Question about MicroBoards PF-PRO Print Factory PRO Inkjet Automated 100-Disc Printer
How do I fix an image shifting problem? I expect occasional misprints, but when the image keeps shifting to various locations on more discs than not,it's a huge waste of blank discs
I spoke with a Sure Thing Rep. and they tell me it's a printer problem, not a Sure Thing CD labeling software issue.
Magnavox tv combo
Did you try disconnecting the unit from the power for a few hours?
Apr 13, 2008 | Philips Magnavox DVD/VCR Dual Player
I have a manual 92 Jeep Wrangler that my friends family gifted to me after he died. I admit that I know little about fixing cars but am trying to learn. At first I wasn't having any problems driving...
Your description indicates a fuel starvation or choking problem. I assume it is a carburettor model and either there are times when the engine is getting too much fuel - or too little, probably the latter.
There could be a blockage in the carb or the fuel pump might be worn or there could be a foreign object in the fuel tank sometimes blocking the flow.
It is also possible your vehicle is suffering carburettor freezing. This usually takes place, not in freezing weather as would be expected but in cool, damp conditions. Vehicle manufacturers go to great lengths in combatting this with warm air collected from around the exhaust manifold and mixed with the cooler air of the normal intake, usually controlled automatically by a vacuum operated flap.
Mar 18, 2017 | 1992 Jeep Wrangler
Have 2003 cavalier....wire for shift selinoid melted and tranny wouldn't shift. Fixed the wire and now the car keeps blowing the transmition fuse. Have had it a various shops and no one can seem to...
Did you trace out the wire to check for more bare spots? There's a reason why it melted. It's also possible that when the wire melted, it did internal damage to the shift solenoid. It may need to be changed. Hope this helps.
Aug 29, 2010 | Chevrolet Cavalier Cars & Trucks
Loading
Try this:
Turn off the computer by holding down the power button. Wait 10 seconds, then press the power button while holding down one of the SHIFT keys. Keep holding down the SHIFT key as your computer starts. This will make it start in Safe Mode, which will do various checks, clear caches, etc. It *may* fix your problem.
** Note: there's a small risk of data loss when reinstalling the operating system. It's important to have backups of your important pictures and other files. **If Safe Mode doesn't solve your problem, locate the system disc that came with your Mac. Put it in the drive and turn the machine off. Turn it back on while holding the C key. Follow the directions to reinstall the operating system.
Good luck and let us know if it worked or not. Please rate me if I helped you solve your problem.
Bot
Jul 06, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Double Image blue color
Need to have the convergence board repaired it will require 2 ICs and various resistors, expect to pay around $300 Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Embedded Animations in E-Mail
why not just download incredimail install it and have your own animations
Nov 02, 2008 | Microsoft Windows XP Home Edition
Okidata c3200 - "needs new drums" message
Check your page count, drum life on a C3200 is roughly 15000 pages. This information can be found on the information menu map.
Information Menu ecblank.gif ecblank.gif dot.gif ecblank.gif Menu Item Default Setting PRINT MENU MAP EXECUTE Prints the MenuMap (menu listing) with current settings shown. Information about your printer is also
shown at the top of each MenuMap page.
Life Expectancy ecblank.gif ecblank.gif dot.gif ecblank.gifToner Cartridge
Life expectancy approximately 1,500 pages, assuming about 5% coverage, which means that 5% of the addressable dots in an image are printed with this color of toner. See Toner Cartridge..
Image Drum
Life expectancy approximately 15,000 pages, assuming an average of 3 pages per print job. If the average print job is longer than this, the image drums could last longer, but if the average print job is shorter, then image drums will be used more quickly. See Image Drum.
Transfer Belt
Life expectancy about 50,000 letter-size pages. See Transfer Belt.
Fuser
Life expectancy about 45,000 letter-size pages. See Fuser.
Feb 11, 2008 | OKI C3200n Led Printer
MicroBoards PF-PRO Print Factory PRO Inkjet Automated 100-Disc Printer Logo
73 people viewed this question
Top MicroBoards Computers & Internet Experts
 Grubhead
Grubhead
 Russ Hill
Russ Hill
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
