Question about GE Washing Machines
I am looking for the back suspension rod for the GE WJSR2080 T Washer. Do you know the part number and where i can buy it
  • GE Master
  • 932 Answers
Tony, you may have to check with a used dealer in your area if you have one. I checked a couple of different models from the number you gave on the Sears website, and they said that suspension rod is no longer available. Sorry!
Posted on Nov 26, 2014
4 Suggested Answers
  • 6277 Answers
SOURCE: wm2301hw front load LG washer vibrates so badly
I apologise if you have already carried this out but I would suggest following my general guidance notes on balance and stability below first ;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine (sorry about my UK spelling!) and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal drum suspension is malfunctioning.
Good luck,
John C
Posted on Mar 03, 2011
rickead1
  • 1998 Answers
SOURCE: exploded view GE WPRE8100GOWT the bucket
hello this is the schematic for your entire machine click here http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-WPRE8100G0WT/0432/0153200?searchedModel=WPRE8100G&blt= and this is the blown up version of the drive and motor area of the unit as well click here http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fG6090002-00004.png 414 and 415 are the main stabilizers for this unit is this what your talking about or if it is another piece message me back which number it is in any of these diagrams I await your reply Thanks Rick
p.s this is the part number for 414 WH16X10057
and this is for part number 415 WH16X545
Posted on May 29, 2011
richroth
  • 9472 Answers
SOURCE: suspension rods
What is the problem you are having?
Posted on Nov 20, 2012
GE washer wle4000b1ww won't spin with clothes in it but will spin when empty.also the spin light blinks,I have checked the belt and the belt is good please help mother of 2 thank u
Normally, when a washer will spin without cloths, the washer is doing all the basics correctly. But when you add cloths, which means adding weight, the washer will not, then its a suspension rods issue. The suspension rods absorb the weight and allow the washer to spin.
May 25, 2016 | GE Washing Machines
I have a Whirlpool Cabrio washer Model number WTW63003WO that gets off balance and displays a UL code.
It's important to check the level of the unit, and assure all adjustable feet are firmly planted on the ground first. A very common problem with these units are the suspension dampening rods, when they get weak they allow the tub to move around too much while spinning, and sometimes washing. A simple test by an experienced technician who knows what to look for would be to reach into the wash basket while the machine is empty and off, and push the tub all the way down till it stops, the technician will be looking for the amount of resistance it takes for this to happen. The easier it is to push the basket and tub assembly down to the end of it's travel the weaker the suspension rods are. At least one update to these suspension rods have been made, suggesting the current replacements are stronger. Part# W10247710, based on a model number of WTW6300WW0. Pleazer Appliance...
Apr 17, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Suspension rods
Nov 20, 2012 | Washing Machines
Washer squeaks When washing and rinsing on the right side upper drum.
There are four suspension rods that the tub hangs on. When the washer is agitating the tub will rock back and forth and the rods will move back and froth as well. To fix this noise, lift up in each rod and put some lubricant in the cup that the rods fit into at the top of the washer.
Note that it is best if you use a lithium-based lubricant rather than silicone based lubricant.
Dec 23, 2010 | GE WBSR3140DW Top Load Washer
Ge profile washing machine
Feb 18, 2010 | GE WBSR3140DW Top Load Washer
I have a top loading GE model WBB3300 that is making noise
Use a putty knife to push in the retaining clips (2) in the seam between the front panel and the washer's top, allowing front panel removal. Push tab at back of lid switch forward to allow lid switch to be removed from washer top. Remove screw on each side near top, allowing washer top to be removed. One at a time, you can unhook the suspension rods at the bottom by lifting up on the tub support frame and unhooking the rod. Lift the rod a little at the top and apply a wad of lithium grease in that ball and socket joint. Rehook the rod at the bottom, and move on to the next rod. Reassemble.
Nov 23, 2009 | Dryers
GE washer does not agitate does not stop filling up
If your washer is filling until it overflows without agitating, and will stop filling if you turn machine off or interupt power to it, the machine is not seeing that it is full. This may be caused by a blocked water level tube (usually some "goop" where it connects to the tub), a hole in the water level tube (look near the suspension rod or where a mouse may have chewed a hole in it), or a bad water level switch. You do not state a model number, or even if it is a top loading or front loading machine, so that is the most information I am able to provide at this point.
Oct 19, 2009 | GE Washing Machines
Loud clicking/thumping in rinse and spin cycle
It doesn't look like a motor problem !!! It seems like an unbalanced tub issue. The machin has suspension dampers and suspension rods, and it's look like one of them was damaged or "run away" from its location during machin's movement. Goog luck !!
Jun 14, 2006 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
