Question about Brandt Washing Machines
The drive belt has just snapped on my WD602 Brandt and pulled all the electrical connectors out in the back. Have you got a diagram to show how they all go back
Nothing
    Top Expert:
  • Brandt Master
  • 3,698 Answers
Www.brandt.com.hk
Posted on Nov 26, 2014
Brandt WFK1458FE ERROR CODE F08
go to http://www.brandt.com/ and get the support via ONLINE via chat or phone.
God bless you
Sep 25, 2012 | Washing Machines
Serpentine belt installation diagram
Long shot here, but on my vehicles, the diagram is embossed somewhere in the engine compartment, just a little diagram to show you how to thread it on. Usually you place a 1/2-inch drive for sockets into a shot and pull back the tensioner with it while you put the belt on. Good luck.
Dec 19, 2010 | 1998 Buick LeSabre
How to fit a alternator belt on a ford focus 16.00 can you send me a pick
p, li { white-space: pre-wrap; }
Simply follow the steps
Disconnect the battery's negative cable and set it aside where it can't accidentally snap back onto the terminal.
Remove the car's accessory drive belt. Disconnect the belt shield by removing its two 10-mm bolts, push up on the tensioner by hand, pull the belt off the air conditioner or water pump pulley and remove the rest of the belt. Take note of how the belt loops around each pulley.
Open the cover containing the alternator's electrical connectors and disconnect them. Remove the bolt on the coolant expansion tank then detach the tank from its clip and secure it away. Detach the power steering reservoir, engine wiring loom bracket, ground cable and evaporative emission canister purge valve.
Unscrew and remove the alternator's first bolt on its right side. Unscrew the second bolt on the left and disengage it fully from the bracket; it cannot be removed from the alternator. Remove the alternator from the engine.
Install the new alternator, placing the built-in bolt within the bracket and tightening it first. Insert and tighten the second bolt.
Replace all other objects set aside in the reverse order they were detached. (evaporative emission canister purge valve, ground cable, engine wiring loom bracket, power steering reservoir and coolant expansion tank). Plug in the electrical connectors and replace the cover over them.
Replace the accessory drive belt. Loop it over all the pulleys except the one on the air conditioner. Retract the tensioner upwards as you did before to fit the belt on the A/C pulley.
Reconnect the battery cable.
Aug 26, 2010 | 2001 Ford Focus
My dryer belt from my Whirlpool model number lgr7646dq1 snapped off and I need a diagram how the belt goes back on. I already purchased a replacment belt but do not know how it goes back on. Thanks Richard
the belt number 341241, that should be packaged with a diagram as how to wind it around the motor shaft , and the idler pulley.youll need to pull the front off the machine to gain acees to the drumm area, fom there you can drape the belt over the drum, "red side out"might be a difficult to try to hold up the drum and try to secure the belt without the use of another set of hands( the front panel that you removed holds the weight of the unit normally) afeter you get the draped belt around the ider pully "snaps into the lower cabinet so that you can pull hte tension to the right. after fully extending the pully to the right wrap the belt around motor pully and allow the idler to release and hold tension on the belt. it will only go on one way! only tricky the first time , youll get it!!!
Jan 27, 2010 | Whirlpool Dryers
How do I change a 2005 mustang alternator? NOT gt
2005 Ford Mustang 4.0L SFI SOHC 6cyl
Ford Mustang 1999-2005
Alternator - Removal & Installation
3.8L And 4.0L Engines
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Disconnect the negative battery cable.
  3. Remove the accessory drive belt.
  4. Disconnect the alternator electrical connectors.
  5. Remove the alternator shield (4.0L engine).
  6. Remove the alternator mounting bolts.
  7. Remove the alternator from the vehicle.
  8. Installation is the reverse of the removal procedure.
To install:
  1. Position the alternator onto engine. Tighten the lower bolt to 35 ft. lbs. (47 Nm) and the upper bolt to 18 ft. lbs. (25 Nm).
  2. Install the alternator shield (4.0L engine).
  3. Connect the alternator electrical connectors.
  4. Install the accessory drive belt.
  5. Connect the negative battery cable.
4.6L Engines (Non-Supercharged)
  3. Remove the air intake scoop bracket, if equipped.
  4. Remove the accessory drive belt.
  5. Remove the upper alternator bracket.
  6. Disconnect the alternator electrical connectors.
  7. Remove the alternator bolts.
  8. Remove the alternator from the vehicle.
  9. Installation is the reverse of the removal procedure.
To install:
  1. Position the alternator onto engine. Tighten the mounting bolts to 18 ft. lbs. (25 Nm).
  2. Connect the alternator electrical connectors.
  3. Install the upper alternator bracket. Tighten the bolts to 89 inch lbs. (10 Nm).
  5. Install the air intake scoop bracket, if equipped.
  6. Connect the negative battery cable.
4.6L Engines (Supercharged)
  4. Raise the vehicle.
  5. Disconnect the alternator electrical connectors.
  6. Remove the alternator bolts.
To install:
  1. Position the alternator onto engine. Tighten the lower bolt to 18 ft. lbs. (25 Nm) and the upper bolt to 37 ft. lbs. (50 Nm).
  3. Lower the vehicle.
  6. Installation is the reverse of the removal procedure.
More details about this model in Autozone.com (free register).
I hope help you with this (remember rated this help). Good luck.
Sep 17, 2009 | 2005 Ford Mustang
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Need to replace dryer belt.
screw on bracket of motor for tentsion release
Jan 24, 2009 | Whirlpool LEW0050P Electric Dryer
The drive belt snapped and ripped out 2 wires.
without seeing it i don't know but sometimes you can lay the wires next to the connector and they show you where they go in the bend in the wire plus there are noly 2 combinations try both,mike
Jun 03, 2008 | Beko 24 in. D3731F Free-standing...
Replacing the Drive Belt
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
Sep 16, 2007 | Hotpoint TDL14 Electric Dryer
Washing Machines Logo
70 people viewed this question
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
Harjeet Singh
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
