Question about Garden
I need help starting an almost new snow blower. I bought in December of 2013 and can't get it started for the first time this year.
Following the owners manual trying to electric start. Engine turns over fine, but engine won't catch
    Problem Solver:
  • 5 Answers
I GENERALLY DRAIN THE SEDIMENT BOWL OF OLD GAS AND CAN THEN ALSO ENSURE THAT GASOLINE IS GETTING THROUGH THE NEEDLE VALVE CONTROLLED BY THE FLOAT. (OFTEN THAT GETS PLUGGED) CHECK FOR A WET SPARK PLUG, IN CASE THE CYLINDER HAS BEEN FLOODED BY TOO MUCH GAS. IF NOT FLOODED, PUT A TEA SPOON OF GASOLINE DIRECTLY INTO THE CYLINDER. REPLACE PLUG, AND ATTEMPT TO START. IT SHOULD AT LEAST RUN TILL THE GAS IN CYLINDER IS BURNED UP. IF NOT, LET ME KNOW, AND WE CAN GO FROM THERE.
Posted on Nov 26, 2014
You may have to take the carb off & take it
apart & clean it
Gas gets dried up in the jets
Needed to have that running in Oct -- so you were ready
If you leave any fuel in it or the carb--- run it every 6 weeks
year round or you got what you have
If the carb was clean-- it should start on the second or third
pull, even if it sat for 8 months with old fuel
Only use fresh fuel in power equipment & stabil
Fuel lasts 30 days only in anything
Clean the spark plug electrodes with an exacto knife
    Problem Solver:
  • 7 Answers
I would make sure that there is new fuel in the tank. Most of the time the fuel in the tank goes stale. Ethanol that is used in gasoline now loses it potency over time and will not burn correctly. Evacuate old gas and put some fresh gas in the tank and try again. Place to start anyways.
  • 417 Answers
SOURCE: will not start
Actually, first you always check to see if there is adequate good condition oil. Then gas, then crank it a few seconds and pull the plug I see if its wet from fuel. If so, disconnect the ground wire from the coil(s) and try to start it. If it starts then try and find where the wires are grounding
Posted on Nov 21, 2013
  • 5 Answers
SOURCE: electric start doesnt seem to catch and turnover
bad starter. while cranking tap the strater litely witha hammer
Posted on Dec 25, 2008
SOURCE: Trouble starting Craftsman Lawn Tractor Mod# 917-272350
It is time to rebuild your carburetor paying special attention to the float and seat.
Gasket set is about $30 delivered and gallon can of gunk carb cleaner with a parts basket is $21 at kragen auto parts. takes about two to three hours. Or you can but a new carb for about $150.
Posted on Jan 29, 2009
SOURCE: Surging tecumseh engine on snow blower
Hi, You have gum or old gas in the main jet on the carb, turn your fuel off, stand the snowblower on the front blower housing with handles in the air, remove main jet from the bottom of the carb and clean. Jim
Posted on Feb 01, 2009
bbreton
  • 437 Answers
SOURCE: Electric start turns over, but engine doesn't
If gas has been sitting in the carburetor since last season, The carburetor will need to be cleaned out and rebuilt. Some ports may be clogged up that allow gas to flow.
HTH
Good Day.
Posted on Oct 30, 2009
Snow blower starts than it dies out I changed the spark plug new gas don't know whats the problem
I suspect the carburetor needs cleaning. Gas nowadays is terrible on equipment that sits for long periods of time (like a snow blower) without being used. The gas nowadays goes stale very quickly and gums up the carburetor. To prevent these issues use a gas stabilizer. I have stabilizer in all my jerry cans of gas. That way everything I fill up is ready to be stored at any time.
I'll give you an example of how bad the gas is.... My neighbour bought a new lawn mower. Selling feature of the mower was "guaranteed to start first or second pull". The next year it wasn't starting properly so he took it back. He was told he didn't store the mower properly over the winter (He didn't use a gas stabilizer) so no warranty. Took the carb apart and cleaned it ran like a champ....
Jan 29, 2016 | Toro Power Clear 621 R
Lost my manual for toro 418ze snow blower. cant remember how to start it
The gas is bad. You have to add preservatives to it before you store it. Now you need to drain the sour gas and put in new gas. Then try to start it again.
Feb 06, 2015 | Toro Power Clear 418ZE - 38282
I have a Craftsman Snow Thrower model # 247.881731. At the end of last year I drained the gas as recommended in the manual, this year I filled it with fresh gas and it now has a problem starting. I pu
Draining the gas from the tank doesn't drain the float bowl in the carburetor. It still had last year's gas in it. Gas will start to turn to varnish if left sitting 6 to 12 months. You'll probably have to remove the carburetor, disassemble it and clean it out with Gumout carb cleaner or some similar product.
When you get it running and the snow's over and done with, put some Stabil in the gas tank to prevent the gas from converting to varnish and then start it up and run it until that stabilized gas is through the carburetor and into the engine. You can leave it with the treated gas in the tank.
Feb 01, 2015 | Craftsman Snow Blower 26 In. 208CC...
Is the spark plug on my new snow blower already set to the .30 gap at delivery?
It,s already set to specs when u buy it u need to call The service center or store where was bought...being new u should not do anything to some thing new and still under warranty
Nov 10, 2014 | Craftsman 21" 179cc* Single Stage...
Will a 42 inch troy built 2 stage snow blower fit a 2013 troy built poney
howdie what are ya changein ?the blower the motor need more lmfo please or measure the parts line them up look at them you Deside what it looks like I can,t see it so tell me more thks for your time
Oct 06, 2014 | Garden
Why does my weedeater start then it just stops running
sounds like the diaphragms in your carb need replacing. and clean your carb at the same time
Jun 05, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Snow blower will not start
sheer pin on flywheel sheered off pull flywheel and replace sheer key
Feb 23, 2014 | Troy Garden
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Blowing white smoke
use a good gas additive and non ethynol gas
should clear it up
Dec 07, 2013 | Cub Cadet Snow Blowers. 26 in. Two-Stage...
Snow blower wont start
carb is probably gummed up from old fuel..take it off then clean it good and i bet it fires up
Feb 05, 2010 | RTO Sno Wovel wheeled snow shovel
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
