Question about Water Heaters
Tried reset code for vapor sensor it worked but then shut down will not start again Richmond model 6gr50pve2-42
    Top Expert:
  • 3,698 Answers
Www.richmondwaterheaters.com/Contact-Richmond-Water-Heaters
Posted on Nov 26, 2014
4 Suggested Answers
robocop
  • 90 Answers
SOURCE: need reset code for hot water talk
Go to www.richmondwaterheaters.com and see if they can assist you with it. Just click on residential products on the left side of the page.
Posted on Jan 22, 2009
SOURCE: need reset code for richmond
I am poting this here hopefully it will help someone else. I have a richmond 40 gallon power vent water heater and it was not working. It was flashing 2-3 on the LED. I used this procedure and it started up..
you can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Apr 13, 2010
SOURCE: i have a 75 gal.
I answer questions for free.
My job is to provide resources that help you for free.
1) That being said, my research into FVIRs says you need a plumber when the FVIR trips.
2) The use-and-care manual for your model also says call a technician.
3) Buying replacement parts through a plumber is true for all water heaters except the Bradford White which has a resettable FVIR. BW is the only company with a re-settable FVIR, however the water heater market changes daily.
4) If the FVIR shorted and shut down the water heater, it probably saved a fire and maybe saved a life.
The following site says to call Rheem, who will tell you to call a local plumber.
http://www.terrylove.com/forums/showthread.php?2520-Broke-Rheem-FVIR-waterheater-Please-help
The Rheem lineup of gas water heaters shows you have a 75 gallon tall heater:
http://www.rheem.com/products/tank_water_heaters/gas_water_heaters/
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
The spec sheet for your model
http://globalimageserver.com/fetchDocument.aspx?id=e3d293b7-bedf-4d9f-bf0f-d85b2d8bda5f
The use and care manual has troubleshooting section > it says the combustion shut-off has to be inspected by qualified technician
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
To get opinions from professional plumbers in the field:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/fvir-issues.html
Posted on Nov 05, 2010
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Richmond umc117 error code cl
Before calling service technician, open following link for Rheem-richmond tankless troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
May 07, 2012 | Rheem Tankless Hot Water Heater...
I have a richmond 40 gallon powervent water heater. It seems to light, but shuts itself off after about 5 seconds. I am leaning toward the vapor sensor. I know there are reset codes, but have not been...
1) Could be the vapor sensor. That's a suspect.
2) General troubleshoot: clean burner and combustion parts, clean air intake, bleed air from gas line, check gas pressure. Color of gas flame should be clear blue, and flame should be strong, and no combustion by-product dripping back into combustion chamber. No chemicals of any kind stored in air supply. Plenty of fresh air. Water heater in hot attic needs more air. If water heater has igniter, then igniter has to be checked. Flame sensor must be positioned correctly and operational at time of combustion, or sensor will signal gas control to turn off gas. Gas control valve can be bad.
Open following link for possible illustrations and reading.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
3) Specific troubleshoot begins with identifying gas control valve and reading the service manual.
I think the Rheem/Richmond power vent has intellivent gas control
Open following link to identify gas valve and download possible service manual:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
4) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 04, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Flammable sensor is lit and won't go off. I replaced the sensor how do i reset the controller?
Certain water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts. I'm not sure what control your unit has, but on a White Rodgers here's how it goes.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Oct 15, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a richmond tankless water heater RMTG-74PVN-2 . the unit works most of the time but code c-2 comes up on the display and the unit shuts down. I shut the power off to reset this does not fix the...
I have a Richmond tankless water heater PTG2-42PVN. It will work for a very short time & then I get an error code of either C4 or C7. The remote control alternately flashes IL - 120
May 16, 2010 | Rheem Tankless Hot Water Heater...
Richmond power vent water heater won't stay lit. I've reset the unit several times and the unit will run for about 10-15 minuets then shuts down (into lock down). Then I have to shut it off unplug it and...
I have a 40 gal richmond water heater with power vent and had a similar roblem. I call to talk to a tech and he suggested the vacuum switch. I ordered on line. It was $43 plus shipping and I installed it and it did the job. I happy.
Mar 29, 2010 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Need reset code for hot water talk
Jan 17, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
485 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
