Question about Whirlpool Ovens
Whirlpool Accubake Wall oven pre heat but temp goes 350 and downwards when pressing temp up
Have a Whirlpool Accubake Wall oven, RBS305PD86 just did a self clean, after oven starts on pre heat but temp goes 350 and downwards when pressing temp up on pad from 350-345-325 etc. replaced the them sensor already what gives
    Visited the website for 20 consecutive days.
  • Whirlpool Expert
  • 84 Answers
If the Whirlpool oven bakes great at 350 degrees, then the problem your having is with the membrane circuitry = The touchpad/keypad on your oven is faulty. The button itself is bad.
You can read more about this issue here --
Replacement touchpads are available for your unit through
Whirlpool Models that normally experience this issue below -- GBS277PDB0, GBS277PDB1, GBS277PDQ0, GBS277PDQ1, GBS277PDS1, GBS307PDB0, GBS307PDB1, GBS307PDQ0, GBS307PDQ1, GBS307PDS1, GBS307PDT1, RBS245PDB1, RBS245PDB2, RBS245PDB4, RBS245PDB6, RBS245PDQ1, RBS245PDQ2, RBS245PDQ4, RBS245PDQ6, RBS248PDB4, RBS248PDQ4, RBS275PDB1, RBS275PDB2, RBS275PDB4, RBS275PDB6, RBS275PDQ1, RBS275PDQ2, RBS275PDQ4, RBS275PDQ6, RBS277PDB1, RBS277PDB2, RBS277PDB4, RBS277PDQ1, RBS277PDQ2, RBS277PDQ4, RBS305PDB1, RBS305PDB2, RBS305PDB4, RBS305PDB6, RBS305PDQ1, RBS305PDQ2, RBS305PDQ4, RBS305PDQ6, RBS305PDZ1, RBS305PDZ2, RBS305PDZ4, RBS305PDZ6, RBS307PDB1, RBS307PDB2, RBS307PDB4, RBS307PDQ1, RBS307PDQ2, RBS307PDQ4, RS675PXEB0, RS675PXEB2, RS675PXEQ0, RS675PXEQ2, RS675PXEZ0, RS675PXEZ2, RS675PXGB0, RS675PXGQ0, RS675PXGZ0, RS676PXEQ0, RS676PXEZ0, RS696PXEB0, RS696PXEB2, RS696PXEQ0, RS696PXEQ2, RS696PXGB0, RS696PXGB2, RS696PXGQ0, RS696PXGQ2
Posted on May 05, 2017
  • 24 Answers
I am not sure about this, but sounds like a connector is on backwards or in the wrong place.
Posted on Nov 26, 2014
how do I get my self cleaning to come on in my hotpoint stove
Posted on Oct 13, 2008
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I did unplug/turn off the circuit and am alive to share this update! Right off I noticed that the ribbon cable was loose. For those who have tinkered around with other electronics such as a PC, etc., note that this ribbon cable is not secured by the connector (atleast in my case). Reseated the cable and turned the power on. Voila- the bake option works. Tested it by turning it on for 20-30 seconds. Touched the bake element and got proof that it was working fine (via a singe of the ring finger ;-)).
About three minutes or so later, the display started to beep with an error code - E0 F2. A shorted keypad is what it stands for. The clock was still operable. I could still select the bake option, broil option, etc. Ran a test bake cycle but it turned off after a minute or so and started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat ribbon cable. Turn power on and test by holding the Cancel button for five seconds. Still displays the E0 F2 error. Waited for 10 minutes but this time no more beeping or error display. Ran a preheat cycle for 4+ minutes without any problems. The oven warms up and the bake element glows red. Hopefully, all is well. Will see what it does when we bake something the next time.
Thanks to PropHeadTwo and others for their contributions.
Posted on Dec 18, 2008
SOURCE: oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Posted on Dec 21, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 725 Answers
SOURCE: I have a Whirlpool Self
When you use your self clean feature, your oven heats up to over 800 degrees and this normally takes your electronic computer control board out.
Posted on Oct 22, 2009
I hav whirlpool accubake.oven wont stay ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
I have a whirlpool Gold Accubake System When turn the oven on turn up temp, only goes to 260 c what is the f under c how to change to f to make the temp go up to bake if problem with temp explaincf
To change: Press and hold PRECISE CLEAN for 5 seconds. A tone will sound, and "°C" or "°F" will appear on the display. Repeat to change back. To exit, press CANCEL/OFF.
Nov 28, 2015 | Whirlpool Ovens
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
Good Evening!
This is a common problem that Ledgestone Technologies and can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
Whirlpool Oven Wont Increase Temperature Stuck at 350
May 27, 2017 | Whirlpool Ovens
Oven won't pre-heat
This is a failed oven temp sensor. the control is not receiving a proper resistance signal from this sensor at this time. the control will shut down the unit if this is the issue. check the oven temp sensors connections form the control to the sensor housing for loose or worn contacts, if the wiring is ok, replace the temp sensor.
Sep 24, 2009 | Ovens
Whirlpool accubake oven (elec) E-2 F-3 fan running oven wont't heat all other functions normal
Hi, your oven will not heat if the temp sensor is faulty or damaged. this code represents a non-responsive oven temp sensor.
Replace Oven temperature sensor (RTD)
Aug 15, 2009 | Ovens
Whirlpool Electric Wall Oven RBS275PDQ6
had same problem, had computer checked out by profesisonal. Was ok. But it seems it is the control pad that clean cycle screws up. Try this (thanks to my wife and her experimental prowess). 1. turn oven on to custom broil. 2. push down temp button to 375. 3. press bake button. 4. You should now have up or down temp. We think you have to get past pre heat cycle in order for this to work. But work it does.
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Dec 18, 2007 | Ovens
Ovens Logo
403 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
