Question about Vehicle Parts & Accessories
I have tranny code po748 on my vw
I have bought a tranny harness and solenoids that are new only a week old and got code on second day
Well can not resolve trans issues here
I owned a trans shop-- once
Why the new harness?
Why the solenoids?
Who is or has worked on it?
The code & possibly some of the problem
you can google
No way I will tell or suggest to you-- to replace or do
anything
Have a dealer work on that when is comes to VW/Audi
Takes different scan tool software, we don't have or use
in most cases here in north america
Keep in mind that it is mechanical issues & moving parts
that send the signals out to those sensors & then is get
complicated as you get into the electronics
Now you will tell me I am rude & your a professional
No way for me to know who comes here
Posted on Nov 26, 2014
  • Vehicle Part... Master
  • 937 Answers
P0748 Volkswagen - Pressure Control Solenoid 'A' Electrical
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty line pressure solenoid valve 'A'
- Line pressure solenoid valve 'A' harness is open or shorted
- Line pressure solenoid valve 'A' circuit poor electrical connection
What does this mean?
When is the code detected?
Engine Control Module (ECM) detects an open or shorted condition on the solenoid circuit
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission shift shock
P0748 Volkswagen Description
The line pressure solenoid valve regulates the oil pump discharge pressure to suit the driving condition in response to a signal sent from the Transmission Control Module (TCM).
Maybe try and reconnect all the connections.
The engine is misfiring
1 You have a bad O2 sensor.
2 I think this second one may mean Possible causes
- Faulty Pressure Control Solenoid
- Pressure Control Solenoid harness is open or shorted
- Pressure Control Solenoid circuit poor electrical connection
Read more: http://engine-codes.com/p0748_chevrolet.html#ixzz3KgNrIzZY
Nov 30, 2013 | 1999 Chevrolet Tahoe
1999 dodge ram pick up transmission wont shift out of second gear
any codes in diagnostics? was pump checked for proper pressure?
Jan 10, 2013 | 1999 Dodge Ram
What does the code po748 refer to
Symptom:
P-0748 GOV PRESSURE SOL CONTROL/TRANS RELAY CIRCUITS
When Monitored and Set Condition:
When Monitored: Continuously with the key on.
Set Condition: This code is set if the voltage detected on the Governor Pressure Solenoid
Control Circuit at the PCM is different than the expected voltage for 4.8 seconds.
POSSIBLE CAUSES
NO POSSIBLE CAUSES REMAINING
FUSED B(+) CIRCUIT OPEN
SOLENOID AND HARNESS ASSEMBLY DEFECTIVE
GOVERNOR PRESSURE SOLENOID DEFECTIVE
TRANSMISSION CONTROL RELAY DEFECTIVE
GOV PRESSURE SOLENOID CONTROL CKT SHORT TO GROUND
GOVERNOR PRESSURE SOLENOID CONTROL CIRCUIT OPEN
GOVERNOR PRESSURE SOLENOID WIRING HARNESS INTERMITTENT DEFECT
GOVERNOR PRESSURE SOLENOID WIRING HARNESS OBSERVABLE DEFECT
TRANSMISSION RELAY OUTPUT CIRCUIT OPEN
TRANSMISSION RELAY OUTPUT CIRCUIT SHORTED TO GROUND
PCM DEFECTIVE (GOV PRESSURE SOLENOID SHORT TO VOLTAGE)
PCM DEFECTIVE (RES IN RANGE)
PCM DEFECTIVE (GOVERNOR PRESSURE SOLENOID DEFECTIVE)
PCM DEFECTIVE (CONTROL CIRCUIT SHORTED)
PCM DEFECTIVE (SOLENOID & HARNESS ASSEMBLY DEFECTIVE)
Feb 03, 2012 | 1999 Dodge Dakota
Just bought a vw jetta. When i test drove it everything was great. All gears were smooth and reverse worked fine. Now two days later i go out to get in it and back out the drive and it wont go into...
A standard tranny can get stuck in gear while in reverse position, like somebody slammed it into second and the linkage hit reverse instead. Could be minor, then again, It could be major. I hope it is a standard you are talking about, If it is automatic, then no, there is no switch or fuse for this, it has shift solenoids in the valve body that do the shifting, mostly electric now days, a ground wire off could cause this but I doubt it. I would get a hold of the seller and give him back his car. Hope this helps, Tranny work is $1200 minimum.
Jul 29, 2011 | 1997 Volkswagen Jetta
What is code PO748
Here you can find DTC P0748 PRESSURE CONTROL SOLENOID (LINE PRESSURE DUTY SOLENOID) ELECTRICAL
Hope helps.
Jun 12, 2010 | 1998 Dodge Durango
Po748 can tcc solenoid or vehicle speed sensor cause this code
One question? Did you clear the codes out of the system with a scanner? I believe that's the only way to do it now,unlike the old days when you could rest by disconnecting the battery. Hope this helps.
Apr 22, 2010 | 2001 Dodge Ram 1500 Truck 2WD
2002 Jetta, how do I remove the drivers seat?
slide the seat right forward and undo the two bolts in the slider then slide right back and undo the front twothen lift it out.when you put it back make sure the bolts are tight....
Mar 30, 2010 | 2002 Volkswagen Jetta TDI
Code0755 shift solenoid b after about ten miles next day whilst driving in fourth transmission goes into second
If you were to take the solenoid pack apart you would find a bad connection on that solenoid. You sill need a new pack installed.
Aug 11, 2008 | 1993 Chrysler Town & Country
Vehicle Parts & Accessories Logo
87 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
