Question about Tefal Irons
I have a Tefal Protect GV9110 iron. Please please help me. It is not generating any steam. when press the steam button on the iron, it cuts off. if i leave it for a while, sometimes it generates steam
I clean it regularly.
    Problem Solver:
  • 5 Answers
You probably have a mineral buildup in the iron which is blocking the water flow. Try putting a cup of white vinegar in it and run it through over the sink on the high steam setting and then the self clean setting. After you run the vinegar through, run two cups of plain water through to get the remnants of the vinegar out.
Posted on Nov 26, 2014
Testimonial: "thank you for your reply. I tried what you recommended. Unfortunately, it is not generating any steam so the water remains in the tank and i can not clean it."
5 Suggested Answers
  • 24 Answers
SOURCE: I have Tefal protect turbo steam generator iron.
I have had the same problem. Though that the main heating element was bust so stripped the iron part down to test. Discovered that the bimetallic switch on the element had contamination between the contact points (will look blackened). If you have a multimeter you can test by pressing together and looking for continuity. Cleaned with some wire wool and some contact cleaner and sorted. 15mins to diagnose and fix
Posted on Feb 14, 2014
DiYerTech
  • 70 Answers
SOURCE: Tefal GV9110 Steam Generator Iron
Hi, you may try to "Google" location of TFAL GV9110 and see if you can find the home website. They should have a PDF of the instruction manual and hyperlink to download the Adobe Acrobat Reader to view and print the document if you are so inclined. Please advise if you find this helpful...good luck.
Posted on Jul 21, 2008
geokohler
  • 304 Answers
SOURCE: tefal proline express steam generator iron needs de scaling
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
SOURCE: Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Posted on Nov 13, 2009
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
Tefal iron steam generator
Steam irons can become clogged with mineral deposits. Use distilled water in the iron to minimize these deposits.
To clean the iron , use 1/2 white vinegar and 1/2 water. pour in iron and place iron on steam. The iron may require a few cleanings.
May 11, 2014 | Tefal Irons
Philips 6104 duble speed
follow this test and fix it. God bless you
As with many small appliances, regular maintenance makes a dramatic difference in how trouble free your electric iron will be. Even so, things can happen.
If the iron doesn't heat, make sure power is on to the outlet, check the power cord and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents and flush sediment out of the steam chamber
If the iron produces too much or too little heat, test the power cord Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Nov 29, 2013 | Philips HI-296 Iron
Straightener nano silver
please make this revision and fix it. God bless you
If the iron doesn't heat, make sure power is on to the outlet, check the power cord , and check the thermostat and replace if necessary.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the power cord. Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
Nov 29, 2013 | Irons
Cleaning a Rowenta steam iron
According to the manual, you should use regular tap water as long as it is not above 12 grains of hardness. Never use 100% pure distilled water, Rowenta recommends using inexpensive bottled spring water.
Jul 18, 2010 | Rowenta Effective DX1900 Iron with Auto...
My tefal express 2941 steams constantly when switched on and cannot be stopped, please advise?
Fill the iron with 50/50 water and vinegar and let it steam for as long as it will. This will clean out the iron thoroughly, the green light will stop flashing and it will go back to normal. Then remember to clean your iron on a regular basis. Mine did!! Found this solution on another site
Feb 20, 2010 | Tefal Irons
Irons Logo
258 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
