Question about Coby Kyros Internet Touchscreen Tablet (MID7015-4G)
I factory rest my kyros mid7120 and lost my start up cd need help
Need to down load cd or software from my laptop
Cant remember my password
A really annoying issue but your password is Your and only you are supposed to know it.
So I guess your only choice is to do a Factory Reset of your Coby tablet:
Hope this Youtube tutorial might help you:
Factory reset on Kyros MID 7012 without using Settings
Also you should read these tutorial:
Coby Kyros MID7010 hard reset
http://webcache.googleusercontent.com/search?q=cache:eQiuI75ELTMJ:resetandroid.com/coby-kyros/+&cd=6&hl=es&ct=clnk
http://www.androidtablets.net/threads/how-to-factory-reset-on-coby-kyros.24344
You can get some more information doing a google search for
factory reset of Coby kyros Tablet
Jul 30, 2015 | Coby kyros Tablets & eReaders
Need to know how to get software for coby kyros mid7120 lost my start up cd
you can try here and no that I don't know this site owner and cannot vouch for any software there. Suggest you download to desktop and scan with you AV before you install.
Solvusoft Microsoft Gold Certified Company
Nov 27, 2014 | Coby Tablets & eReaders
How can i reset my passcode pattern
Steps on how to do the restart. -You have to turn off the system. -Then press and hold the power button until you will see a message that will popup in a window that saying "Device Options"Appears on the screen. -Then select the power off again then you can see it again.You can be able to check that it first. -Then just select okay And while holding down the -Back -Button -Then Press and hold the power button. -Until you see the Coby`s Logo -Then wait until it change to Android Logo. - Then press the Back button.And Then the system menu will appear in the screen. -And then choose the wipe data/factory reset. >Home >Menu Buttons >Press the back,the button once you select the wipe data/factory reset then just click option. Then the confirmation that you will see in the screen Is a "yes" "Option". Then Choose "yes"-delete all user data,option by using the "Home"and "Menu"buttons. Then it will perform the factory data reset. -wait until it done. -Then once your done the main system menu has to appear in the screen. -And then reboot the system. -Then you have to press the back button to reboot the system. -The system will reboot the initial factory data setting. -All the user data will be lost. -Then Give the reboot,at least for 5 minutes. -Then Do not assume the unit has frozen.
Aug 22, 2014 | Coby Kyros MID7120-4G 4 GB Tablet - 7" -...
How to reinstall os on coby 7" tablet?
Usually on an android device access settings : sd card and storage : select erase all or restore or factory reset and device will be factory restored . If the OS is completely gone you may have to access an image from te Coby website and install from a laptop by cable .
Jun 12, 2014 | Coby Kyros MID80244G Tablet
My coby kyros mid9742 will not start up at all it just keeps rebooting
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Apr 19, 2013 | Coby Kyros 716829701508 Tablet PC
I just got a new MID7120 system and my grandson set the connect the dote to unlock and now he forgot what dots he connected , how can we get access to re
can try master reset but will lose all personally input and downloaded data. suggest you take it back where you bought it.
Aug 27, 2012 | Coby Kyros Tablet
My Coby 7125-4 says its not compatible with AppsLib
I am having the same problem with the mid7120. I bought two for my boys for Xmas. The appslib worked the day before Christmas. On Christmas day, I noticed their site was under maintenance. Now it says my device is not compatible on one and says to reset the date to June 20,2010 on the other.
Dec 26, 2011 | Coby Kyros 716829701508 Tablet PC
How do you update
Before we begin you will need to have the following ready. ? The Coby Kyros with a battery level of 30% or more, the USB cable and an empty micro SD card with a minimum of 4G. The Micro SD card should be inserted into the Kyros. Start by going to our website www.cobyusa.com to download the zip file to your computer. The file can be found on the main page for the MID7015. It is titled "UPDATE.ZIP". It is important that you do not UNZIP the file.
Once file has been downloaded to your computer, turn the Kyros on and connect the unit to the computer via the included USB cable. At the top of the main page Go to the navigation bar and scroll down. A menu will open with several USB notifications.
Click on the External USB connection. This connection refers to the inserted SD card. A new menu will appear Click on MOUNT. Once complete your computer should recognize the Kyros device. A screen will open and show the Removable Storage drive. If this window does not open, please go to the start menu of your computer and select computer or my computer. There may be several drives shown. Please choose the one that corresponds to the SD card, it should show as empty. Open the drive. Now you may drag and drop the ZIP file into the removable storage drive. This process will take approximately 1 minute to complete.
When complete Go back to the Main Screen of the Coby Kyros Once again go to the top navigation bar and Turn off the USB Storage. Another window will appear with a turn off message. Make sure to click on this as well. Disconnect the Coby Kyros from the USB cord attached to the computer. Then Press the Power button, it will again prompt you to power off from the main screen twice.
Wait 5 seconds. During this time locate the power button and the return button. Press both buttons at the same time. Continue to hold the buttons down until you see the warning triangle and android logo. Once the symbols appear you may release.
Press the return button again. The reboot section will appear. You will use the Home and Menu keys to scroll through this section. The Home key scrolls up and the Menu key scrolls down.
Scroll down to Wipe data/factory reset. Press the return button to select. Scroll down to Yes and hit return. The Kyros will notate the Data wipe is complete.
Scroll down to Apply SDcard and press return The Kyros will notate Install from SD card complete. This will take approximately 1 minute .Select Reboot system now and hit return key
Congratulations you have just updated your Coby Kyros
For more info visit www.cobyusa.com
Hope this support has been helpful?
Thank you for visiting FixYa.
Sep 06, 2011 | Coby Kyros 716829701508 Tablet PC
I need to download driver software for my coby kyros MID7015 so i can sync it to my pc
i have coby kyros mid7010-4g tablet
it just load the coby logo then penguin logo then android_ text
i tried the factory rest ( power + back + home ) ..
it gives " Unexpected updater mode! Please reboot your device.
How do i proceed from here Any help please.
Mar 20, 2011 | Coby Kyros 716829701508 Tablet PC
Coby Kyros Internet Touchscreen Tablet (MID7015-4G) Logo
42 people viewed this question
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
