Question about Whirlpool Kitchen Ranges
Whirlpool range/oven. The display shows "door" controls do not respond
Tried resetting power
    New Friend:
    Problem Solver:
  • 6 Answers
Maybe press and hold the bake and broil pads at the same time and hold for 3-5 seconds should show (sf) then press clean pad the display will then show (loc off)lock-out off then press start pad can only be set when oven is not in use JUst a guess but seems to be locked on ??
Posted on Nov 26, 2014
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
Whirlpool gas range f5 code
F5 is a fulty display control board. Unfortunately there is nothing you can do to fix this problem but to order and replace the display control board.
Here is the board to order.
Dec 02, 2012 | Whirlpool GS563LXSS - stainless Steel Gas...
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Error code
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.T$%^%ETG
Dec 15, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
My whirlpool gas range display is malfuntioning shows f5,please replay
either the door latch switches are off kilter or the oven control is defective
Nov 01, 2009 | Whirlpool 30" Freestanding Gas Range -...
Whirlpool Gold electric range.
Hello delmonico
Welcome to Fixya,
You said, when turning on the self clean option, after 1 minute, I get E 1 F5 on the display panel. What do I do?
Try this .
Turning off the power to the range at the breaker for 5 minutes and see if this will reset the system.
Display shows messages
Is the display showing a letter followed by a number?
Depending on your model, press OFF/CANCEL or CANCEL/
OFF to clear the display. See “Control Display” in the
“Electronic Oven Controls” section. If it reappears, call for
service.
Let me know how it goes.
Thank You,Huuum
Please remember to enter a rating!
Oct 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
After a power failure I am getting the code e1 f1 flashing on my display board and it will not go away.
q.gif Why is the display showing E"#"-F"#," for example, E1-F2?
Answer Is "PF" displayed on the control?
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
please do not forget to rate and comment about your experience today. Thank you
Sep 03, 2008 | Whirlpool Kitchen Ranges
Whirlpool oven
When I had a similar problem, the door wouldn't unlock even after unplugging, waiting 30 minutes, and plugging the oven back in. I finally had to manually unlock the oven by turning the lock latch motor myself.
Here's a good page that describes what the lock latch motor looks like and where it's located. Of course, there is 220V current running around inside there, so please unplug before removing the back access cover and put it back on before plugging the oven back in.
My symptoms:
  • Oven failed to complete auto-clean cycle.
  • Oven started beeping; control panel showed FSE 1
  • About a minute after plugging in, oven started beeping and displaying FSE 1 again
Once I unlocked the door manually and plugged back in, the oven started behaving normally.
Jan 01, 2008 | Whirlpool RF368 Electric Kitchen Range
Whirlpool Electric range model RF386
cant nfind euf5 code can find eo f5 its a door loc code saing the door and latch switches do not agree try pushing stop/cancel and try again also does the oven light go off and on when you open and close the door
Dec 31, 2007 | Whirlpool RF364 Electric Kitchen Range
Kitchen Ranges Logo
79 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
