Question about Adhesives, Coatings & Sealants
What's a good marine sealant to use on leaking underwater port holes on swimming pool?
The house we bought has a pool with two underwater port holes or windows (yes, bad idea -- but not mine) that bring in light underwater. They are on a side wall that opens out to the woods; the pool is not entirely in the ground. When it gets cold enough, usually in the 20s, the windows leak and the pool loses a lot of water. I do not want to drain the pool to repair them this time of year, but am instead looking for a temporary fix in the form of a good sealant that can be applied to the outside of the windows at the edges (which are wet). Any ideas? Thanks
  • 51 Answers
Plumbers gold sealant
Posted on Nov 26, 2014
How to fix leak in swimming pool sand filter
Empty the filter, dry the inside, rough up the are with a wire cup brush on a drill. Push two part marine putty into area where the leak is.
http://www.bing.com/images/search?q=marine+epoxy+putty.&FORM=HDRSC2 marine epoxy putty Bing images
Aug 20, 2015 | Pool & Spa
How to fix a hole in a swimming pool liner
  • Get some food coloring...
    • Squeeze bottle works best
    • Or pool leak detection Dye
  • get some good goggles...
  • get in the pool, start at one specific area...
  • and take a deep breath...
  • Now follow all the seams 1st, squeeze some dye in a suspected area and watch. If the dye gets sucked in, there's a leak! If it just puddles and hangs around, keep checking somewhere else.
  • Once a lead IS found, vinyl liner pool patch! Can even be used under water.
Amazon com Vinyl liner pool patch Patio Lawn Garden
Leakmaster Pre Filled Dye Tester For Finding Pool Spa Leaks
Oct 15, 2014 | GLI Pool Liner 050012rdlucub52 12 Round,...
Hayward pool filter Model SP711 alignment on filter, ports, spider gasket replacement
Remove the 6 screws from around the valve assembly. Pay close attention to the current orientation of the valve assembly before removing. Lift the value assembly straight out and the spider gasket is on the bottom. This could be twisted a little which would also cause your back flush port to leak when positioned in the filter position. If twisted, just position back in alignment with the valve holes on the bottom of the valve assembly. If the gasket is worn or torn then just replace and place the valve assembly back in the valve housing and replace all 6 screws. If you still have problems with water not functioning based on the way you have the handle turned then it might be time to replace the entire valve assembly.
Jun 15, 2014 | Hayward SAND FILTER, PRO SERIES
My pool is loosing air
You have a hole some where in the top ring. Any pool store has underwater patch kits, they also work above the water too.
owner of www.ThePoolToyStore.com
Jun 25, 2013 | Intex 18 X 42 Quick Set Pool Package
Above ground pool leak
Is this an above ground pool or an in ground pool? As a general rule you don't want vinyl to go too long without water. Water helps things stay in place. If the vinyl starts to shrink and bow inward there is a good chance that it will lose its elasticity and split when the pool is being refilled. I would advise you to go ahead and refill the pool. Leaks can be repaired underwater. In the event of a split I'd go back to the installer and pursue a new liner at his expense.
Jan 28, 2013 | Pool & Spa
My 14' pool is leaking from the bottom slowly. 1" per 26hrs. I can not find a hole. No water on the sides of the pool. It is leaking out from under it. How do I find the hole. I have patched holes...
Using goggles I inspect the bottom and looking at each individual speck on the bottom. Sometimes what looks like debris is actually a hole though it seems it would take a good size hole to leak that much. Check the seam by gently trying to spread it.
Jun 14, 2011 | Intex Easy Set Pool 15x36
I have the 18 ft x 48" intex easy set infletable pool and it has been set up for almost 1 month. Until a couple days ago I had no problems. In the morning I noticed the water level was down more than a...
This should be easy ... a foot of water? I would suggest you are leaking out the bottom. do you have a mask and snorkel? Watch the bottom from a floating position ... you might find the hole ... there are underwater patch kits for this very purpose.
Aug 24, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
How do you fix a leak to a 15x48 swimming pool without emptying all the water? it's a small leak on a seam near the ground.pool has been up a week & no leak, until tonight?
They make underwater patch kits that are very simple to use. You cut a patch and apply glue, fold the patch in half with the glue faceing in. take it to the leak and slowley unfold against the hole. smooth out and make sure edges are sealed down. Keep pressure on the patch as instructed on package. Then let cure. Good luck.
May 28, 2010 | Intex Ultra Metal Frame Pool w/ Upgraded...
I have two holes in the bottom of my pool how do I fix them
The easiest way to patch a hole in a vinyl pool liner is with the water still in the pool. With an inexpensive underwater repair kit, some swimming goggles and a few hours to allow the patch to cure, you will be back to enjoying your aquatic playground. jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Pool repair kit (underwater) Rag Scissors Swimsuit Swimming goggles
  1. Step 1 Locate the tear in the liner. You may need to get into the pool and examine the surface wearing swimming goggles.
  2. Step 2 Read the patching kit instructions thoroughly before starting the job.
  3. Step 3 Clean debris from the area around the tear using a rag.
  4. Step 4 Use scissors to cut a patch for the hole. Use the vinyl from the repair kit to for the patch. Be sure it is at least 2 inches in diameter and will cover the entire hole.
  5. Step 5 Use applicator brush that comes with kit to apply adhesive to the back of the vinyl patch. Do not apply too much adhesive or the patch will not cure properly.
  6. Step 6 Fold the patch in half. The adhesive should be on the inside of the fold.
  7. Step 7 Enter the pool2_bing.gif water and relocate the area in need of patching. If hole is accessible from the outside of the pool, there is no need to get into water.
  8. Step 8 Hold patch underwater as close to the hole as possible. Unfold patch while underwater and apply to the hole.
  9. Step 9 Press the patch firmly while smoothing it from the center to the outside edges. This will help remove any excess air bubbles or water from under the patch surface.
  10. Step 10 Let patch cure as indicated on repair kit instructions.
Mar 29, 2010 | Intex Complete Easy Set Pool Kits at...
Adhesives, Coatings & Sealants Logo
556 people viewed this question
Top Adhesives, Coatings & Sealants Experts
David Payne
David Payne
Richard Piatek
Richard Piatek
Are you an Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
