Question about Cell Phones
Any calls I get ring only two times (not enough time to answer it) Can I change this?
Nada
    Problem Solver:
  • 14 Answers
Call your carrier. They can adjust the default rings before it goes to voucemail
Posted on Nov 26, 2014
How do I change the number of rings on my Alcatel?
The number of rings is set by the phone service, not by you. And don't mistake a bunch of rings when calling. At times, the phone doesn't connect to the number for the first few... So it can ring 6 or 8 times before getting to voicemail.
Nov 26, 2014 | Alcatel Cell Phones
Extend ring time
this feature is set by your carrier. Call customer service and ask them to extend rings to 6 - 8.
Jul 26, 2014 | Motorola Cell Phones
Panasonic number ring
Answering system settings
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
Jan 16, 2014 | Lands Phones
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
When my 8110 rings it only rings 4 times and I keep missing calls because I cant answer it quick enough. How can I change the length of time it rings for,thanks,Bill
select your profiles which is the little loudspeaker icon. scroll all the way to the bottom you should see advanced. select advanced, selcet your profile that is labeled as active. you will then be able to customize the entire profile.
Dec 14, 2009 | RIM Blackberry 8110 Cellular Phone
I have a Uniden 5.8GHz DSS8955+1 and it's connected to my phone and fax. The problem is: everytime the fax rings, the answer machine works as it works when is a phone call. How do I set up the machine not...
Set your answering machine to pick up after four rings2.gif . This will give the fax machine enough time to take the call if it senses that it's an incoming fax. Setting the answering machine to pick up after four rings would give the fax machine enough time to accept the fax.
hope this was helpful .
Nov 13, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
How can i change the ringer on my fax machine?
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Dec 10, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Phone Doesn't Ring Long Enough Before Going To VM
The phone you have can be used on different Avaya phone systems that program differently. It is certainly something that can be changed but you would need to know which system you have first. There is a call-forward no answer timer that send the call to another station or voice mail box etc.. after so many seconds. That is what needs to be changed.
All the manuals are available at www.avaya.com but again, you would need to know which system you have before looking for the manual.
Nov 15, 2007 | Lucent PARTNER18 Corded Phone
Cell Phones Logo
49 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
