Question about Refrigerators
Mantiwoc ice machine
Uneven ice formation . Ice is thinner at top gradually thickens towards the bottom. Bin switch fails to open every time. Bin switch is new.
  • 1 more comment
  • John Tripp
    John Tripp Nov 27, 2014
    Tom what is the model number of your ice machine maybe I can find the service manual that way we can look up what's going on
  • tom
    tom Nov 27, 2014
    mantiwoc qy0424a
  • John Tripp
    John Tripp Dec 02, 2014
    There is a sequence of events that are disrupted when the ice machine fails. If you would like my assistance solving this please let me know. You should be getting a flash of lights that will usually identify the source coming from the controller. Contact me here or the link below and I will help if you don't see the problem by following the Service Manual.
    Director Badge:
    Uploaded 100 video answers.
  • Refrigerators Master
  • 488 Answers
try to run a full clean cycle with nickel safe cleaner.
Posted on Sep 02, 2015
  • 4,655 Answers
Click here=> Manitowoc Q-Model Service Manual Manitowoc are good about help Click HERE sorry I just got back and saw your model number. If you have questions please let me know, Thanks John TrippAppliance 911
Contact Me Here
Posted on Nov 29, 2014
catriver
  • 878 Answers
SOURCE: Ice Maker
Sassy, the red led should flash 2x followed by a pause, repeatedly with the door open. If you hold the left side flap down, it should stay on steady. If it does this you know the optics are ok. Sounds like you just hooked it up to water. The ice maker thermostat has to be at least at 17 degrees before it will call for water and then it will have to prime the lines to the ice maker first before filling the mold. The easiest way to reset the icemaker is to unplug the refer for 30 seconds. Other things you want to check are that the ejector blades (blades that push the ice out) are in the 2:00 position. Check to see that the fill tube that fills the mold is not frozen over. I have a feeling that your lines just needed to be primed. Hope this helps you understand this unit a little better...Catriver...post back.
Posted on Apr 05, 2007
Merkader
  • 21 Answers
SOURCE: kitchenaid superba ice freezes in the bin
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
Posted on May 01, 2008
marked
  • 6487 Answers
SOURCE: Kenmore Elite Trio Refrigerator - ice maker shut off arm
This link will be helpful to your problem , check this out this is the link for it http://www.fridgedoctor.com/fridge-doctor-book/ice-maker-not-working.html
Hope that helps........
Posted on Aug 26, 2008
  • 10865 Answers
SOURCE: Ice maker is not making ice
hello. i can help.
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Small or too few ice cubes If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly.
Posted on Jun 25, 2009
aasc
  • 1606 Answers
SOURCE: DSS25KSRD SS GE Adora refrigerator- ice in tray
It sounds like the # 4 thermistor is bad . You will have to remove the lower inside rear freezer panel ( 2 or 4 screws ) and on the top of the coils , you will see a 1 " long torpedo looking piece , clipped on , with 2 white wires going to it . Part number WR55X10025 . This thermistor , tells the maon control board , the temperature of the freezer coils ( evaporator ) and when to defrost and when to stop defrosting and turn the compressor back on . There is also a defrost thermostat which cuts the heater off to keep from over heating , but I do not believe this is part of your problem . You should also replace the # 5 thermistor , located behind the oval grill , mounted on the lower right side of the freezer . This thermistor , tells the main control board , the temperature of the freezer section .
Posted on Oct 21, 2009
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
To big of icebridge
The ice bridge thickness of this machine should not be over 3/16" check the harvest assist solenoid and plunger during harvest to make sure it is operating. also check freeze cycle controller you will see it has some dip switches with off and on above the switches with numbers to the side of them you can take some freeze time out by starting at the top and moving the switch to off then let it make a batch of ice to see if this made a difference. The less time the thinner the ice. Time added to the controller the thicker the ice.
Jul 07, 2014 | Ice-O-Matic ICEU220HA Undercounter Ice...
Machine has stopped working and is in alarm
Possibly a stuck or defective ice level switch in the ice bin. It's supposed to cease the ice making when the bin gets full and then return the ice making components back on when the ice level drops to a certain level. Should be an easy fix if the switch is bad. The wires have push connectors on them.
Sep 06, 2017 | Kitchen Appliances - Others
We have a commerical manitiwoc ice machine that after the bin fills up it cuts off and has to be reset. After resetting it fills up again and a blinking light comes on telling me that something is wrong....
Manitowac uses a plastic deflector which has a magnet located on the bottom. When the machine drops the ice the deflector opens breaking the circuit to the bin switch. This would indicate "Bin Full" condition. As the ice is used the deflector closes and the magnet comes in touch with the bin switch.
Most likely the bin switch needs replacement.
Feb 22, 2011 | Freezers
My cme 256a8 model scotsman ice melts to fast will not fill my 250 lb. bin in four days. What is the problem? in a hour run time it makes 7 lbs of ice and 4 lbs. water. in one dump cycle it makes 3 lbs...
There are a couple of things to check. The machine must be level. You can remove the front cover and the plastic sheet that covers the plate where the ice is made. Check to see that the water is flowing from the manifold at the top of the plate. You may have to pop the hose off the end of that manifold to clean the water holes out. It must flow evenly over the plate. Probably the most common problem is the radiator coil there the fan draws air through is clogged up so that it can't dissapate heat properly. You should be able to feel a lot of hot air moving through the coils. The fan cycles on and off periodically to maintain a certain pressure in the freon. That is normal. Clean the fan coils and level the machine.
Sep 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Ice machine growles; crushed or cubes
Remove the ice bin and throw out the ice. Run water through the ice bin to clear out the frozen ice in the bottom. Dry the bin really well. Re-install the bin and start over.
Sep 23, 2009 | Fisher and Paykel Refrigerators
I have an ice machine (Ice O Matic) Mod # EC1406HPB2 print # 9071919-01. that runs for approximately 10 mins, than compressor stops, I replaced start and run capicators, same problem. am thinking the Hi -...
You have to remove the bin to access the inner workings and the hi-temp safety is strapped to the suction line. You just look for two black wires disappearing into the line insulation to find it.
To remove the bin you: 1. Unplug the unit. 2. Take the top off and remove the sliding bin door, 3. Remove the front bottom louver, 4. Look straight back and disconnect the drain hose from the bottom of the bin, 5. In the louver opening look in the top corner and there will be a screw in each side going straight up into the bottom of the bin. Remove these two screws and lift the bin up and out.
If you are going to run the unit with the bin off you will have to cover the condenser area so that the air is forced over the condenser and be prepared to catch any ice that is produced.
Aug 08, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Admiral side by side, the ice maker does not seem to making ice
Pull down slightly on the bottom bin lip , and pull the bin foreward . The bin has to lock in place , or it would slide foreward , each time the ice dispensor is used , causing the freezer door to be pushed open from the force .
Jul 11, 2009 | Maytag Admiral Top-Freezer Refrigerator
Melded mass of ice in bin
The only thing I can offer is to limit the out put of the machine closer to what your needs are.Or bag the ice and store in a freezer. The ice pushing down while melting is what is causing the BIG FREEZE. The bin for storage may be too big for your needs, at least at the time you write this. When the demand goes up (warmer weather) the ice would be used more and the pressure pushing down will alternate as well as people getting scoops out more often this will help prevent such a freeze up in warmer weather.
Dec 01, 2008 | Scotsman Cooled Modular Contour Cuber Air...
Ge top freezer refrigerator ice maker problems
most likely bad icemaker but could be a leveling issue or overfilling which both would be very noticable
Jan 04, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
