Question about Tablets & eReaders
How do I download apps and or games and save it on my 32GB external SD card. I have loaded the card but it shows the card is loaded but it is in grey is that correct.
Every time I downloaded anything it goes to my internal memory when I want it to go to my external memory.
    Habit-Forming:
  • 145 Answers
Depending on what device you have you have to tell your device where to install or moves folders manually. Always describe what your problem is as accurate as you can and always specify what device and model..
Posted on Nov 26, 2014
I have put 32 gb sd card into excelvan tablet for external storage and its not saving?
Unfortunately, most apps will not load onto an SD card. You'll find that some apps will, if a card is installed, place data there. Mostly the SD Cards are installed for use in storing photos and videos taken by the user with the tablet camera. Newer tablets and smartphones are coming with more and more internal RAM to alleviate the "full" issue, but in most cases, you wither have to give up the new app, or remove one to get another.
Aug 31, 2016 | Tablets & eReaders
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
How to save downloaded apps to an external SD card?
open up file explorer first. than copy the files and paste them onto your sd card
Feb 18, 2016 | Tablets & eReaders
My pad says the internal storage is almost used up...I inserted an sd card, but not sure how to get the tablet to read it so that I'm able to install more apps and games.
Good afternoon Linda!
You can view your manual here
RCA RCT6077W2 Manuals . If you go to page 10
RCA RCT6077W2 User Manual Micro usb Headphone Micro Sd it notes a couple of important caveats on the card:
  1. You can use MicroSD or MicroSDHC type cards
  2. Size limit of 32GB
  3. You are warned never to insert or remove the MicroSD card in 'On' mode (i.e. only insert/remove the card when the tablet is off)
Aside from that, it looks like things should work. To be sure on what is the root of the issue, you can:
  1. Insert your card into another device to verify that it works
  2. Format or Re-Format the card - the SD Card association has a formatting app here:
https://www.sdcard.org/downloads/formatter_4
  • Make sure the card is legit. If it was purchased, for instance, off of Ebay, or other not-so-top-tier online store, as likely as not it's a fake made in China, likely with guts from manufacturing rejects. You might, for instance, get a card marked 32Gb that actually has a 2Gb chip in it with a hacked controller that says it's 32Gb. It'll seem to work OK for a few files, and at some point will just write your files into no-where. SD Insight, a free checker app for Android phones can be picked up here
SD Insight Confirm your micro SD card authenticity instantly amongst many options.
Hoping this helps!
D
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
I have an irulu tablet. I inserted a 32gb sd card. It says it is mounted and when i try to install an app from the google play store i get the message there is insuficient space available. how do i get it...
Most apps do not natively install to an SD card when downloaded from the play store. You have to have an app like AppManager, that has a function to 'move' apps from internal storage to an SD card, or use a manual option in the Android Settings section to move each app individually.. If you are that tight on space that you cannot load any new app, you may have to delete or move something from your internal storage so you can download AppManager or some similar app, and then move as many apps as you can to your SD card. If you have a lot of photos and music you can try moving that to the SD card if your player/viewer software will allow you to find it there. Best way to move bulk items (music/photos, not apps) is to connect to a PC through USB, which brings up your internal storage and the SD card as external USB storage items. Then copy from internal storage to SD card through your PC. Best to establish folders on the SD card to hold these items and then tell your app where they are.
Dec 03, 2014 | Tablets & eReaders
Transfer data from galaxy 10.1 note to sd ext storeage
Go to the play store and download a file management app. Use the app to move the files. OR, connect to a PC and manually move the files to the SD card
Dec 27, 2017 | Samsung Galaxy Note 10.1
Tablets & eReaders Logo
76 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
