Question about Electrical Supplies
How do I connect a Fuling Inverter to a Gecko G540 controller to enable spindle speed control via Mach3 Software
I have been unable to find a wiring diagram so have not tried in case i damage the controller. The wiring power supply and 3 phase feed to the spindle are fine. I have no info on the inverter or suggested wiring diagrams
efs_perpends
  • 1996 Answers
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
  • 4 Answers
SOURCE: Invertor connections to protect from utilty power backfeed
Inverters normaly have inbuilt protection built into them check for reset button/switch.
Posted on Jun 19, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
buffalonyman
  • 1865 Answers
SOURCE: I have a c25 relay I'm wiring that is controled
I am a Master Electrician, I provide DIY services via email. You can pay via paypal. email me at buffalonymann@yahoo.com and I'll give you the link to my website where you can set up the account
Posted on Sep 04, 2009
GiantTechGuy
  • 25 Answers
SOURCE: my giant wse 200 tig inverter single phase AC/DC
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
Posted on Oct 18, 2009
F6 error code whirpool duet
The F6 error code for this model indicates a drive motor tachometer error. The control board is unable to properly detect the motor speed.
Jan 09, 2016 | Washing Machines
What is error code f06?
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
May 24, 2015 | Washing Machines
I have a KEB combivert F5. The parameter ru 00 shows nop even if i give switching to terminal 16 for control release.Please help.
This may be due to the inverter waiting for an ST signal via buss communications.
What is the part # of the unit in question?
The inverter is recognizing that terminal 16 is going active but still waiting for another command to enable the inverter.
Mar 09, 2015 | Inverter KEB COMBIVERT F5
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
F6 error
F-6=Drive Motor Tachometer Error
solution-
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
  • Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    I am unable to activate my speakers - after accessing sounds via the control panel the volume control is greyed out. The speakers are correctly connected
    So we're talking about a PC here, right?
    Perhaps you could fill in some details as everything is software-controlled. Can you access your soundcard controls? It probably overrides the basic system stuff.
    Dec 29, 2010 | Logitech X-140 Speaker
    DELTA INVERTER VFD-B PROGRAM HAS BEEN LOCK THREREFORE WE CAN NOT CHANGE SPEED CONTROL NON AUTHERIZED PERSON PUT IN THE PASSWARD AND FORGET PASSWARD
    First thee attempts will "lock" you out. you must restart drive to allow 3 more tries. If you can't get to programming funcitons to change password you should be able to connect via serial connection and reset the password funcitons to 0. See attached pdf file for directions to connect pc to drive: http://www.delta.com.tw/product/em/control/cm/download/manual/IFD9507_application_en.pdf
    If you don't have your manual to expalin password functions you can also find it at:http://www.delta.com.tw/product/em/download/download_main.asp?act=2&pid=1&cid=1
    Jul 20, 2010 | Delta Vfd007b43a AC Drive VFD B Inverter
    Code flashing F 06 wont spin
    The code F06:Drive motor tachometer error happens when the control unit is unable to properly detect motor speed.
    If you are planning on doing this yourself then in order to troubleshoot this you will need to remove the back panel to gain access to the motor and wiring harness.
    Check the motor by turning the pulley. If the motor does not turn smoothly then it's most likely a bad motor. If this seems ok inspect the wiring harness for any broken or loose connections. It's a good idea to unplug and then reinsert all the connections between the board and motor. This helps clean any corrosion that may have built up on them.
    If your still having problems then the MCU (motor control board) may need to be replaced.
    I hope this helps.
    Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Turntable 45rpm speed has stopped working
    Check that the lever is actually making the contact with the 45 rpm switch position and completing the circuit as it would seem everything else works. The only other thing it could be is a break on the pcb, but that is unlikely.
    Oct 17, 2008 | Philips Audio Players & Recorders
    Memory upgrade
    I like all the information you gave. However the information you are looking for is in the manufactures web site. goto search engine and enter your computers manufactures name followed by the word "support" find the site and then look up the details for your computer. The reason I say this is because each slot can only control a certain amount of memory. The manufacture will tell you what each slot can control and also the type of memory supported by your motherboard. THIS IS VERY IMPORTANT> never mix memory. Make sure of speed and capacity. If you mix diffrent speed and capacities the results could end in total failure.
    Sep 19, 2007 | Computers & Internet
    Electrical Supplies Logo
    87 people viewed this question
    Top Electrical Supplies Experts
    ken skalski
    Gene Haynes
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
