Question about Whirlpool Washing Machines
MY WHIRLPOOL WASHING MACHINE AWO/R5206 CONTROLS ARE NOT LIGHTING UP AT ALL. CHECKED FUSE IN PLUG AND FUSE BOARD NOTHING WRONG.
SWITCHING ON AND OFF AND FUSE IN PLUG ALSO FUSEBOARD
  • 3 Answers
I am sure there is a electronic control board on the machine. I will bet the control board is defective.
Posted on Nov 26, 2014
Testimonial: "Thank you."
barkencoa
  • 3463 Answers
SOURCE: No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Posted on Dec 14, 2008
jonniewalker
  • 1029 Answers
SOURCE: fault codes f 13 Whirlpool Washing Machine AWO/D 5716
f13 is a Dispenser circuit error
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Posted on Jan 29, 2009
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
  • 69 Answers
SOURCE: Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
Posted on May 11, 2010
SOURCE: how to reset service ligth
whirlpool awdo/d 4505 flashing service light
Posted on Feb 03, 2011
AWO/D4405 whirlpool washing machine has power to machine but nothing lights up or works ?
all washers have a switch without them the washer would cease to operate. Check power source (outlet at the wall. ) use bed light lamp to test. if thats ok you may have a a faulty switch or an internal safety fuse blown
Jan 31, 2015 | Whirlpool Washing Machines
I have a whirlpool awo/d8140 washing machine that has suddenly seems no power. I have changed the fuse tested the plug and socket and nothing apears untoward when taken the lid off. Any ideas? Cheers Neil
If there is power to the main board, would suspect the board is the issue, however, if the pump, motor , water solenoid ect has a fault, machine will not fire up
Nov 22, 2014 | Washing Machines
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Aug 15, 2014 | Whirlpool Washing Machines
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
Washing machine not switching on no lights coming in control panel
Check that all the many wire connector plugs are seated correctly
on the board
Oct 27, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Feb 22, 2012 | Whirlpool Washing Machines
Whirlpool AWOE 8748 has no power. Changed fuse and tried in a different socket. Still no power.
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 16, 2011 | Whirlpool AWOE8748 Front Load Washer
My Whirlpool AWOE 8748 washing machine was showing error message F13. I swithced it off via the plug but the door will not open. Tried to switch it on again but no lights come on why?
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 04, 2010 | Whirlpool AWOE8748 Front Load Washer
Washing Machines Logo
230 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
