Question about Garden
Where do the two wires go from the rectifier on a 13hp briggs and straton single cylinder engine
Internet and Briggs agent
  • Eugene Rounds Nov 26, 2014
    Hi R Shand, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Several different possible configs.
    Really the equipment numbers including the engine and type numbers. Also need wire and connecter colors.
  • R Shand
    R Shand Nov 26, 2014
    Hi Eugene, the engine number is 21B807 type4120 H1. the two wires are red and black, the red has a diode fitted and they terminate in a push on plug
  • 1,169 Answers
From the engine model given you have a dual circuit alternator.
The red wire with the diode is connect to either to the amp meter if your mower setup has one or directly to battery side (large conductor) of the starter solenoid. It supplies a 3 amp unregulated DC charging current. The diode converts the Ac on that line in a pulsating DC voltage/current and it also normally prevents the discharge of your battery when the engine is not running.
The black wire is the AC output for your lights and is normally connect directly to the lighting circuit.
Posted on Nov 26, 2014
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
Presumably you have a red wire and a yellow wire. The red wire goes to the battery positive and the yellow wire should go to the starter.
rycgl
  • 1545 Answers
SOURCE: i have a 13hp briggs and stratton model # 28m707
Go to www.searspartsdirect.com . Enter your model number, get the owners manual download and inside there will be a page with the wiring schematic for it .Good luck!
Posted on Aug 23, 2010
bbreton
  • 437 Answers
SOURCE: need an ignition wiring diagram for a craftsman 14
Go to www.searspartsdirect.com. put in your model number, from under the seat and it will bring up parts list and diagrams for you.
Good day.
Posted on Oct 23, 2009
SOURCE: craftsman dls 3500 briggs and straton motor.
my craftsman dsl 3500 will start but wont move forward or backwards. whells wont turn
Posted on Mar 19, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Briggs & Straton 158cc engine
This is usually caused by either the introduction of air between the carb and the engine (loose carb mounting bolts or nuts) or.... debis in the fuel system. The debris in the fuel system would be on a float bowl type carb. If you have the carb that is mounted on top of the gas tank... tighten the screws that hold the carb to the tank.
If you pass me a complete / exact engine number off of the air shroud by the spark plug lead, I will pass you a parts list and identify the parts you need to look at.
We can get this corrected.. just need that engine model / type / series number.
Thanks for choosing FixYa,
Kelly
Posted on Sep 12, 2011
SOURCE: backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Posted on Sep 13, 2011
Wireing diagram for Briggs and Straton Mower engine
There used to only be a single wire, that when connected to any metal part of the engine will kill the engine
Sep 19, 2017 | Briggs Garden
Fitted new coil to briggs and straton 16 twin but have no spark
unplug the wire that comes from the tractor then check for spark if you do then stat by checking he safety switches
Mar 30, 2012 | Briggs & Stratton Garden
Backfiring thru carburator briggs and straton
Aug 14, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Best oil to use in tractor lawn mower
Always use straight 30W oil in small four cycle engines if they are not liquid cooled. Use a brand name single weight 30 viscosity oil.
Mar 16, 2009 | Briggs & Stratton Garden
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
