Question about Jandy Pool & Spa
Jandy LJ400 temp. indicator reads 97 temp set at 84 heater wont fire when i raise the temp to 100 it lights. what do i look at
  • 937 Answers
Bob, sounds like it is working as designed. If the temp indicates 97, of course it won't fire if you set 84 as the temp (97) is already above that. When you set 100, it is higher than 97 and the unit attempts to raise the temp those 3 degrees. If you don't think the water is already at 97, then there is a calibration problem with the temp sensor.
Posted on Nov 26, 2014
Testimonial: "i might not have explained it right. the water temp is at 79, unit set at 84, reading on unit indicates that the water temp is at 97 but we know from actual water reading its 79"
  • mbarre Nov 26, 2014
    OK, so the unit is not reading the temp correctly. If there is no ability to calibrate the temp sensor on the unit, it must be replaced. If the unit "thinks" the water is at 97, then it won't fire till you set it above what it's sensor is telling it.
  • 22 Answers
SOURCE: Jandy lite 2 LG pool heater
ignition control board failure
Posted on Feb 18, 2009
  • 22 Answers
SOURCE: Jandy, Lite 2 Pool heater wont kick in
3/4 pipe line will work and will keep heater from sooting up.
  • 83 Answers
SOURCE: Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Posted on Jul 10, 2009
  • 990 Answers
SOURCE: Water Temprature read 126 on heater and will not Fire
This is a problem with your thermister (heat sensor) You will find this on the left side of the water manifold about half way down. I'm not sure but I think it is a small tube that slides into the manifold and if you follow the wires back to the board it just plugs in. The part is reasonable priced for a heater part and very easy to install. Good luck.
Posted on Dec 21, 2009
  • 990 Answers
SOURCE: jandy aqualin rs air temp malfunction
Check this by swapping your air sensor with your water sensor. (Just swap the plugs) if it still reads off then you may need a new board, if this reads ok then the new sensor may be bad. Good luck.
Posted on Jan 20, 2010
Jandy panel reads 89 degrees, sta rite heater panel reads the right temp 78.
Standard 10K ohm sensor appears to be compromised. Replace it.
You have one for water temp, one for air temp, and one for the solar if you have one.
Feb 14, 2014 | Jandy Pool & Spa
I have a jandy LT200 propane heater which doesn't turn on. When power is on the lights on electronic board all flash once and then go off. 2amp fuse going to transistor is fine, not blown. I replaced the...
If this heater is hooked up to automation check the temperature reading on the indoor remote. If it reading over 104 the sensor is bad and the heater will not fire thinking that it is at set temp.
Oct 29, 2013 | Jandy Laars Lt 250,000 Btu Heater
Heater will not come on.
controller temp sensor bad
Jan 06, 2013 | Pentair Mastertemp Heater
Jandy lx250 won't keep water hot
what size pump motor slow the water down put a bypass in
Feb 27, 2012 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Cannot get temp to raise
I would go for the sensor first. It is in the easy to afforde range and easy to install along with more sucpeteable to falure.If that dosen't help then you can still try the board.
May 28, 2010 | Jandy Aqualink Rs4 One Touch Control...
The pool heater temp is set at 84 deg F, yet the pool water is at 78 deg F. What's wrong? Please send answer to: janapavlov @yahoo.com Thanks, Vlad
what is the tem at the heater do you have a automatic control what is the temp here may need new temp sensor but dont have all info
Jul 15, 2009 | Jandy Laars Lt 400,000 Btu Heater
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool & Spa Logo
102 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
