Question about Panasonic PT-52LCX65
I have a panasonic pt 52lcx65 with red lines vertical over the entire screen. I've been told it may be the light engine. Don't know how to find where to buy it from so I can replace
I have a panasonic pt 52lcx65 with red lines vertical over the entire screen. I've been told it may be the light engine. Don't know how to find where to buy it from so I can replace it.
    Problem Solver:
  • 19 Answers
TRY SHOP JIMMY .COM
Posted on Nov 26, 2014
techman
  • 3130 Answers
SOURCE: Vertical lines and big red spot on Panasonic PT-56LCX66
Return it my friend, it sounds like a problem on the display panel driver board, and boy is that expensive to replace! Good Luck
Posted on Jul 31, 2007
jomabug76
  • 1148 Answers
SOURCE: Panasonic 52LCX65\PT Green Spot
COLOR CONVERSION IN THE MENU ,,TRY THAT,,IF NOT A NEW CABLE,,CONVERSION REALIGNS THE COLOR
Posted on May 15, 2009
ArnelM
  • 153 Answers
SOURCE: some green spot, purple and red are showing on the tv screen
Try updating the software first :)
Posted on May 27, 2009
ArnelM
  • 153 Answers
SOURCE: has a orange and green spot on screen tv is 3 years old
Call Panasonic and request for correction tool(software update) part#LSUQ0100. This comes with the instruction. Try this first before suspecting light engine.
tvtek
  • 1284 Answers
SOURCE: I have red (3) & green (1) spots on my TV
This is actually a memory error issue on the LCD driver panel board. This will require the repair from a Panasonic authorized servicer as there are no parts needed but they have to use a special reset tool that Panasonic provides to them. Call Panasonic and see if this is a covered repair since it was a well known issue. Please take a moment to rate my answer...Thanks..
Posted on Dec 04, 2009
Testimonial: "Thank you ... I have contacted Panasonic."
I have RED verticle lines all the way across the screen fro top to bottom 10 minutes after I turn my Panasonic PT-52LCX65 TV on. Is there a solution?
Hello
Check and replace the main filter capacitor in the power supply section. Replace all of them in the secondary section of the power supply too. The problem is due to insufficant smoothing and regulatio fo the power supply section. If main smoothing capacitor gets value deveoped, it won't supply enough voltage to the switching section, and switching section also will go inefficient. Replace all of them. It won't cost not much. OK.
Jun 22, 2011 | Panasonic PT-52LCX65 44" HDTV
HEllo, I have about a six year old Panasonic projection HDTV television model # PT-52LCX65-K I recently placed the lamp. Now I have four green spots and two red spots on the screen. They are getting...
CALL PANASONIC THERE WERE SEVERAL MODELS FROM PANASONIC THAT HAD MANY PROBLEMS WITH EEPROM CORRUPTION THAT WOULD CAUSE THOSE KINDS OF SPOTS PANASONIC WILL MOST LIKELY PAY FOR THE REPAIR IF YOUR MODEL FALLS UNDER THE GUIDELINES.
Dec 16, 2010 | Panasonic PT-52LCX65 44" HDTV
There are color spots all over screen-pt-61lcx35
This, sadly is getting to be a very common problem with all Projection LCD TV's
Colored Blotches on an LCD Projection TV are usually caused by defects or marks on filters or lenses or one of the LCD panels themselves which are all located in the light engine (or optical block) First confirm that the lamp or main lens is not discolored by removing the lamp (unplug set and let cool before removing!) and inspecting the lamp itself and the lens that it shine onto. The light engine is an expensive part ($600-$1200) to replace and requires major disassembly. Get an estimate -Be sure to vote/rate me if this helped Thanks!
Nov 06, 2009 | Panasonic PT-52LCX65 44" HDTV
Red vertical lines on screen
You have a defective lcd driver board.so you can replace just the lcd driver pcb or the entire light engine...
Oct 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
What is phosporing screen
The colored spots may be a light engine issue that Panasonic will pay for repair costs even though tv is few years old. Contact Panasonic. . No you can't reset the lamp timer without a remote.
Oct 11, 2009 | Panasonic PT-52LCX65 44" HDTV
Red light on screen
Call Panasonic they will pay for this problem on this model
May 25, 2009 | Panasonic PT-52LCX65 44" HDTV
Has a orange and green spot on screen tv is 3 years old
May 21, 2009 | Panasonic PT-52LCX65 44" HDTV
Red, purple and green dot
Its the light engine. Had a tehnician come and look at mine and was told it would have cost over $600 if I didnt have the warranty. Panasonic called 2 weeks later and told me that parts are no longer available for my model and are upgrading me to a 50 inch tv.(from 44 inch)
Nov 29, 2007 | Panasonic PT-52LCX65 44" HDTV
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-52LCX65 Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
