Question about AGA Kitchen Ranges
Boiler shut off when i removed top plate. I found it nearly full of soot. its a two oven 15 year old kerosene aga cooker. what is the reason for this?
    Top Expert:
  • 3,698 Answers
Not enough air.
Posted on Nov 26, 2014
  • 1462 Answers
SOURCE: Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
Posted on Mar 31, 2007
  • 7 Answers
SOURCE: Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Posted on Jan 07, 2008
  • 1462 Answers
SOURCE: I have a Belling 755
almost certainly the thermocouple is faulty
Posted on Oct 08, 2008
grandadfixer
  • 99 Answers
SOURCE: Both electric ovens do not work.
Have you set clock time?
Posted on Oct 11, 2008
  • 3 Answers
SOURCE: Old Rayburn/Aga, 1964, to remove the top? 4 chrome
remove the chrome studs, under them you will find threading for the screws.
Posted on Sep 22, 2009
Testimonial: "many thanks a great help "
My old oil-fired Aga has started sooting up and the temperature falls within a month. My oil supplier says a c onstituent has been removed from the oil when it is refined and has given me an addative which...
sooting is an indication of incorrect air/fuel ratio
too much fuel and not enough air
as the fuel has changed in quality so the jet sizing may need reducing or the blower fan needs to go faster
get in a boiler professional or change the fuel brand and supplier
Nov 17, 2017 | Gaggenau EB290 Electric Single Oven
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
What boiler?
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 22, 2009 | Combi Centre DX - Mango
Smokey ovens
Hi, yes, it is a pity that this occurs.
In my opinion, an oven only can smoke for the next reasons:
1 burning insulation.
in this case the oven will not work long, so I think it is not the
problem
2 there are foodrests in the oven
but as you clean the oven regulair, this also will not be the
source of the problem.
3 the methode of cleaning is the wrong one. This cooker has
selfcleaning ovens
here you can find the User Manual of the Masterchef 100DF
http://www.rayburn-web.co.uk/Prodin/UNITED%20KINGDOM%20and%20IRELAND/AGA/2.%20AGA%20Discontinued/Aga%20Masterchef%20Mk1/Masterchef%20Mk1%20100%20Dualfuel%20Manual%2005-06%20EINS%20514327.pdf
I hope this helps, Dik
Feb 15, 2018 | AGA Kitchen Ranges
Warmer lights up but not getting hot - Rangemaster Toledo XT
Hi Sally
I havd exactly the same problem. I contacted Rangemaster/Aga support line (0845 603 5312 if in warranty, 0870 789 5107 if not) and they told me the heating element was shot.
My cooker is 2 1/2 years old, so out of warranty, but they were good enough to send me a new cooker top (top left hand side only of course) free of charge!!!, I just have to get it fitted.
You have to replace the whole left hand side of the cooker top too - the burner that the wok goes on!
Good luck
May 08, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Beckett burner; I notice small particles of soot under stack vent
The soot can be caused by a number of reasons, if it was recently cleaned, I would wonder if the service tech just left a little mess behind. If you are reasonablely sure that is not the case, one cause could be a faulty pump. Inside the fuel pump is a pressure regulating valve, that is responisible for pump pressure and cut off. If the valve is failing, and not giving proper cut off, then a small amount of oil will drip into the chamber (called "after drip") and upon start up this oil burns incompletely causing a soot build up. A delay valve often masks the problem by providing the positive shut off electronically. Another problem/cause could be impoper adj. of the burner during the tune-up. On a final note, with equipment that old, it would be a good idea to start looking into a newer, more efficient system.
Apr 10, 2009 | Leviton White Decora Oil Burner Rocker...
Beko dc543 oven and top left top right bottom right hobs not working bottom left hob is working and so is grill i have checked all terminal wires and all ok i had this problem before under...
I AM NOT AN ELECTRICIAN ! But i have had the same problem of the oven and the back right ring not working and have found the cause of this. For some reason there is a thermal fuse running inline on a live wire inside the cooker if you feel competent yourself in replacing this fuse you will save a good deal of money on call out fees, here is how to do it. SAFETY is the crucial, First of all isolate the power source to the cooker, pull out cooker so you can get access to the back of the cooker, remove the 9 screws ( i think there is 9) to remove the back plate from the cooker, this is quite heavy because there is a small block of concrete fastened to the bottom left hand side of the back plate, looking at the inside of the cooker on the right hand side you will see a white wire which has been secured via a small screwed clip, this wire has a transparent sleeve covering the thermal fuse, remove the sleeve by sliding it up or down the wire, check the fuse by with a meter just to be sure, if it is blown cut the fuse out. replace fuse the same way it was fitted. replace the sleeve and fit the back on the cooker SAFETY FIRST switch on power and try oven and back ring, mine works fine. like i said at the start i am not an electrician, but i can not understand why there is a thermal fuse running inline to the oven which is linked the back right hob. all the best folks Hobbo from Chess.
Mar 23, 2009 | Jenn-Air JES9860 Electric Kitchen Range
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Calor gas and cookers
You need a C.O.R.G.I. (soon to be re-named "gas safe" in april) engineer qualified for LPG to sort this.
Jan 04, 2009 | Cannon 10476G Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
107 people viewed this question
Top AGA Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Paul Carew
Tom Chichester
Are you an AGA Kitchen Range Expert? Answer questions, earn points and help others
