My plasma swiches on for about 5 min than swiches of orange light comes on i switch it off on the power button and it comes on again. sometimes it comes on by it self. some times it plays for 2 hr
My plasma swiches on for about 5 min than swiches of orange light comes on i switch it off on the power button and it comes on again. sometimes it comes on by it self. some times it plays for 2 hrs es
Sounds like a bad power supply. When it gets warm, it shuts down.
Posted on Nov 26, 2014
    Scholar:
  • 80 Answers
Hello!
I would check the owners manual, in the troubleshooting section under "orange light". As SS observed, may be a power supply, but that colored light is designed to provide a clue. Lacking a manual, call the manufacturer service line. Even out of warranty, they can be very helpful. And dare I mention Google here ? ??
Also, symptoms sound like an overheating issue, the bane of solid state electronics. Check all the ventilation slots on the set to ensure there is good air circulation. Plasma's run much warmer than LED sets.
All the best.
MerlinTech
  • 197 Answers
SOURCE: Canon iP4300 is noting "offline or no power" blinking orange light 3 times then turns off
maybe you have some driver issues..
go here, get new ones, re install
Posted on Jun 16, 2008
AlmostBob
  • 550 Answers
SOURCE: Orange LED blinks 5 times then a 2 second green
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
If you type in 'flashing power light' in the problem box, for 5 you get print head failure, often it means the connectors between cartridge and print carriage are dirty, can be cleaned with a pencil eraser and a soft cloth. there is a sequence of checks and repairs to follow on the canon service page
Posted on Sep 02, 2008
cene765
  • 787 Answers
SOURCE: Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Posted on Oct 30, 2009
pineworks
  • 4041 Answers
SOURCE: printer orange light flashing 2 and 5 times, servive error 5100
Hi You can Try 2 things.
All the luck for you
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
SOURCE: If I am not printing continuously, the printer
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Posted on Jan 14, 2011
Orange light is on ,printer does not operate
click the power button for 5 mins nd click again to open it . .
Jun 12, 2016 | Brother HL-2070N Laser Printer
Have PT50LC13 that will not light up when power button is turned on. The power button just blinks orange 5 times consecutively with a 2 second delay between intervals.
The light flashes 5 times consecutively with a 2 second delay becuase it denotes there is some internal problem in the TV.So please consult your near by service centre.They will come and fix the problem.You cannot do anything .
Thanx
Jul 23, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
How can you remove a 5100 error with a canon mp210?
1. Switch off the printer (the button, rather then from wall-plug
2. Press and hold Resume
3. Press Power
4. Holding Power , release and once again two times press Resume , then release simultaneously all button.
5. After indicator is flashing, fall into service rezume.
6. Four times press the button Resume , under each striking Resume indicators are switched: green-orange. Once press the button Power for acknowledgement of the selected action (the unset of the counter pampers). The Button Resume enter prefunction:
- 0 strikings unset main counter in 0%, or
- 1 striking unset additional (platen) of the counter in 0%, or
- 2 strikings installation both counter on 0% .
7. Press Power (is executed service-function, chosen striking Resume )
8. Once again Power - swich off.
Sep 22, 2009 | Office Equipment & Supplies
Samsung 50'' Plasma TV won't turn on anymore
If your tv is within the one year warranty period then call 1-800-Samsung for warranty repair. Look at your tv purchase receipt for the Purchase Date. You have one year from the date of purchase to get warranty repair.
Jul 08, 2009 | Televison & Video
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
Yamaha snowmobile starting issue
sounds like the starter is sticking!
Dec 09, 2008 | 2008 Yamaha XT 660 Z Tenere
TV switch off randomly
It is a Rely in the Power Supply. Need to have it changed out. Cheap part.
Dec 29, 2007 | Samsung HP-R4262 42 in. Plasma Television
Samsung SPN4235 42" Plasma
green light flashing no video but audio, on/off switch in operable
Nov 12, 2007 | Samsung SPN4235 42 in. Plasma HDTV
jasbo
jasbo
