Question about Electrolux Kitchen Ranges
While boiling water spilled over on stove top suddenly a beeping noise from electrolux double oven slide in model ew30es6cgs7 shut off
Model double oven slide in model ew30es6cgs7 now will not restart
Repost under the correct category & hope someones cares to answer
Posted on Nov 26, 2014
catriver
  • 878 Answers
SOURCE: Spill into oven vents
The best way to clean the inner glass is to remove the door from the oven. With the door in the broil open position (first stop) pull up for about 2 inches until the hinge brackets are released from their stops. Close the door all you can and lift the door off the hinges. Lay the door on a padded surface and remove the 4 screws on the bottom. The outside glass will now slide out of its rail and you can clean the inside. To install just reverse the process. If you take your time and observe, it's not that bad of a job...Catriver..post back.
Posted on Nov 26, 2006
fridgetech
  • 473 Answers
SOURCE: oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Posted on Nov 23, 2007
  • 1314 Answers
SOURCE: Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Posted on Jan 19, 2008
SOURCE: GE Profile Spectra XL44 oven wouldn't light, stove top and broiler works
We have our second GE stove and it has started to do the same as the rest of you.  Our first stove began to suffer igniter issues after 4 or 5 years.  I called GE and was given a simple test procedure for the igniter using a multimeter that I don't remember and likely wouldn't post regardless lest someone do things incorrectly... In any event, as I understand, the gas flow is tied to the igniter temp.  As the igniter ages, the temp that it can achieve gets lower. Eventually, it hits a point where the temperature isn't sufficient to reliably ignite the gas and our problems start.  The solution is fairly simple.  Replace the igniter. So, call a repair person and tell them the problem.  They can come out and instal the new igniter.  Unless you are a licensed or certified repair person, DO NOT DO THIS YOURSELF.  Let the pros handle repair to gas appliances.
Posted on Jun 15, 2008
SOURCE: Can't Unlock oven doors after "self-Clean" maytag double oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
Posted on Dec 22, 2008
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
Why do I get E 21 message on my Electrolux slide in range Model EW301S6CjSc which has frozen the stove top
Thank you for your post, Sandra Gee!
Based off the information you have provided an "E21" error code is displaying on your Electrolux range. Typically, an "E21" stands for a communication failure between the EOC (Electronic Oven Control) and the ESEC (Electronic Surface Element Control). I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. The best way to disconnect power is to flip the household circuit breaker. If you continue to have an issue with an "E21" error code I would have a professional technician perform a diagnosis on your range to help repair it properly. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux Kitchen Ranges
My stove top does not respond to the touch
Good Morning Kenneth Kozoway, thank you for your inquiry!
I see that you have explained the stove top on your Electrolux range is not responding to touch and the oven controls are working properly. From what you have described it sounds like a possible issue with your control panel or sensor. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. If that does not help correct the issue I would recommend having a professional technician come and perform a proper diagnosis for repair. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux 30" Self-Cleaning Slide-In...
Samsung Microwave Oven Model smh918713 beeping
You may need to replace the keypad. I found there was moisture causing the problem when we boiled water on the right side of our stove which is under the keypad. I let the microwave dry out for several days and now only use the left side of stove when we boil water and have not had the problem.
Oct 19, 2012 | Samsung Microwave Ovens
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Getting error F1 on digital display
F1 Board failure Replace control board (also called ERC or clock).
Mar 20, 2009 | Ovens
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Aug 09, 2007 | Frigidaire FES367 Electric Kitchen Range
Kitchen Ranges Logo
119 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
