Question about Refrigerators
Need wiring diagram for kelvi n520f Confused with 2pink wires at Dtt/def heater conect
    Novelist:
  • 166 Answers
It's been a while but if I remember correctly on the inside cover shield or on the back of the unit- there should be a schematic/diagram- sometimes there's a sheet or manual tucked inside the compressor area. but I'll say this it would be very very unusual that if the wires are the same color that they would be different from each other - they normally tie them together at one area then send them out to two different area(components)
Posted on Nov 27, 2014
Testimonial: "Thanks Dave I have a red wire [from the timer def terminal]2pink wires[1female spade 1male]and a blue nuetral[one side of heater]"
Tryin to conect 10-2 wire where does the black and white wire go.myou manuel does not explain it very well. Heater model #cz220
10-2 is for 220. White is neutral and black is power. You'll have to run a 10 gauge wire to the heater from your panel. Probably a good idea to hire an electrician as you make need to have a breaker added to your panel...could check/install if you need a wall thermostat. 220 is dangerous....
Mar 01, 2015 | Heating & Cooling
I have a 3yr old samsung fridge/freezer srl324np. this morning i woke to find the digital door display flashing, and the inside of the fridge was warm, however the interior light was still working. i've...
It sounds like a temperature sensor problem. On my RF265AABP model there is a control board located under a cover on the back of the refrigerator. There is a wiring diagram on that cover. Remove the cover if you have one, and locate the control board and power supply boards. If you have a voltmeter, check for +5V and +12V (on my model anyway) from the power supply board. If that is OK, then check the voltages on the temperature sensor wires. Mine are at the bottom of the board as shown in the photo. I have 5 temperature sensors, refrigerator (R), freezer (F), refrigerator defrost (R-DEF), freezer defrost (F-DEF), and Pantry (a temperature controlled drawer in the refrigerator). You may need to refer to your specific diagram to get the colors of wires, but it appears that the voltages should be somewhere between about 2 to 4 volts from each sensor to ground. I had a broken ice maker wire that resulted in a high reading, about 4.3 volts on the freezer sensor, so I assume high reading indicate an open sensor, and low reading indicate a shorted sensor. I am not sure where the refrigerator sensor is located. Repairing the broken wire restored the display to normal readings.
On my model the left gray wire is common, and the diagram should indicate color and a letter or so (R, F, R-DEF, F-DEF, Pantry) on my model.
Sep 12, 2013 | Samsung Refrigerators
Wiring diagram for electricmotor with capacitor
On most motors the wires with the tabs are connected to the capacitor (usually brown). White wire is neutral and color wires are speeds.
May 09, 2010 | Heating & Cooling
I do not have a diagram for you, but depending on the motor, I can tell you a couple of things. 1. All capacitors are wired in series with the start winding. Most multi-speed motors, that require capacitors, have two brown leads, along with the motor winding leads. If this is the scenario, then just connect line power to neutral and the speed you wish to use, and connect the two brown leads, one to each side of the capacitor. Hope this helps.
Apr 01, 2010 | Heating & Cooling
Need wirinkg diagram for rgmc-100c to conect trans former and thermostat
Can you read the wiring diagram located on the inside panel on the furnace?
Dec 21, 2009 | Heating & Cooling
Confused about wiring a tach on my '05 Kawasaki Vulcan 1500
go to gadgets fix it page, they have diagrams and step by step instructions to do this, i use his site religiously you can find anything there about your vulcan
Apr 21, 2009 | 2004 kawasaki VN 1500 Vulcan Classic...
Reinstall capacitor 370 vac from a/c
Here is the standard connection of dual capacitor. Actually you can see the diagram on the unit but Im not familiar with the Intertherm model. What can I give to you is only the standard connection of dual capacitor.
Feb 26, 2008 | Heating & Cooling
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
