Question about Bosch Washing Machines
HOW TO RESET F16 CODE ON MY BOSCH MAAX 7 WASHING MACHINE
    Master:
  • 706 Answers
The easiest way is to just unplug the machine or flip the breaker off, then back on.
Posted on Nov 26, 2014
5 Suggested Answers
  • 1382 Answers
SOURCE: door wont open on bosch classixx 6 1400 express washing machine
The "F16" on a Bosch indicates the door is open / unlocked. If it's happening during a wash it would suggest either a faulty door lock, faulty wiring or worse, a faulty main control board. The wash program should halt when this comes up but you should be able to restart it when the door is closed. As the cost of a new door interlock isn't overly expensive. The best way to fix this problem is to purchase a new lock and fit it.
Thank you !
Posted on May 19, 2010
Chesc
  • 59 Answers
SOURCE: Error code F18 for Bosch Maxx 7 Silence washing
F-18 means the pump is blocked.
First checkthe filter for coins or other junks. Make sure the drain hose isn't blocked, restricted or kinked. Make sure there's no obstruction in the drain standpipe or U-bend.
If this doesn't work, might as well change the drain pump assembly. http://www.espares.co.uk/parts?k=pump
Hope it helps. ;)
Thanks for using Fixya. A 4-thumbs up for answering your question is greatly appreciated.
Posted on Jun 04, 2011
  • 500 Answers
SOURCE: Bosch exxcell 7 washing machine
Hi hulley3,
Keep the Start Button Pressed in for 5 sec.
If it does not help, try keeping the Power button in for 5 sec.
Should reset Child Lock.
Regards :-)
* If you found this solution helpful, please rate it
Posted on Jul 08, 2011
kevin_getz
  • 1031 Answers
SOURCE: f16 error code on washing machine
Posted on May 07, 2012
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
Error code 141. How can I fix it?
Bosch error code 141 Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
error code 141 Washing Machines Questions & Answers ...
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
Zanussi Washing Machine Fault Code Reset - iFixit
https://www.ifixit.com/...Washing+Machine+Fault+Code.../34977
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
[PDF]TOP LOADER Automatic Washing Machine - you
Dec 29, 2015 | Washing Machines
What does error F:16 indicate?
no one will know without a MAKE and MODEL.
Dec 26, 2015 | Washing Machines
What do's f16 mean on the bosch classixx 6 1200 mean
F16 is a door fault, could be the door is not tightly closed before pressing start, the lock is faulty so the machine is not registering that it is closed or the wiring connection to the door lock is loose.
Apr 10, 2013 | Bosch Washing Machines
Why is F16 code flashing up on my bosch avantixx washer dryer
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Aug 26, 2012 | Bosch Logixx WFT 2806 Front Load...
F16 error code on washing machine
May 06, 2012 | Bosch Washing Machines
I have a Bosch Logixx 8 washing machine showing error code 34. What does this mean?
Same as 'F16', 'F34' stands for 'door lock (fault)' ;-0)
This is indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 15, 2011 | Bosch Washing Machines
F16 showing on display
F16 measn a problem with your door lock.
The machine senses the door is open and will stop. The door lock isn't that expensive and should solve your problem. If that doesn't solve it then you may have a faulty control board.
Try the first choice. Good luck.
Aug 24, 2011 | Bosch Classixx WFL 2066 Front Load Washer
Door wont open on bosch classixx 6 1400 express washing machine
Thank you !
May 19, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Error code F16
F16 on a Bosch indicates the door is open / unlocked.
The wash programme should halt when this comes up but you should be able to restart it when the door is closed.
As the cost of a new door interlock isn't overly expensive I would suggest fitting a new lock on a "fit and see what happens" basis.
Aug 10, 2009 | Bosch Washing Machines
Washing Machines Logo
425 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
