Question about Envision Televison & Video
I own an envision flat screen tv L37W698. I was getting no sound unless I left it on for about 20 min. Then turned it off and back on immediately. Now that doesn't work. I get a wonderful p
For a while if I let the tv run for 20min Or longer longer and the turned it off and back on the sound would come on. When that no longer worked I unplugged everything for a while, then turned it back on, let sit for 30 min, turned off and on. That worked for a while. Now nothing works.
  • 26 Answers
The problem was the e prom on the main board
and has now migrated to the rest of the board.
to fix the set r & r the main board and your good to go
Posted on Nov 26, 2014
  • 27 Answers
Almost certainly, this is a failing power supply. Not uncommon and usually it is because of 'blown' capacitors. Google using your model number and 'power supply fault L37W698' and you'll find your ansdwer there - along with options to repair it if you know someone who can resolder capacitors.
    Top Expert:
  • Envision Master
  • 75,581 Answers
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
  • 16 Answers
SOURCE: Won't turn on
one of the inverter transformers has gone bad replace the bad one and the set will work fine ,there are 6 transformers in the 32".
Posted on Oct 09, 2008
rylee_smith
  • 8619 Answers
SOURCE: vizio 42 hdtv mo picture,no sound
Hi
Thanks for using FixYa. Please check the following—
1. Is Power board output +5V?
2. Is J1 (#19 in the right diagram)connector good?
3. Is DC-DC OK, check the voltage at J1 using a multimeter.
4. Is U4 (3.3V) working ok, U4 is an IC, you’ll need an IC tester or an oscilloscope to check this IC.
After checking this if it still doesn’t work then check P3 D-sub Input (on the D-board). See this schematic for details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 17, 2009
  • 8457 Answers
SOURCE: My LTV32w1 Westinghouse TV keeps shutting off
Ur tv power supply have dying leaking parts call capacitors.The board where the power a/c cord plug into it.That the power supply board.U know basic electronic's,have the tools and know basic soldering?Searches the power supply board for these dying leaking capacitors and replace them,ur tv will power up normal an last.These dying about to be dead are alway bulges up on tops or puff on it tops.These Capacitors must be replaced.Or tries websites like Shopjimy.com,Ebay.com to buy a whole refurbish power board for the replacement.
Posted on Jul 05, 2010
Envision L37W698 tv
Could be either the main or power supply
Feb 05, 2018 | Televison & Video
My TV model l37w698 envision has picture but no sound it did for a little bit but now no sound comes out. Does anyone knows whats the issue.
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Jan 12, 2017 | Envision Televison & Video
Envision menu lock
Refer its user manual for details. Try this link to download the manual. Envision L19W698 LCD TV User Manual
Feb 03, 2014 | Envision Monitors L19W698 19 in. LCD TV
Envision tv
simply has moisture issue..button should be cleaned or hit slightly the button..may be it will help
Dec 17, 2013 | Televison & Video
Envision tv L37W698
Try to use a different code for remote control, sometimes all buttons not working properly
Where is baclight inverter located on l37w698
this is where the screen back light ( CCFL ) connected which the 24v connected in the power supply usually in the left or right side of the rear panel of the monitor.
Aug 18, 2012 | Envision Televison & Video
Envision L37W698 LCD TV sound will not come on when turned on unless we turn it off & on a few times. Then once it comes on, sometimes when we change channels (DirecTV) it will go off again.
I would suggest unplugging set and the box you are using--let sit for a while with no power and plug back up----both the set and box will power up and try to reboot as issue may be related (most likely) to one of them..
Another simple test you can try first is see if this happens when a DVD etc is played--if it does not I suspect a glitch with your box or set.
May 27, 2012 | Televison & Video
My envision lcd l37w698 wont turn on and it has a ornge light that steady blinks
DEAR user,
its supply capacitor may be weak so that's why its not turning on.
Feb 08, 2011 | Televison & Video
My tv will not turn on, it turned itself off and I can't turn it back on, there is no response at all when I hit the power. The day it stop working it was a very warm day. model L37W698.
Possible that the TV has a failed power supply , so check the mains power supplywhich is a SMPS. Please checck this link below for some tips
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
If the power supply works and there is voltage to the processor , the set must trigger. if not check the mains board for dry solderings, burnt drivers /capacitors.
Feb 05, 2011 | Envision Televison & Video
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Televison & Video Logo
136 people viewed this question
Top Envision Televison & Video Experts
matt martin
matt martin
Are you an Envision Televison and Video Expert? Answer questions, earn points and help others
