Question about GPS
TomTom One won't turn on at all and I have charged it up
  • buzz flewhart
    buzz flewhart Nov 26, 2014
    Hi Trevor Palmer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Specifically, I need the model number of the TomTom.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Try resetting the device, by put charge cable to it, see light is on, then press and hold for 10secs or more the reset button on the back of the GPS.
Posted on Nov 26, 2014
My Tomtom 300 Go won't charge?
It appears that the battery will not hold a (good) charge anymore. If it is still under warranty, contact TomTom to address that problem. They may replace the unit for you.
It is not unusual for (rechargeable) batteries to loose it's capability to hold a good charge if it is plugged in (to a power source) all the time, even while it is not in use.
May 06, 2012 | Tomtom GO 300 GPS Receiver
DOES THE tOMTOM via NEED TO BE CHARGED BEFORE USE?
I would read the manual if it doesn't state it in it you should not it should be a lithium battery and if it is it wont hurt to charge it again they should be capable of running all the time charged so if you can run it all the time it won't hurt to charge it before hand.
Nov 20, 2011 | Tomtom VIA 1505T GPS Receiver
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
I can't get my tomtom to turn on. It is plugged
Straight from the TomTom website:
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
    I hope this helps!
Mar 09, 2010 | Tomtom ONE XL GPS
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
My tomtom one no longer recognises the car charger.I have purchased a new one from a dealer and it won''r make it charge.I can only bharge it with my bomputer hook up cable...what can I do now?
Seeing as it charges from the computer
I doubt that it is the tomtom.
I would suspect either the outlet in your car or a posible problem with the lead even if it is new.
Aug 28, 2009 | Tomtom ONE GPS Receiver
My tomtom doesn't turn on
the green light shows when i am charging my tomtom but it doesn't turn on.
Aug 19, 2009 | Tomtom GO 720 GPS Receiver
Tomtom won't turn on or off. So I can different screens
does the socket in your car stay powered on even when the car is turned off most likely not and you just need to charge your device will itcome on when it is in the cradle for the computer
Dec 27, 2008 | Tomtom ONE GPS Receiver
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
TomTom 910 won`t turn on
try charging both in the car and on the home charger
try a doft reset
www.tomtom.com.7134
Jun 22, 2008 | Tomtom GO 510 GPS Receiver
GPS Logo
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
