Question about Garden
I have a toro ccr2000 that starts but when I get to the snow it shuts off
Fresh gas and cleaner let run for 20 minutes same results
    Sergeant:
  • 166 Answers
Shuts off -I would look for a bare place on the spark plug wire. Slows down and stops under load (snow) then check for a bind in the throttle linkage. The govenor is not opening the throttle as the engine slows down.
Posted on Nov 26, 2014
2 Suggested Answers
SOURCE: How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Posted on Feb 09, 2014
Why does it run for 10 mins, then stops?
Loosen Gas cap and see if that helps. Many times the Gas tank Vent gets clogged. When engine runs, it creates a suction and starves the engine of gas.
OR
If the engine was stored with gas in it, sometimes the Rubber seat in the carburetor deforms and wont let the gas flow into the Carb Bowl at a fast enough rate to keep up with the running engine. The bowl empties (after 9 minutes) and the engine quits. Takes a while for the bowl to refill (5 minutes).
Jan 16, 2016 | Toro Snow Blowers. Power Clear 621 QZR 21...
Start snow blower runs for 3 min. and starts to over heat checked oil its ok then stats to shut down like its not geting oil
Why do you say its over heating .Runs for 3 minutes the oil is OK .
Do you understand how the choke works .
bacsicly you prime the mechine in cold condutions 3-4 pumps choke to max throttle at 3 /1/4 .
Start backing off the choke after 3-to4 mins .
The choke shuts the fresh flow down to the engine in cold condutions ware it needs more fuel then air to run.
When the engine starts to get hot it can't run with out fresh air to mix with the gas it won't run anymore because there is to much gas and not enough air
Its simple fool prof will work everytime if you adjust it right
Mar 01, 2015 | Craftsman Snow Blower / Snowblower Bottom...
New 621E toro snowblower running on prime fuel has been running now will not stay on with choke out what do i need to do
HOW OLD IS THE GAS . PLEASE DRAIN THE GAS OUT OF BLOWER AND PUT FRESH GAS IN IT I WOULD ASLO GET WITH THE STORE THAT YOU BOUGHT IT FROM TO EXCANGE THE BLOWER
Feb 21, 2015 | Toro Snow Blowers. Power Clear 621E 21 in....
How do i get my toro gts-5 550 lawn mower to keep running?
The problem is likely varnish buildup in the carb. Add PAINT THINNER ( yes, I meant to say that !) to the gas. Use 1.5 ounces each of Xylol ( Xylel) and Acetone per 10 gallons of gas ( 5 gal. can will use 3/4 ounce each ).Drain gas tank and carb float bowl. Add fresh gas mixed with thinners. Remove air cleaner element and use quick starting fluid with upper cylinder lubricant to start mower, and keep it running with SHORT bursts of starting fluid until it will run on its own. You may also need to replace or clean air filter if it is old or dirty. continue procedure for 5 minutes or so. Remember to run Sta-bil fuel stabilizer through the system before you shut down for the season, as this will prevent the varnish build up.
I've been using thinner in all of my engines ( gas, pre mix, and diesel ) for a few years with no bad side effects. I've ridden over 15,000 miles on my motorcycle - getting better mileage and power, and not having to buy premium gas either.
Hope this helps!!
May 31, 2014 | Toro Lawn Mower With Toro Power Tools
Stalling
drain gas from carb and tank get some fresh non ethynol gas
while carb bowl is off spray/ clean with carb cleaner spray.
when you drain gas put it in clear container so you can see if there was water or dirt in it. helps to figure out the problem
Mar 27, 2014 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
Toro power clear will not stay running brand new
is the choke closed when you start this thing make sure you close the choke to start then shut it off , the plug gets fouled if you do not do it this way make shore you have the right gas mix in it , takes 50 to 1 I believe 2+2
Feb 08, 2014 | Toro Snow Blowers. Power Clear 621 QZR 21...
Feb 09, 2014 | Garden
LEFT GAS IN SNOWBLOWER OVER SUMMER REMOVED THE GAS STILL WILL NOT START
You will need something stronger than regular, fresh gas to clean the carburetor. May I suggest using some Berryman B-12 ChemTool. It contains strong solvents and cleaners that may enable the carburetor to function. Check the dosage, add a little extra in your machine's gas tank. After doing that though, I would remove the air filter housing and spray some carb/choke cleaner directly into the throat of the carb with the choke open. Then choke it to attempt a start immediately. Continue doing it until it "pops" like it wants to start. If that does not work, then pull the plug and introduce some fresh gas or carb cleaner directly into the engine (1 tsp gas). If you get it running, the Berryman will automatically clean the carb and you might be good to go. Post back if needed.
Dec 13, 2010 | Toro Snow Blower Scraper For S200 s620 New...
I have a toro-recycler. it is about four years old and has always run great-until now..it shut off in the middle of the yard and wont re-start. i put in fresh gas/sea-foam, new plug, and air cleaner..it is...
It sounds as if the gas cap may be clogged. It must be able to breathe so that the carburetor gets the proper gas flow. Does it run for about 10-15 minutes? If so, this is more than likely your problem.
Jim
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
Snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
82 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
