Question about Sylvania Hd1z Sd/sdhc/mmc 720p Hd Pocket Video Digital
How\can I reset my device?
I tried look for a reset hole, you know like they do sometimes have them on things like this. But the real problem is it won't turn on and it is charged so I'm thinking if I can reset it it may work.
    New Friend:
  • 3 Answers
Try pressing the on/off button and holding it in for about 10 seconds this sometimes works
Posted on Nov 26, 2014
    Scholar:
    New Friend:
  • 80 Answers
Hi Jessica,
If the the problem is curable by a reset, would pulling the battery accomplish your purpose?
All the best.
My 2000 ford expedition wont turn over and I have a new battery and new starter sometimes it sounds like a vacuum
Sounds like your fuel pump died. Do a quick check by having someone just turn the ignition key to on without staring truck while you have gas cap off. If you hear a hum once key is turned on then fuel pump maybe good however has low pressure output. Then do a fuel pressure check. Engine obviously not getting gas. Before you go buy a new fuel pump check and or reset your fuel pump circuit. The fuel pump reset is on the passenger side lower right. You have to take off plastic door railing cover. Easy to get too and the button is red and easy to push. After you reset try again. Good luck. I went thru same thing you did this past december. However it ended up being my fuel pump. A real dirty job. By the way if it is your fuel pump buy the fuel line disconnector tool. And also buy a new fuel filter.
Apr 19, 2015 | 2000 Ford Expedition
My mercedes ml350 won't sart..when i turn the ignition it makes a sound but the engine won't start
I don't know if this is helpful but an engine needs three things to work. Air, fuel, spark.
Jan 15, 2013 | 2006 Mercedes-Benz ML 350
Won't turn on
Some of these have a reset button in a tiny hole in the bottom rear of the unit. Try pressing the reset with a hair pin or a paper clip. then try turning it on again. Hope it works for you.
Jun 24, 2012 | Toro Blowers Rake and Vac - Electric...
Key in ignition won,t turn 2004 ford escape
several things, does key go in and out easily, turn steering wheel in both directions while turning key. sometimes the steering wheel lock binds the lock cylinder and turning wheel releases the pressure and it will turn. other than that the ignition cylinder is jammed, wet key lightly with lubricant such as wd-40 and a light bit in key hole and try key again, If key is heavily worn out , try a different ignition key as it might not be disengaging all the tumblers in lock, if all this fails you need a new cylinder.
Jun 09, 2012 | Cars & Trucks
My Plymouth will not start right away. When you first turn ignition it just clicks. It soo start on 2nd or 3rd try but sometimes won't stay running unless you constanly push on gas. What could this be?
it could be a multitude of things from bad starter, loose or corroded cables,faulty cells,very dirty injectors, etc. You really need a mechanic to look at it or you could be throwing cash at non existent problems and completely missing the real one. Sorry.
Apr 13, 2012 | 1994 Plymouth Acclaim
What do the adjustment screws on a poulan pro chainsaw carburetor look like
I'm not sure about the poulan, but they should just be little holes in the side cover there with a hi and low or H and L, If the engine won't stay running, open the low jet just a hair at a time, no more than 1/4 turn, try throttling it a minute, then see if it will run, If not try it again, do not open it up more than 1/4 turn at a time, the same goes for the high speed jet, if it won't rev. Open it up a hair at a time. Sometimes it will act totally wrong and have to be redone, close both screws, open both screws up 1 turn, then try it again. It is a small flat blade scewdriver just big enough to get in the hole, check it out. Hope this helps.
Mar 17, 2012 | Poulan Pro Chain Saw 46cc 20"
Anti theft light won't go out
There are 2 things to try:
1) Use your key to manually unlock the driver's side door - sometimes this alone is enough to reset your security system.
2) Put your key in the ignition and turn to ON position (do not try to start the car, just turn to ON)- after 30 seconds, attempt to start the car and see if the security light goes out.
Dec 08, 2011 | 2000 Mercury Sable
I was wondering if you could give me some things to check on my van won't start and we tried jumping it. The lights all come on with full charge . So I was wanting to know if there is a reset button...
if u unplug your battery for acouple hours it will reset youre ecu/cpu. (everything) does it turn over? or absolutly nothing? if nothing sometimes ur battery loses so many electrolytes it can't retain a charge therefore jumping won't help. new battery first step! local junkyards probably have a good battery for $20. Let me know if this helps.
May 15, 2011 | 2009 Volkswagen Routan
Every time I try to turn on my MP3 player it reads OPAL (in blue) initializing... what do I do?! PLEASE HELP! :)
Not sure about this model but look on the back for a real small hole. This hole is a reset button. Using a paper clip end (straighten one out) press in the hole to reset the player.
Oct 29, 2010 | RCA OPAL M4001 MP3 Player
Water does not come out of the port hole all of the time.
you might just have dirt in the water view port try a real smal drill bit BY HAND to clean the hole . if the morot doesn't run hot then you really don't have a problem
Apr 27, 2010 | Boating
Sylvania Hd1z Sd/sdhc/mmc 720p Hd Pocket Video Digital Logo
113 people viewed this question
Top Sylvania Video Cameras Experts
ray gallant
Are you a Sylvania Video Camera Expert? Answer questions, earn points and help others
