Question about Garland Kitchen Ranges
Could you tell me the voltage of the three wire relay of the Garland Master 200 electric oven? Thanks
We need to verify the voltage of the solenoid.
24 Vac
Posted on Nov 26, 2014
2 Suggested Answers
  • 125 Answers
SOURCE: what do I clean my 60" garland double oven with?
Hello. Try going here:
http://www.garland-group.com/?xhtml=xhtml/gar/us/en/general/productdownloads_service.html&xsl=productdownloads.xsl
this manual may not apply to your unit specifically, however, it does contain cleaning information specified by the manufacture for oven,grill, exterior, and stainless surfaces.
Hope that helps, and thank you.
Posted on Feb 22, 2009
I have a Garland Mater 200 electric oven and the fan continues to run even with the door open. Is there a switch / sensor that controls that?
https://www.manualslib.com/manual/55869/Garland-200.html?page=103#manual
This web site had a manual that may answer you question. It seems that here is a heat/cool switch. The cool switch is designed to function to cool the oven down by running the fan with the door open. If you close the door, it will heat so the door has to stay open.
Aug 20, 2017 | Garland Ovens
Secondary air injection pump not working. Checked voltage on it and got 2.81 volts. put 12 volts on it and pump worked
the air injection pump has a relay in the power distribution box that is controlled by the computer. it gets 12 volts when the relay is closed. the relay can be bad
Mar 29, 2015 | Lincoln Cars & Trucks
Oven cooks too fast and burns the food
My electric oven, Garland master 200 only reach a maximum of 250* and I only saw 1 of 3 elements turn red
Dec 14, 2012 | Garland Convection Oven - MCO-NAT Gas
Does not heat food-master relay reset, all electric OK (fan runs, time & all other settings show OK, turntable rotates), door closed tightly, control lock
THere are three possibilities, open magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor.
Mar 14, 2012 | Maytag MMV1164WB Microwave Oven
1987 corvette electric rear window release wiring diagram
You need to check using a multimeter on the solenoid for the operating voltage when the relay clicks on activating. If there is voltage then the solenoid is faulty and if not the relay contact points have burnt out and so does not give the connection for switching the voltage.In either case get yourself a multimeter or a 12 volt park lamp bulb to check the voltage on the solenoid.
Mar 12, 2012 | 1987 Chevrolet Corvette
How do I switch the wiring for a Garland Model S 686 -2 Stove from Single Phase to 3 Phase?
If the oven is a three phase oven currently wired on single phase there will be three active terminals at the terminal block. There will be links or bridges which connect the single phase to each of these active terminals. Remove these links and connect each phase to each terminal.
Feb 24, 2011 | Garland S686 Electric Kitchen Range
After usung the self cleaning function the oven no longer works
Check for correct voltage at plug, in the mean time the oven will be disconnected from any power, see if it resets with no power for 10 minutes
Nov 13, 2008 | Whirlpool RBD305PD Electric Double Oven
Kitchen Ranges Logo
57 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
