the thread is fed properly through each loop, and the tensioner isn't too tight.
Posted on Nov 27, 2014
  • 3 Answers
SOURCE: I have a Euro-Pro 473 model sewing machine, I?m
If you're having the same problem we did, the attachment is installed too high on the bar. Move it down as far as possible and see if that solves the problem. If it doesn't, check to see whether the machine is belt-driven; did the belt break or slip off?
Posted on Oct 01, 2009
SOURCE: I have a singer confidence
Hello Renee,
Please visit the link provided below :
http://www.sunsewvac.com/documents/Confidence7469.pdf
Look for needle position in pdf document.
Adjust the needle in its correct position and then try.
Posted on Apr 26, 2011
SOURCE: Sewing machine handwheel turns and whirrs but needle bar stuck?
my suggestion is that the machine needs to be serviced at a sewing machine shop, because for 1.it's not responding 2. it used & you don't know when the last time it was serviced 3.something is wrong with the machine.
hopefully there are no broken parts, but having the machine serviced will tell that.
as for a manual
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w510 ) & click search
Posted on Mar 19, 2012
SOURCE: My Singer 5050 sewing machine won't let me
sounds like a part is damaged or jamed, the machine needs to be checked
to see what's wrong with it
Posted on Apr 16, 2012
SOURCE: how do I replace the wire that threads the needle on my brother sewing machine
it would probably be a good idea to take the machine to a sewing machine shop to have the needle threader fixed
Posted on May 22, 2012
Tip
Timing A Mechanical Sewing Machine
If the thread is not being picked up by the hook, you can set your timing by moving the needle bar height. move the hook so it is in the nearest position to the needle, but not touching. Remove the left, needle bar cover. You'll see a screw, or set screw on the needle bar. Slowly loosen it, and move the needle bar up or down until the hook lines up with the scarf on the back of the needle. The tip of the hook should be in the middle of the scarf, above the eye. Hold still, and re-tighten the screw.
on Mar 05, 2015 | Sewing Machines
Needle bar frozen
Rather suspect the bar has bent, remove it and check for true
Dec 18, 2013 | Brother SE400 Computerized Sewing Machine
The long metal bar that the needle holder is attached to keeps dropping down and is very loose
If when the needle bar drops down the take up lever moves as well you need to open the face plate and tighten the screw on the take up lever
Oct 08, 2013 | Feiyue FY100 Computerized Sewing Machine
How to retime a brother 900d sewing machine
Breaking threads isn't necessarily a timing problem. Check for burrs.
Nov 11, 2012 | Brother Innov-Is 900 Sewing Machine
Thread keeps knooting up
is the bobbin threaded correctly ?
is the bobbin warped?
try rethreading the machine top & bobbin
change the needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check to make sure every thread guide is used
Jun 11, 2012 | Brother Sewing Machines
How do I replace the wire that threads the needle on my brother sewing machine
May 21, 2012 | Brother Sewing Machines
The wire for threading the needle has broken how to replace it
a sewing machine shop can replace it easy for you.
or try the sewingpartsonline.com & see if they have the part
Remove sewing maqchine case
Plate on bottom: Remove screws. Keep screws in safe place and oil moving parts with good quality sewing machine oil. Zoom with spout for sewing machines & servers is what I use purchased online...lubricate gears with Singer lubricant (in tube). Tip machine back onto a towel to remove screws. Just one drop oil on moving parts & dot of lube gear only if not showing signs of grease already. Please remove bobbin and presser foot before cleaning/oiling. One drop oil then generously SMEAR oil on oscillating hook, open right front door & one drop top of needle bar. Clean out race shuttle for lint, fuzz balls, broken threads with soft sewing machine brush & clean your feed dogs gently with bristles too. Hope this helps. Do not clean machine near children or curious pets! I run my machine with pedal on table top so I don't accidentally step on it. Control with right hand to see moving parts. At your own risk, of course. Safe and effective but only if you are extremely careful. Replace all screws securely. Put in new needle all the way UP into needle bar groove, presser foot UP turning handwheel towards you, flat end of needle to back, Thread Front to Back of needle.. Keeping presser foot raised @ highest position ensures thread locates the tension slots properly. Jimmy
Apr 07, 2012 | Singer Sewing Machines
Oiling XL-5700
You oil this machine anyplace that it moves and rubs. Needle bar, joints that drive the needle bar,end of each shaft, presser foot bar,hook race etc. Do not use 3 in 1 oil. Use a good quality sewing machine oil.
sewman7
Sep 01, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
