I have a Mitsubishi Wd65638. The picture stopped working and would not turn on. I replaced the lamp, and now it comes on, starts out working right, then begins to flicker and then eventually turns off with a solid red LED light in place of the green that symbolizes that it's on. How do I fix my TV?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Check your power supply, it sounds like you have a bad cappacitor
Posted on Nov 26, 2014
  • Theo Long
    Theo Long Nov 26, 2014
    I don't think it's the power supply. The sound does not change. Only the picture changes, and it's not the only electronic run off of this circuit. Thank you though.
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
I have a Mitsubishi WD65738. The picture stopped working and still had sound. I replaced the lamp and cartridge and now it doesn't turn on and i just get a flashing yellow light. What can I do?
If you replace the lamp you need and got sound no picture is your color wheel. Make sure the cover wherew the lamp goes is close completly other wise it would not work.
Thank you
Nov 22, 2013 | Mitsubishi WD-65738 Medallion 65 3D DLP...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Air flow problem
Pull Lamp Out and see if when you try to turn it on if the Ballast Board has a spark/arking noise coming from it? If So Replace the Lamp.
Jan 14, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi w52525 - replaced lamp and red light still on
could be the wrong lamp or not set right in housing or bad door switch.
May 03, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP - model #WD62725
We're under a service plan and had the guy out today. Same symptoms. He replaced the lamp and it didn't work and then called Mitsubishi. They said it is probably a very common capacitor problem on the power supply board. If you open the back and take a look you are likely to see bulging caps. Parts C9A37 and C9A38. The caps are cheap if you can find them, but the parts are really hard to find right now so Best Buy is actually replacing these for people under service plans rather than fixing them. You probably ignored the "warning signs" like we did and didn't think much of it when the TV said there was something blocking the air flow and the lamp was going to shut off. We now know this is a sign that the caps are getting too hot and need to shut down to cool off... Good luck! BTW, our guy said the repair will run you about $200 if you can't do it yourself.
Aug 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Dec 10, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
Electro Med Services...
