Question about Tascam 2488 Portastudio Multitrack Recorder System
My stop button on my Tascam 2488 will not stop the playback or recording. What can I do?
I've been trying to reload/update it with an update from the internet using the ISO formatted files. It will not let me do this. This I suppose may be due to the type of CD I am using, however I'm not sure that is the problem (operating system).
  • 189 Answers
SOURCE: Tascam 2488 Recorder
The 2488 has three effects types: “Mic” effects (compression, exciter, de-esser) you use while recording or insert into a channel; multieffects (distortion, amp model, modulation effects, delay, wah, etc.); and an internal send effect (reverb, delay, chorus, pitch shift, flanger, phaser, and gated reverb).
To add effects to an already recorded track you can assign the effect using the internal send loop for the channel and then bounce the track to print a copy of the track with the effect applied.
Posted on Jan 03, 2008
  • 189 Answers
SOURCE: Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
SOURCE: TASCAM 2488 won't boot up..HELP!
reseat the HDD cables, just unplug them and blow on them to remove any dust or anything on the cables and the connectors and plug them back in, but first make sure it is unplugged from the socket and once it is press the power button to let all the power out of it so you don't shock yourself , i hope I was helpful and it solves your issue
Posted on Apr 10, 2008
  • 189 Answers
SOURCE: vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Posted on Sep 15, 2008
SOURCE: Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Posted on Feb 25, 2009
I want to erase all of my data on the tascam 2488
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 7, page 45 talks about erasing partitions permanently.
Feb 07, 2011 | Tascam 2488 Portastudio Multitrack...
On my Tascam 2488, the Stop, Play and Record buttons have been getting harder and harder to press and activate. Today I can't get them working at all no matter how hard I press. I opened the unit up, but...
I got the same problem. Also, the headphone jack on my Tascam 2488 is going bad. Only the right headphone will work most of the time. Anyone know a remedy/ solution for this?
Nov 16, 2009 | Tascam 2488 Portastudio Multitrack...
Is there any way to record Tascam 2488 Multieffects directly to the hard drive when I record? When I change tracks during playback, the previous effect that I used disappears...Please help???
Yes. Rather than pressing the track SELECT button to assign the effect, press one of the SOURCE buttons to the left of the EFFECTS. This will record the effect HARD to the track as oopposed to SOFT. SOFT being that the effect will NOT be recorded whereas HARD means it IS recorded and will be there anytime you play the track. NOTE: Just make sure that's the effect you want as it is then part of the track.
Aug 21, 2008 | Tascam 2488 Portastudio Multitrack...
Uploading audio instumentals into the Tascam 2488 II
You can get to the quick start guide here.
www.tascamgiga.com/i-738-232-128-0-BBDFF677.pdf
There is quite a bit to learn to get to the proficient point with this unit. Most of it involves the operator learning the software
Feb 11, 2008 | Tascam 2488 Portastudio Multitrack...
Hope this helps !
Best regards
Jan 24, 2008 | Tascam 2488 Portastudio Multitrack...
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 10, 2007 | Tascam 2488 Portastudio Multitrack...
I can't figure out how to record on 8 tracks at the same time.
Nov 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
140 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
