Question about Mr. Heater MH125KT Utility
I have a Mr. Heater 125,000 BTU contractor series shop heater and it started surging spurts of flame rather than run smoothly.
Checked valves, fuel level, turned off and on, called Mr. Heater (put on terminal hold).
    Sergeant:
  • 231 Answers
You may have contaminants in the fuel, such as water. Fuel that sits in gas cans can sometimes have condensed water in it. There may also be something that has clogged teh fuel flow.
Posted on Nov 26, 2014
SOURCE: mr heater 75,000 btu kerosene heater
I got this error when I had increased my air pressure to 5.5 lbs. Cut the pressure back to 4.5 and it has been running fine for the last three hours. At 5.5 it got WARM ... solid red hot cone and flames coming around the outside. Had been having problems with it cutting off for no apparent reason in really cold weather. Took the pump apart and cleaned it and checked for clearances and reassembled but it did not help much. Will schedule it for a total pump replacement with new filters asap. Pump parts and filter are not that bad. Should come in under $50.00
Hope this helps
I also turned the thermostat back a little off of full on.
Mike
Posted on Feb 04, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Posted on Feb 15, 2009
wilsodfarm
  • 986 Answers
SOURCE: pilot will not stay on
replace your regulater,which almost cost as much a a new heater.I have own 4 or 5 and finally got a good one,I have in the past cleaned out the regulator that was plugged with oil from the propane,they put oil in the propane for leak detection,I hope this helps you
Posted on Dec 02, 2009
Testimonial: "Thank You. perhaps it is not adjusted properly. I so appreciate the quick response..Good Job!!!"
SOURCE: Mr. Heater Natural Gas Garage Heater - 45,000 BTU.
my garage heater was working early this winter. I turned the thermostat to 0, but when I went to restart heater nothing happens, can you help me with this problem?
Posted on Dec 27, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Mr. Heater Big Maxx 75,000 BTU Heater will not
Is the circuit board giving you a blinking error code?
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Feb 26, 2010
210,000 btu Mr. Heater Contractor heater won't start
That error is a cad cell error. That could mean that the combustion air is having issues. The electric eye is bad or dirty or there could be an issue with the pressure sensors. go to mrheater.com and look at the troubleshooting guide or call the free 800 number
Jan 05, 2014 | Mr. Heater Heating & Cooling
Heater runs for about 30 seconds and goes out
If the unit continues to relight and "Go Out" then the Flame Sensor needs to be replaced.
Feb 03, 2011 | Mr. Heater MH170FAVT 125,000-170,000 BTU...
I have a mr heater contractor series 75k, it fires like it should, runs for a very short period of time then quits running
Sorry to read about your problem, I hope this helps you out.
I think your high limit switch is defective, and is kicking in. 21751 is the part number or just contact Mr Heater. http://www.mrheater.com/ContactUs.aspx
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 03, 2011 | Mr. Heater MH55FAV Open Flame Utility
Ignitor runs continually, even when lit....is this normal?...........turn the gas on and push the gas valve and lights perfect, but no matter how long you hold it in, when you release it, it will not stay...
This sounds like a problem with your thermocouple or flame rod. If it is a flame rod you may be able to just clean it with some sandpaper or steelwool. If it is a thermocouple you will probably need to replace it.
Dec 10, 2010 | Reddy Heater-75-125,000 BTU Variable
Heater was working fine but it stopped. I'm wondering what the problem might be. I've backwashed the filter, checked for dirt and spider webs inside the unit, turned off and on the knob....but no luck
If your Laars will not stay lit then the pilot generator is faulty. That is the small brass and copper piped connection near the pilot flame. It must produce 250minivolts in order to open the main gas valve and keep the gas running into the pilot burner..
please visit http://www.laarsman.co.uk for more help
Miles X
Jun 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Reddy Heater 110K btu motor won't start.
Bearing have gone bad in the electric motor. You will have to replace the electric motor. They are expensive but still cheaper than buying a whole new heater.
Jan 05, 2010 | Reddy HEATER RH125T 125,000-BTU...
MR. Heater Portable Buddy model MH9B
the mr heater series units have a millivolt generator connected to a very small sensitive electromagnet in the valve body. inside the generator is a small insulated wire connected to the very tip of the generator. that and the outside copper tube forms the j-k junction. at the other end, the part that goes into the valve is a silver button and a gland nut. this forms the other part of the electric circuit. the inside of the valve has a spring and an iron slug with a rubber pad. the slug gets sucked into the electromagnet when the magnet is operating and holds the pad off its seat allowing propane to go through the regulator and valve. change out your generator and I'm sure your problems will be solved. mr heater has a web site.
Oct 29, 2007 | Heating & Cooling
Mr. Heater MH125KT Utility Logo
266 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
