Question about Cell Phones
It seems to be stuck on low heat and will not go on to high no matter what we try
Giving it agood clean thats all cannot say much more than that
  • kakima Nov 26, 2014
    Can you say what make and model device you're asking about? I take it it's not a cell phone, but...
    Problem Solver:
  • 5 Answers
Instructions
1.Remove the faceplate around your stereo. Slip a flat object under the edge and gently pry it up. A flat-head screwdriver works well. There will be clips holding the faceplate in place, so feel for them. You may need to move your faceplate up or down to slide it out of position.
2.Find and remove any screws holding the stereo in place.
3.Slide the stereo component out far enough to see the label on top of the stereo. Write down the model and serial numbers of your car stereo component.
4.Locate your VIN number at the base of the front window, driver side. If you can't read your VIN off the window, you will have it on your proof of insurance and title as well. Write it down.
5.Locate your car manufacturer's toll-free Customer Service number and call them. Click on the link in the Resource section of this article and find your car manufacturer's toll-free number.
6.Call the number and let customer service know you need your stereo code and have the vehicle's VIN number, as well as the model and serial numbers off the stereo. They will provide you with the code. If you are unsure how to input the code, be sure to ask for support at this time.
Posted on Nov 26, 2014
Testimonial: "A up mr wounderful this item is a house hold shower not a phone. Cheers for now,t"
How do I troubleshoot a goodman 2 stage that always starts at high stage
It wouldn't be stuck if that's the case the valve would never shut off. Sometimes those 2 stage heat thermostats stats call for 2nd stage if the room temp drops more than 2 degrees. Easiest way to check is take the w2 wire off of the tstat and try a call for heat. If the furnace kicks on both 1& 2 stages then its either your wiring on the fan board or a dip switch setting. If it kicks on 1stage then it's your thermostat.
Mar 19, 2013 | Heating & Cooling
My oven does not want to heat up - it always stays on LO? can u help
Do the top burners act properly, meaning giving high heat? Are you seeing black soot or just low flames? Low heat all around possible the gas cutoff in the kitchen has been turned down accidently. not an expert but have experienced the same problem with my new gas stove. The valve was almost off.
Nov 29, 2012 | KitchenAid KGRT607 Gas Kitchen Range
2002 Chev. Traiblazer- heat guage jumps from low value to high values almost instantaneously . The dealer has replaced the water pump and the clutch fan but the problem persists. Sometimes there is no...
Is the engine actually over heating or just the gauge giving incorrect readings?? The stepper motor in the console's temp gauge could be defective. Have someone with a laser heat gun check the temp of the engine around the thermostat to find the correct temp.
Jul 07, 2011 | 2002 Chevrolet TrailBlazer
My Kenmore dryer seems to have a mind of it's own on heating. Sometimes it heats very hot, sometimes little heat at all. It does not seem to matter what setting it is on, low, med, or high. Nor does it...
when was the last time you cleaned it out,try running it with the vent line removed,you need to clean out the duct that the lint filter slides into,vac out the inside of dryer where the motor is,if you have a shop vac put it on blow and blow off the motor and clean out the vent line and the outside vent,if the vent line is long i use a leaf blower to clean out the vent line,also is it gas or electric?next time send model number?if it's gas you could have bad gas coils,when they heat up they fail,clothes are warm at end of cycle.run the dryer for 15 to 30 minutes and check to see if the flame is still lighting if not bad gas coils.hope this helps
Feb 21, 2010 | Kenmore Dryers
My nespresso aeroccino machine seems either quirky or moody: sometimes it froths the milk, and other times it just kind of heats it up and stirs it, even though I'm pouring the right amount of milk in and...
THEY SAY MILK MATTERS. SKIM OR LOW FAT BEST. ALSO MAKE SURE IT IS CLEAN, WHEN YOU ARE CLEANING IT, REMOVE THE FROTHER, TO BE SURE MILK DOES NOT STUCK IM COIL, WHICH CAN MAKE THE FROTHER, NOT MOVE AS QUICKLY AROUND.
Jan 19, 2010 | Nespresso Aeroccino Automatic Milk Frother
Manual Transmission seems to be stuck in low range. Transfer case in 2wd high range, however when transmission is shifted to 5th gear still only going 25 mph at 4000pm. Clutch seems to be engaging and...
The transfer case is stuck in the low range. If manual shift try shifting from low to high several times to see if free up. If electronic, check all fuses and make sure you hear transfer case change range. Do this by shifting with key on engine off. If no change refer to qualified transmission mechanic.
Dec 25, 2009 | 1990 Ford F250
Our Jaccuzzi Magnum Force pump extremely low pressure
Giving it a good cleaning probably clogged the pump impeller. If you vac'd the pool and the pump basket was packed with debrie it probably passed through and clogged. Split the pump and inspect the eye of the impeller. Low pressure means low flow.
Aug 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My air conditioning unit is not blowing as cold as it did, nor is it blowing as hot as it did in the heating mode
90 percent of the time the freon charge is low and lack of freon lessens the amount of compressed heat that can be created and also the amount of heat that can be extracted. hence less cooling and less heating. however the exact same thing can occur when a change over valve gets stuck partially between heat and cool . it then mixes the hot and cold together and you get poor cooling and poor heating. you check it with a gage. fed law requires that you have an epa certification to apply a gage. low pressures in heat and cool on both high and low pressure gages are a sign of low charge. if low pressure and high pressure are close to the same on both gages then a good chance valve is stuck half way between. you can also sometimes check by feel . at the change over valve two lines should be virtually to hot to touch and two should be cold to the touch. one is heating flow and other is cooling flow. if the valve is stuck then temps will be within a few degrees of the same on all. low charge and the hot lines won't be hot hardly .and the cold line s barely cool. look for white frost forming in the heat mode outside at the condensor tubing shortly after you turn on the heat. thats a sign of low charge. good luck.
Nov 04, 2008 | Heating & Cooling
Electric cloths dryer, turn on runs 5min and turns off
upper limit switch being triggered, need to check lint in the exhaust line, seems over heating, not much air is flowing thru the heating coils, upper limit switch is resseting by itself. needs agood general cleaning of all the inside parts and duct lines...
i hope i was able to solve ur problem..
tnx,
drcool
Jul 22, 2008 | Dryers
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
