Question about Daewoo KOC-925T Microwave Oven
Smoke coming from under oven
Smokes and trips breaker
  • 75 Answers
You need a new microwave or you need an appliance repairman. Usually smoke in an electronic product means that there is a short in the wiring or overheating circuit board. If it is still under warranty take it back where you got it.
Posted on Nov 26, 2014
My Trager set on smoke and it reaches smoke temperature. The fuse is ok the control seems ok, circuit breaker has popped 3 separate outlets
Does the fan and the auger both work? There is a short somewhere. If those are GFI circuits it is tripping, it could be just a little dirty (greasy) at one of the connections.
Oct 13, 2017 | Microwave Ovens
I have a neff B6774N0GB combi oven. Activated the hot air button and it has tripped the circuit breaker. Fan element examined and looks perfect. Oven is isolated from other appliances
The hot air function uses a great deal more current than the other functions. Check the tag on the oven for current requirements, and check the rating of the circuit breaker in use. If the breaker is rated lower than the ovens rated maximum current draw, it will trip under the load. If the rating of the breaker is above the ovens maximum current draw, and there is nothing else plugged into that circuit, the breaker may need replacement.
Sep 14, 2016 | Neff Microwave Ovens
My advice would be to scrap the oven. Smoke is never a good sign, Even if the smoke is coming from a food scrap or cockroach trapped in the turntable motor, opening up a Microwave oven is extremely dangerous. The oven has high power capacitors inside which when charged, will deliver a dangerous and painful electric shock EVEN IF DISCONNECTED FROM THE WALL POWER POINT. These capacitors will hold their charge for days and they can be lethal. The power supply inside a microwave oven is also capable of supplying more then enough power to KILL !!!!
As the oven is tripping the breaker, replace the oven. It really is not worth attempting to repair one of these appliances unless you have extensive professional training and have access to the correct tools and equipment. Don't mess with it, replace it.
Nov 26, 2014 | Microwave Ovens
Freestanding stove (range) keeps tripping breaker when oven is used or two burners are used
Is this a new installation?? It sounds like the circuit breaker is under rated for this unit.
Nov 03, 2013 | Panasonic NN-H965 Microwave Oven
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
Purchased G.e. JES2051 microwave May 3rd, 2010. When I press start, it trips the ciracuit breaker every time. I had the braekr changed and it would still trip the breaker--every time. I have moved the...
Verify the manual or the sticker in the back, check for the electrical rating (AMPERS) 15 for a house appliance and 20 for commercial type oven, if your electric system meets the ratings then (if it is still under warranty), go to the store have it replaced, with all the tests you did, it is definitely defective.
Jan 12, 2011 | GE JES2051 Microwave Oven
My microwave oven keeps tripping the circuit breaker.i replaced the outlet that it plugs into but it still trips it. is there an internal fuse in the oven that may be bad?
If a fuse inside had blown, that would definitely reduce the current flow rather than trip the breaker.
I have replaced several breakers over the years; they no longer last forever.
Try your Amana on a different circuit, not in the kitchen; if that other circuit likes the oven, the breaker is bad. If the alternate circuit breaker also trips, then you have not a blown fuse in the Amana but rather a shorted component inside and repairing the oven will likely cost about the same as replacing it.
Nov 22, 2009 | Amana Radarange Microwave Oven
Powers on will not work
Check the breaker . A microwave oven should have a dedicated circuit plug a lamp in the oven plug in if it comes on you have another problem if it wont come on flip the breaker they can trip just enough that you cant see it is tripped flip it all the way off then flip it back on again see if it works. You might have to do this a few times even if light clock comes on it might be tripped just enough to not let enough power come through use a multi meter if you have one to check the current.
Oct 10, 2009 | Emerson Microwave Ovens
Roper Microwave (mhe14xmq dec. 2003) trips breaker...
you might have to reset your your power settings on the micro.
Sep 21, 2008 | Roper MHE14XKB Microwave Oven
Micro not working
No most likely the little angel didn't ruin it. Remove the cabinet and you will find a 10 to 15 amp fuse connected in line with where the power cord comes into the back of the microwave. Be careful that you make sure power is off and be careful you don't touch the capacitor it could be charged. But the fuse just usually snaps in.
Dec 24, 2007 | Whirlpool MH2155XPS Microwave Oven
Daewoo KOC-925T Microwave Oven Logo
90 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
