Question about Directv RC65 Remote Control
How do I connect a directv remote to panasonic SA-HT680?
    Sergeant:
  • 204 Answers
This is what I did & it took all of about 5 minutes.
call tech support for direct TV & they will walk you through the process.
the phone # should be on your bill or you can Google it.
when you call the #, you will get the automated system, say I want to talk to a representative, (tip - if you sound upset to the automated system it will put you through sooner & won't run you in circles for so long, the system is designed to read your responses.)
Posted on Nov 26, 2014
The remote control for my Panasonic SA-HT680 was totally destroyed by 6 year old son (Boys will be boys). I want to replace it with a genuine replacement. Can anybody help me? I have also had the problem...
You can call Panasonic at 1-800-405-0652.
Be ready to give them model and serial numbers to find out availability of replacement remote.
Good luck ( with the remote and your son) !
Nov 29, 2010 | Panasonic SC-HT680 System
I need a code for dvd panasonic home theater SA-HT680 for sony rm-y181 thanks
Future reference, go to www.Sony.com or even google. The users manual is available online and you can get the codes there.
However, I was bored so I looked them up for you.
the code is 753
Jun 11, 2009 | Sony RM-Y181 Remote Control
CD/DVD PROBLEM ON A PANASONIC SA-HT680
Check your "Setup Menu" with NO DVD in the player. Could be the wrong format, should be 720p or 1080i or 1080p. Are you using Component cables to your TV or HDMI? if Component, check your connections, it is color coded but may be hard to see with most installations. Use a flashlight to make sure colors are correct Red to Red, Blue to Blue and Green to Green. Sounds like you've got cables mixed up. It happens to the best of us! and I do it for a living! Hope this helps
May 21, 2009 | Panasonic SC-HT680 System
Low sound when turned to AUX for surround sound
remember to turn the volume up on the cable box and down on the surround sound so you will get max audio input to the surround system and then adjust using the surround sound remote! good luck
Jan 11, 2009 | Panasonic SC-HT680 System
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Jan 27, 2008 | Panasonic SC-HT680 System
Bit rate showing at top of screen
is it possible to play my cable tv through my system
Dec 03, 2007 | Panasonic SC-HT680 System
Code for rmote
do serch on makers website like charter.net then see if they have codes for remote for your model dvd player if so they give u code u can email cust support ther also
Oct 13, 2007 | Panasonic SC-HT680 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Nov 19, 2006 | Panasonic SC-HT680 System
Directv RC65 Remote Control Logo
96 people viewed this question
Top Directv Televison & Video Experts
john milligan
Ed
Level 1 Expert
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
