Question about British Telecom Contour 50 Corded Phone (212796)
Trouble dialling out - swamped by 'please insert coins on answer' message
Hi - I've got a BT Contour 50 Payphone and as I dial, after 3 or 4 digits the message 'please insert coins on answer' appears in the display, preventing the dialling of the rest of the phone number. 100 and 999 dial ok, though. Phone's been reset several times, same result. Any ideas or is it a software glitch and the phone's toast?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
Inform the network provider
someone has hacked in and using to make free calls
let the network providers reset ontheir system
Posted on Nov 27, 2014
Our KX-T7630 seems to delay a few days before sending individual message bank messages through to individual handsets. How can this be? I arrive at the Office, take 2 or 3 messages off, the phone...
Hi
When your red light is on with the handest down presss the message key. this will tell you where the message has come from. I expect you will see that an internal extension has dialled you by mistake. It is a message waiting function on the system for user to call back on. Nothing to worry about. To clear the light you have 2 options either press the clear button on the display for each message or dial *700(then your extension number)
Speak Soon
Phil
Oct 28, 2012 | Panasonic KX-T7630 Corded Phone
How easy is it to to replace battery in a Contour 50 payphone? One site says the soldering will blow the chips. Terry
HI,
I have just replaced the battery on a similar phone today (not a BT one, but a "Payphone Link 20", its belgian counterpart).
It was a bit tricky as the battery is soldered on both sides of the circuit board, but the battery was replaced in a matter of minutes and the phone works fine now.
I wouldn't recommend this to the novice however. You need good soldering skills + equipment, and basic knowledge of how to handle a circuit board without damaging it (i.e. short circuit or electro-static discharge).
If you're not sure, I would advise you to get it done by someone familiar with electronics repair. Otherwise there are several companies that could fix it for you : you send them the front of the phone by mail, they replace the battery, clean and check the phone, and send it back to you.
Jul 28, 2011 | British Telecom Contour 50 Corded Phone...
Motorola D810 Digital Cordless Phone with answering machine. One phone dials out normally from memory other phone dials out and gives message back "the no. you have dialled has not been...
hi friend,
it's not a battery problem.but, when you go for dialing. you put your country code before the no........like.....+91.....then...number....789876838......it look like.....+91789876838......it will help you.
Regards:
Rakesh
Jan 29, 2011 | Motorola Lands Phones
Phone receiver not working
Is this a replica or a real payphone? Will the transmitter cap unscrew?
A couple of things to try, is take out the transmitter, hold it in the palm of your hand (with the holes in your palm) and slap the assembly on a hard surface. That unpacks the carbon granules.
If that doesn't work, it also may be that a relay is operating because it is want is called a Postpay payphone. Try reversing the Tip and Ring (green and red) line connections and test it again.
Finally, a genuine "g" handset transmitter capsule is about $3, making it cost more to ship than buy. Your picture shows a non "armored" handset cord. If that's really the truth, is the handset black and non-modular? And how does it fit into the payphone housling?
Please don't rate this until you have answers....
Mar 28, 2010 | Crosley 1950 Pay Phone
Fitting a new battery to a bt contour payphone
I have a bt contour 100 that had the same problem no dial tone and nothing on the screen this is easily fixed by soldering in a new battery or soldering in a battery holder / battery back that takes 3 aaa batteries in place of the old battery you may have to solder two separate wires into the positive side and one wire into the neutral side after the old battery has been removed once you have soldered two wires into the positive thoes two wires need to be connected to the positive side of the battery holder and the other single wire into the neutral side of the battery holder once done correctly when you have inserted 3 AAA batteries and reset the payphone it will start working again bare in mind when you reset the payphone the pin number will go back to its default setting you may have to contact bt payphone help desk to get the default pin if you don't already have it there is a company offering to convert the bt contour payphone to run on regular alkaline batteries which are easily replaced but getting it professionally converted would come at a cost you can easily do it yourself giving some basic knowledge of electrical wiring and some common sense. The payphone runs on a 3v dc lithium battery that costs £9.99 on some sites on the Internet I believe that you can also get it to work on a 3v DC adapter but I have not tested or tried running my payphone on a power adapter as converting it to run on aaa batteries is easier and quicker to replace
Nov 03, 2009 | Lands Phones
Bt contour 50 phone is completely dead. no display, dial tone. replaced cords Done all resets that manual say. not sure of water damage, but circuits and box all dry
Yeah, the internal battery is probably exhausted. You can replace it with a new one, which you can get on eBay, but you probably need to know how to solder it in
Jul 15, 2009 | British Telecom Contour 50 Corded Phone...
My BT Verve 450 digital phone set won't ring out /incoming call
bt cordless phone i have pressed something and it has locked can anyone tell me how to unlock it
Dec 08, 2008 | Uniden Cordless Phone
Hi, Ive got a BT Contour 100 Payphone, but there is no dial tone or display. Cheers
You need to dismantle phone and replace Varta CR1/2AA 3Volt lithium battery. Dismantling is easy enough but you MUST lay out the screws etc so they go back in the right place, particularly the one with the two nylon washers underneath the head.
Apr 23, 2008 | Lands Phones
Fax nightmare!!!
If you have a BT line and use the 1571 answering facility , when you have a message waiting the dialling tone changes from a constant tone to a split tone. This is to let you know that you have one or more messages waiting.
In order to get the dialling tone to revert to the constant tone you have to deal with the waiting messages in accordance with the options provided i.e Save, Listen Again or Delete. BT say the Split Tone is to let subscribers know when they have a message waiting. This should resolve the Fax problem.
It certainly worked for my phone/fax system.
Good Luck
Geowilmil
Nov 28, 2007 | Pitney Bowes 9920 Plain Paper Fax
British Telecom Contour 50 Corded Phone (212796) Logo
61 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
