Question about Eureka Pet Pal Bagless Vacuum
There is smoke comming out of my eureka pet pal vacuum cleaner every time i shut it off. and it does not suck up dirt.
  • Phoenix pashelk
    Phoenix pashelk Nov 26, 2014
    i checked the belt.. it was perfectly fine. i cleaned off the roller.. but the smoke seems to be coming from the motor and i dont know what to do
    Problem Solver:
  • 16 Answers
Assuming it does not need emptying, then it sounds like a dangerous electrical fault. Recently similar thing happened to me, (different vac cleaner), and if I'd left it on any longer I'm told that it would have burst into flames. Be careful.
Posted on Nov 26, 2014
reddevil6
  • 1673 Answers
SOURCE: Vacuum Cleaner sucking dirt out of the cannister instead of into it.
You didn't give you model number, but check by the brush roll to see if the inlet there is clogged, hose still has a clog, filters are bad and need replacing. Does the brush roll turn, belts stretch after short usuage and will not drive the brush roll under load, may need to replace the belt.
Posted on Feb 17, 2008
rickzilla
  • 706 Answers
SOURCE: My vacuum doesnt **** dirt
Probably have a clogged intake from the beater bar thru to the vac system.. Try this.. with the vac unplugged, flip the vac over so you can get to the bottom of the vac head near where the brush rotates.. then depending on the model.. remove the cover to access the brush ( called a beater bar).
Once the cover has been removed ( may require removing several screws) .. look at the beater bar and make sure the belt is hooked up.. you should be able to lift that brush assembly out of the housing to expose the duct where dirt travels into the bag.. that path ( including the flex hose) is probably clogged up...clean out any debris found there.. ( if you have access to another vacuum..try sucking that junk out with it or use a stick or coat hanger to pry anything lodged in there out.. When that is clear, reassemble things and try it again.. Hope this helps you
Posted on Sep 23, 2008
SOURCE: vacuum is sucking but dirt is just shooting out behind the vacuum
I bought this same vacuum and have all the same problems. It seems it is always the filter but if it out and use the air hose and clean it it really really well then it sucks really well it will pick up anything but who wants to always do this. As one person asked about the bare floors not working well I read on another blog that company knows it does not work well on barefloors but has failed to metion this. One more thing besides the clog always being in the back were the hose connects I always find a clog in the yellow part above the canister. I always pull out so much crap there. Oh sorry one more thing I found that helped with the power was that I completely took the duster part completely off and just use the hose. Hope you have better luck than I do or did..
Posted on Nov 19, 2008
nwj2468
  • 76 Answers
SOURCE: EUREKA Bagless altima shooting out debris and not picking it up
did u clean the filter? if u get a new one i would suggest a kirby. bu get a self-propelled model. THEY LAST FOREVER!!!
Posted on Aug 22, 2009
Vac Belts
  • 701 Answers
SOURCE: eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Posted on Nov 19, 2009
How do I stop Eureka Pet Express from making loud noise?
does it make the noise with belt disconected if not its the brush . it could be installed wrong check it.
Dec 03, 2014 | Eureka Pet Expert Vacuum Cleaner in Mystic...
Theres smoke coming from the motor of the eureka pet pal bagless vacuum cleaner.. i dont know what to do
Some vacs have two belts. Is urs also self powered? If so, has a separate belt. With model # can give better info.
Nov 26, 2014 | Eureka Pet Pal Bagless Vacuum
Eureka 4870 upright vacuum cleaner needs powercord replacement
If it's not too badly damage you can wrap it with black electrical tape
Oct 20, 2014 | Eureka Boss SmartVac Pet Lover Bagged...
What size belt does a eureka pet pal use
Hi, it's Jeremy from Crucial Vacuum.
The Eureka Pet Pal requires Eureka U belts.
You can purchase direct your replacement belts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=eureka+u+belts
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jul 16, 2014 | Eureka Pet Pal Bagless Vacuum
My eureka multicyclonic vaccuum isn't spinning or picking up any dirt, what do I do?
Try open the bottom cover where the motor is located. It seems the the power belt is broken. Guides and Manuals Eureka
Apr 13, 2014 | Eureka Vacuum Cleaners; AIRSPEED One...
The eureka model # 4703D does not **** although the motor is running
The vacuum cleaner probably is clogged. Look especially in the opening behind the roller and follow the path to the bag/container. If you have a pet that sheds, you can clog a vacuum quickly
Dec 29, 2012 | Eureka Capture Upright Vacuum Vacuum
How do I change the belt on Eureka Pet Pal
Unlike most vacuums, this one the screws are on the top of your base. There are two screws one on each side. When looking at the front of the vacuum right side screw is located above the s in 12amps and on the left side screw is located above the p in pet. Now keep in mind it's not directly above the letters look about 2 inches up. Unscrew them, take cover off. Once you have done that pull up on the brush rod. Maybe tough if ur vacuum has a lot of built up dirt. Next put belt on metal prong then put on brush rod. Place rod back in its spot, gonna need little bit of muscle. Then put top back on and replace screws. Plug in flip bottom just to make sure brush is spinning. If u have followed steps this should work. I hope this helped took me forever to find the screws because I have always had vacuum with them on the bottom and internet was no help to me. Good luck
Nov 25, 2010 | Eureka 3276AZ Pet Lover Bagless Upright...
Eureka Pet Pal Bagless Vacuum Logo
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
